Question about Makita UC3530A 14" Electric Chain Saw
Installing chain on homelite xl ut 10741 - Makita UC3530A 14" Electric Chain Saw
I need a manual for Homelite Texron #105064
I found this download link for the Homelite chainsaw ut10506-4 parts manual, if it is helpful.
http://megaslides.com/doc/9405595/homelite-chain-saw-parts-manual-for-xl-chain-saw-ut-10506...
No operators manual found.
May 02, 2017 | Homelite Garden
WHERE CAN I FIND A MANUAL FOR THIS CHAIN SAW MODEL UT10753
You did not say who the manufacturer is of your chain saw. Is it made by Homelite?
Go to this website: http://www.manualsonline.com/ and type in your chain saw manufacture and model
Feb 21, 2016 | Garden
Correct chain for homelite UT 10565
Pretty sure it is a 59 drive link chain
Feb 26, 2012 | Garden
Looking for the right replacement chain for homelite xl ut10695. Home depot had every other listing of UT model but, the ut10695. The brand to choose from is Powercare. I am hoping the powercare G60...
'Oregon' chainsaw replacements are available for practically any saw ever made--check with a local saw service shop for help. Unfortunately, the home centers only cater to late model saws which tend to turn stock more rapidly. Hope this helps!
Nov 09, 2010 | Homelite Garden
My homelite chainsaw model# ut10520 has aoil leak from the flexible line at the base of the oil tank.
I input your model number and found 3 possible matches, "42cc/46cc Chain Saw UT-10520; SUPER 2 Chain Saw UT-10520 or SUPER 2 Chain Saw UT-10520-A".
I opened the first "Ref # 3" on "Figure A" I suspect is what you say is leaking. It is very inexpensive and available. I would order one and inspect it once recieved to determine an installation method. It does not appear overly difficult without the part in hand. Good Luck.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 07, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
How to adjust the chain model 10655
See Chain Installation & Adjustment here: http://www.fixya.com/support/r4146814-chainsaw_chain_installation
No chain brake on your saw, ignore 1.
The adjustment screw is parallel to the bar. Look from the nose of the bar toward the engine the adjuster is the screw head just to the right of the bar (order follows):
1. - Engine,
2. - bar,
3. - guide bar plate (flared portion away from the engine),
4. - finally the clutch cover.
There is an illustration of most parts here:
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here:
Find "XL Chain Saw UT-10655", see "Housing & Handles" print.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 05, 2010 | Homelite Garden
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
Makita UC3530A 14" Electric Chain Saw Logo
27 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
