Question about Sony Playstation 3 (PS3) Console
Wont connect online was on earlier no problems got back home started up wierd messege pops up about erasing harddrive with a precent bar then goes away and system starts over and proceeds normal. i got to log in on psn in it says DNAS error occured. Well i do have internet and its running fine, my internet is wired not wi-fi and as i am online on my computer idk...tryed returning the ps3 to factory did it and when it did the connection test it went fine but once again when i try to log on PSN its says error.
    Problem Solver:
  • 20 Answers
Sounds like there is an error with the current firmware you have installed. you might have to go into recovery mode. to do so press and hold down the power button for about a minute and your blue light will start flashing and the recovery screen will appear. follow the prompts and it should work. keep in mind this is last resort and might format your HDD hard drive. you can also try going into your settings and scroll all the way up to were it says update console/ system and just update it. i know if you canceled a firmware update in the past it will create a problem were it will not function correctly because its not getting enough system packets from the update or it has missing packets when it did update. either way just update it and see if that fixes it, it will not erase the hard drive by updating it.
Posted on Jan 22, 2009
    Problem Solver:
  • 8 Answers
Try setting up a new account on psn it seems like the system is trying to log you on with incorrect login details
I have an IBM Thinkpad R51. When I try to use the WIFI, it only works sometimes. I get a good connection to my home router but cannot get online. Alot of the time I get a messege that the IP address cannot...
I've your using Windows 7, you can't do anything about it (yet)
Windows 7 is knows for connection errors.
It wants to check everything that a connection requires, and i've 1 " part " fails, the whole connection goes down.
Jun 18, 2011 | IBM ThinkPad R51 Notebook
Ever since i hooked up the usb ports from my mv8000 to my vista compuiter my roland wont save or it wont load any projects and also it seems that it erased all my songs that i ever worked on, when i start...
I think the most common cause of this with a pc is that windows media player scrambled the data on the hd.. you need to get a harddrive ide ata adapter , open the mv and connect the hard drive directluy to a computer then copy the files.. then reformat the harddrive in the mv then put the files back on .... i had the same problem with a mac but i dont know the cause since i dont have windowns media player.. im interested to know how this turned out.. i thinking of sending my drive to a drive saver company if it doens work out.. i neeeeeeddd my fillleessss.. aaahhhh
Dec 15, 2010 | Roland Mv-8000 Sampling/Record Production...
How can i see my online friend and available to chat.. from my home page?
You can find your online friend at right down corner of your home page. A small pop up is appeared at right side (Its showing "chat" and no. of online friends). You'll have click on this chat pop up, you can see all your online friends.
Regards
Ashly
Feb 25, 2010 | Facebook Social Network
Panasonic home theatre keeps making a popping
try cleaning all your connections for your speakers with isopropyl alcohol and a q-tip, if no luck it could be an internal problem
Jan 09, 2010 | Panasonic Home Theater System System
XBOX 360 PROBLEM!!!! HELP!!!
Have you tried replacing the hard drive?
Jun 21, 2009 | Microsoft Xbox 360 Console
Erasing Network Harddrive
I'll go ahead and assume that you're using Iomega's home media network drive. That model has a built in USB 2.0 port, so you should be able to connect one of the Macs to the hard drive physically. OSX should recognize the hard drive and allow you to format it. If you are unable to physically access the drive (i.e., it's in a closet, wall, server mount) you may be able to still connect to the built in server on the drive and format it from there. I would recommend the physical method first though.
May 26, 2009 | Iomega Computers & Internet
My nokia 5300 wont charge
your mobile was wet someday
and now the effect is on
U should imedietly go to ur near nokia care center
and for the charge thing
Tell nokia care center to replace the charging needle ... bcuz it is rusty..... !
Mar 08, 2009 | Nokia 5300 Grey Cellular Phone
Dunno what happen??
When You Boot up your screen goes in to the windows xp loading bar and after a quick blue flashin screen pops up and it restarts unfortunately this is what they call the Blue Screen of Death so more than likely you harddrive with the os is corrupted so either you will need to reload the OS or by a new harddrive and load the Os on that Harddrive
Jan 22, 2009 | Microsoft Windows XP Professional
Loocking Up when Findings Friends
This may or may not be a solution but....with my quantum of solace, couldnt get online at all, but after a while they fixed it...its wierd but I was one of a few that had that problem...I can play friends on MC wii no prob.. so call nintendo ask about the platform.....or erase your connection settings(wired and wireless) make new connections..if that dont work try erasing your profile and friends numbers(of course, have them do the same and communicate them back to put the FCs back in) IF THAT dont work wait it's probable like my quantum of solace,not working for me but for others....one of the others above said they could play worldwide and regional...so you know its not something serious....good luck
Nov 02, 2008 | Nintendo Mario Kart (Wii) for Wii
Sold computer
download a eraser program that will fully erase your files on your computer, search on google theres heaps of them. i did it and its imposible to get back.
Jul 05, 2008 | Intel Motherboard
Sony Playstation 3 (PS3) Console Logo
70 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
