Question about Radio Shack Pro-2096 Base Scanner
Backlit display and keypad fading
I purchased two Pro-2096 Digital Scanners when they first became available, one for the house, and one for the car. The other day, I downloaded and installed the Firmware v1.4 update. I did the house scanner first which is probably the only reason I noticed this; but when I went out to the car to upgrade that scanner, I noticed how much dimmer the back lighting had become on it. I keep the house scanner on the dimmest setting and see the display easily; however even with the Dimmer on the highest setting, the display and keypad lighting is not very bright at all anymore. As far as I can tell, all other scanner functions are working okay. I am wondering if the extreme temperature changes experienced here in Minnesota have affected it? The scanner has been in temperatures from 30 Below to 150 Above. It is mounted under-dash, so I don't think it's been in direct sunlight too much. Any suggestions on fixing or upgrading this issue? Has anyone else experienced this?
  • standers420 Feb 07, 2008
    20 mins out of the box... nice...
    Problem Solver:
  • 6 Answers
Known problem... remove display SMALL ribbon cable, trim 2mm cleanly, clean connections, reinstall, reassemble. good luck
Posted on Feb 07, 2008
  • 139 Answers
On the Driver Board of the Display,There should be Some Capicitors,They will tend to Change Value Causing the Display to Go Bad Also since its in a Car look for Bad Solder conns around the ribbon Cable that goes to that Board Goodluck TTech
Posted on Jul 20, 2007
SOURCE:
Pro-2096 Digital trunking mobile/ base scanner
hello,
Open the mobile and the refix all the connection inside maybe some loss connection make it faulty.
best ,
melnavz
Apr 29, 2008 | Radio Shack Pro-2096 Base Scanner
Will the Nexedge be decode by Pro-2096 so I can listen to them?
No. Nexedge is a Kenwood digital system that utilizes a different protocol that the more common APCO system, and there are currently no scanners capable of monitoring Nexedge transmissions. You can find more information on the Nexedge system here:
http://nexedge.kenwood.com/faqs.html
Bill B.
Listening in since the 60's
Jan 19, 2011 | Radio Shack Pro-2096 Base Scanner
Unlock code all frequencies for pro 2096 digital scanner
Sorry, but there is no magic code that will "unlock" your Pro-2096 or any other modern scanner. If you want a scanner with wider frequency coverage, you'll need to purchase one that comes that way from the factory.
Bill B.
Oct 07, 2010 | Radio Shack Pro-2096 Base Scanner
Display keeps going out of the pro 2096, it was repaired once,,,, is there any simple fixes to this?
Unfortunately there is not. This is one of the "gremlins" that plagued the 2096. From what I have been told by other 2096 owners, the problem comes from a fault where the ribbon cable (or flex) joins to the LCD display. You may want to try opening the scanner and checking the connection. Sometimes gently pressing on the joint with a pencil eraser can re-establish the connection.
Sorry I don't have a "quick fix" for you, but hopefully this will help steer you in the right direction for troubleshooting.
Feb 22, 2010 | Radio Shack Pro-2096 Base Scanner
My pro-2096 does not display any letters or
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Jan 22, 2010 | Radio Shack Pro-2096 Base Scanner
Looking for a part number for a
Here's a link to the parts list for your scanner. Parts can be ordered online or from your local Rat Shack store.
http://www.icomamerica.com/en/support/PartsAndService/default.aspx
Dec 19, 2009 | Radio Shack Pro-2096 Base Scanner
We have a police digital scanner havent been able to receive the police frequency wonder if they have been changed? i dont want to have to pay for this service just need new frequency numbers if they have...
Your community's public service radio frequencies may have been rebanded. Rebanding was the result of services throughout the nation being moved in the 800Mhz band.
Complete rebanding details of this can be found here:
http://wiki.radioreference.com/index.php/Rebanding
The Pro-2096 scanner can be reprogrammed to receive your old services in the new band with software that is run on your computer and connected to the scanner. It is available for a small fee ($30). More information on this can be found below:
http://wiki.radioreference.com/index.php/Win96
Many scanners are not capable of upgrading, and were reduced to "paper weights". Consider yourself lucky that a $30 upgrade will restore the full functionality of the radio. A great deal of information on your scanner can be found here:
http://wiki.radioreference.com/index.php/Pro-2096
I hope this helps!
Sep 29, 2009 | Radio Shack Pro-2096 Base Scanner
Blank screen goes in and out
My 2096 was doing the same thing with a blank screen. IF, your scanner is scanning normally and the dim button still dims your display, your problem could be the same as mine was. This worked for me and got my display working like new again. First thing to do is to take the covers both top and bottom off to expose your scanners insides.Next, once you can see the inside of your scanner you will see a ribbon cable connected to the main board and also soldered to the display. Take the ribbon out of its coupling connector and gently clean the contacts on the ribbon with a cuetip with alcohol on it, also clean the solder joints on the display face that connect the ribbon to the display with the cuetip and alcohol. Ii then reassembled everything, ribbon back into its connector and made sure the clamping mechanisim on the ribbon was securely holding the ribbon. I pluged the power supply into it and turned it on before reassemblig the case covers to see if it would work. Bingo, it worked like new again. Hope it works for you ! Jim
Nov 04, 2008 | Radio Shack Pro-2096 Base Scanner
This is happing to most of the units and radioshack wont admit it.
Apr 18, 2008 | Radio Shack Pro-2096 Base Scanner
Radio Shack Pro-2096 Base Scanner Logo
415 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
xxxxxx xxx
Steve Allison
Steve Allison
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
