Question about IBM ThinkPad R32 2658 Notebook
Error stuck key 29 ibthinkpad lenovo T61
I am using IBM thinkpad T61, when I put on my computer immediately the message error 0210 stuck key 29
pkbytes
  • 45 Answers
SOURCE: 'stuck key' on IBM ThinkPad 390E (2626-DOU)
goto the device manager and uninstall the keyboard and restart the system. check that the error is still coming..
If still the error remain same ...shutdown the system and power off and just clap the each and every key of the keyboard to release the keys if any stuck. Check that error by rebooting the system. Hope that the problem is solved.
If still not then maybe the keyboard is going bad.
Cheers - Parveen
Posted on Feb 10, 2008
SOURCE: Spacebar on IBM Lenovo ThinkPad X61 came off.
I took mine off to clean under it and had a similar problem. After a bit of struggling I figured it out. I will try to explain it as best as I can, but forgive the non-technical language:
There are two gray plastic pieces on the space bar that must be that must be latched to the two white plastic pieces on the computer. The gray pieces pop off the space bar easily. Take them and put them on the white pieces on the computer so that the white arms lay across (and snap into) the top and bottom of the gray piece. The middle of the gray piece will sit in between the two arms that are not "holding" the gray piece. Then take the space bar and put the metal part into the hole on one side (outside of the plastic pieces) and then push it over so you can put the opposite metal part into the other side. Then push the space bar straight down and it will snap into place.
Posted on May 30, 2009
SOURCE: i have error 0210 stuck key 01 on an IBM
My key R is stuck. And some some letter keys become numbers once I press them
Posted on Jan 28, 2010
  • 111 Answers
SOURCE: error 0210: stuck key 01
I assume its a laptop. laptops some times get stuck keys, meaning one of the keys has not fully released after it was depressed. I recommend getting some compressed air in a can and give it a good cleaning. there might be something stopping git from popping back up. then give the keys a little work out. just mash the keys a bit. then turn it back on. if you still have an error, then you might want to consider replacing the keyboard. if you don't, it will not harm you pc in anyway...good luck
Posted on May 04, 2010
  • 10406 Answers
SOURCE: ibm lenovo t61 won't boot. if it overheated, is my
Yes, it's highly-likely that all your "data" files on the disk-drive are intact. Any qualified computer-technician can remove the disk-drive, temporarily connect it as a "slave" drive in a computer, and copy all your files onto DVD-writable disk(s).
Posted on Jul 20, 2010
Error 0210 stuck key 41
Reset BIOS to default settings. Perform Flee Power - remove the battery and any other peripheral device connected to the computer. Hold the power button for 10-15 seconds and then connect only the AC Adapter and turn ON the computer.
If none of the above said helped to resolve your concern, I strongly recommend you to contact our technical support for assistance.
Apr 28, 2012 | IBM Lenovo ThinkPad T61p T9500 Notebook
ERROR 0210: Stuck key 7B Press F1 to setup . Please help me out of this problem.
There are issues with the ThinkVantage Button at boot as it doesn't do what its suppose to. Just use the F1(BIOS Setup), F11(pre-boot/recovery area) and F12(boot device selection).
Just a reminder to practice press and release when pressing a button. We sometimes get impatient and do a key hold down for a while rather than multiple press and release.
I hope this would resolves your ERROR 0210: Stuck key
Jul 20, 2011 | IBM Lenovo ThinkPad T61 Notebook
ERROR 0210: Stuck key 7B, what do with this?
if this Problem before windows you need to reset keyboard cable anf if the Problem still you need to replace the keyboard
else if the Problem after windows just repair the Windows
Jul 11, 2011 | IBM Lenovo ThinkPad T61 Notebook
My thinkpad 2628 wont recognize my hard drive and tells me i dont have a operating system on it
This means it has crashed. You will need to use your recovery disk that came with the laptop to re-install Windows and the system drivers.
May 05, 2011 | IBM ThinkPad A21m 2628 Notebook
I have an IBM ThinkPad T42 whenever I boot it shows an error message Error 0210 : Stuck Key OF Press F1 While using my built-in ThinkPad Keyboard there is a beeping sound on all the keys pressed...
Hi Levu, I can help resolve the issue over the phone,please provide me your number or please call me at
OneEighthundred,ThreeThreeNine,NineSixThreeFour (Free number in USA ).
One time charges apply ,USD 20; pay only if issue is resolved.
My Name is Harry.
Jun 21, 2017 | IBM ThinkPad 390X 2626 Notebook
I spilled some water on my laptop. After removing keyboard and letting it dry, it seems key 29 is stuck. When turned on, my ThinkPad T60p shows error 0210 **** Key 29. Which letter or key corresponds to...
mcdevito75 here, Yopu should be able to lift the cover off that #29 key and use a drop or 2 of penetrating oil to free up that key, not unless that button is broke in which case you"d have to replace the entire keyboard.
Jun 22, 2010 | Office Equipment & Supplies
I have error 0210 stuck key 01 on an IBM
Nov 17, 2009 | IBM ThinkPad 390X 2626 Notebook
ERROR CODE "0210:KEY STUCK 39
I got the 0210 stuck key error on a Lenovo Thinkpad T61, pc would not bootup, made sure keyboard was connected and cleaned with aircan and then went into bios and via F1 on startup, then went to CONFIG then to Keyboard/Mouse then I disabled the TrackPoint. Boots up fine now but the red nipple mouse is disabled due to action mentioned above. Looks like a warranty fix for Lenovo since this is a newer laptop. If it was out of warranty i would just skip using it and leave it disabled. The trackpad works fine.
Apr 27, 2009 | Compaq Presario 1200XL111 Notebook
IBM ThinkPad R32 2658 Notebook Logo
1,202 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
