Question about Laser Symbol Technologies MC9060S Mobile Computer with Short Case and WLAN and Bluetooth and Standard Rang... (MC9060SH0H9AEA750) Barcode Scanner
Symbol RF MC9060S - Internal Battery is dead
How do you fix or replace the internal battery of Symbol RF MC9060S terminal? What kind of battery? Or even, Does anybody know how does the warranty expires on Symbol products?
  • Buster Mercado Jul 07, 2007
    Is it normal for the internal battery to stop charging after only 16 months since I received them.
    Of course my problem now is that they are now outside the warranty period.
    To avoid repeating this same problem in the future, Is there anything I should do?
    Habit-Forming:
  • 45 Answers
You have to first charge the backup battery, for charging insert a fully charged main battery into the MC906x. Then the backup battery will starts charging leave it there for one day. if that message is still coming then the problem is with the backup battery and u have to replce it
Posted on Jul 11, 2007
  • 944 Answers
First check if the internal battery will hold a charge. Symbol says; "The MC906x backup battery charges off of the MC906x main battery. To charge the backup battery, insert a fully charged main battery into the MC906x. The MC906x can be placed in its cradle, but does not need to be. The backup battery takes approximately 15 hours to charge. To determine whether the backup battery is fully charged (after allowing to charge for 15 hours), remove the main battery." If you are still getting the replace internal battery message, contact these guys for a replacement and instructions - (you have to open the case, and often these batteries are board-soldered components, so you have to be reasonably skilled to identify and replace them); http://www.symbol.com/category.php?category=733 Warranty details are here; http://www.symbol.com/symbol_warranty/warranty.html If you can get a spare battery from Symbol and want to try it yourself, please post back a photo or two of the inside and we can hopefully direct you, but symbol may well recommend sending it to them for replacement. Hope this helps :)
Posted on Jul 06, 2007
  • 1 more comment
  • Nigel Ridehalgh
    Nigel Ridehalgh Jul 07, 2007
    It largely would depend what type of battery it turns out to be. See what Symbol says, and then please ask us again. Try and get them to give you the specifications of the battery.
    Good Luck :)
  • Nigel Ridehalgh
    PS if you get nothing from Symbol, Then see if you can open it up and take a few photos - post them back and we can see what we can do :)
  • Nigel Ridehalgh
    PPS if you can't get the info from Symbol, also ask if they can at least get you a service manual :) :)
SOURCE:
Help
if it has a internal battery
the internal battery must be dead i think
kindly test it
Jun 16, 2008 | Tomtom GO 910 GPS Receiver
What is the mc9090 internal battery
Leave the 9090 overnight in a charge cradle and check status of backup cell in control panel>power. If the is still dead after a full night of charge then it will need to be replaced.
May 28, 2014 | Symbol MC9090 Mobile Computer Portable...
My fone dead put charger in does nothing dead dead dead
Nokia phones are notorious for slow response time when recharging from a completely dead battery.
Remove battery.
Make sure there is good contact between all of the contact points.
Replace battery.
plug in charger.
wait for at least 5 min.
If recharge symbol does not appear in window, then one of these things has occurred:
1. Phone has internal damage or water damage. no way to fix without nokia service.
2. Battery is dead. Try a new battery
3. Charger is bad. Try a new/different car charger or home charger.
These chargers are very inexpensive on Craigs List, try to solve it before throwing away the phone. Good luck,
A former Nokia employee.
Feb 16, 2011 | Nokia Cell Phones
My Tracker will start and then the battery is dead and now it is a dead battery. Driving it loses power and lights all go out.
Take off both battery cables and use coarse sandpaper to clean out the inside of the cable terminals and clean the outside of the battery posts. Examine the battery cables to make sure one of the the cables iis not coming loose from the end terminals. You may need to disconnect the other ends of the cable and clean those terminals also. If that doesn't fix it you should get the battery checked. It could have an intermittent internal short.
Using a pocketknife to clean the terminals before using the sandpaper could speed up the process if there is heavy corrosion.
Dec 05, 2010 | 1990 Geo Prizm
RF driver failed to load
It can only be one of two things.
Less likely but also will cost you nothing, try and reload LWP and UPD but don't forget to use the comman FLSHFMT on both E drive and D drive first.
More likely is that the radio card of the terminal is busted or might have become lose as the internal radio connector was always a bit flakey on this device. You can try removing the 6 screws on the plastic cover, open it and unplug and plug again the radio card.
Apr 17, 2009 | Symbol PDT 6846 Portable Terminal
Internal battery terminal corroded and fell off
Old batteries leak and the battery terminals corrode. Replace the terminals and clean the area thoroughly.
Jul 27, 2017 | Canon Optics
Battery symbol blinking when put on charging.
It does sound like the battery needs to be replaced, but it also could be an internal charging problem with the camcorder. I would try a new battery first, since it's the easiest and cheapest option
Oct 19, 2008 | Sony Handycam DCR-TRV38 Mini DV Digital...
Gyration keyboard goes to sleep too quickly and then....
This sounds like an internal failure on the keyboard. It should not go to sleep. By removing the battery you are effectively resetting the internal logic. If the status light is on all of the time it may think it has (or have) a key stuck and is timing out to conserve battery life. If that is not the case it is time to contact Gyration Technical Support.
Dec 11, 2007 | Gyration GB9450-220 Keyboard
Laser Symbol Technologies MC9060S Mobile Computer with Short Case and WLAN and Bluetooth and Standard Rang... (MC9060SH0H9AEA750) Barcode Scanner Logo
1,583 people viewed this question
Top Laser Computers & Internet Experts
Sunil Karickom
Level 1 Expert
Steve Sweetleaf
Steve Sweetleaf
Are you a Laser Computer and Internet Expert? Answer questions, earn points and help others
