My Toshiba 43n9uxa dramatic-theatre tv switches on but has a blank screen with the power/timer light flashing!
SOURCE: flashing power light
you need 4 caps in you dm module they are 1000 mf @35volts
Posted on May 25, 2007
SOURCE: monitor screen blank and LED orange light flashing
I think you should try clean the cmos first... its not a monitor problem but for the system.
Posted on Aug 20, 2007
Slinteriors
  • 8617 Answers
SOURCE: flashing green timer light, no image on TV
4 capacitors on the DM board causes this they are 1000uf @35 volts replace these capacitors and that should take care of your problem
Posted on Mar 19, 2008
  • 33 Answers
SOURCE: Mitsubishi WS73713 - Now working - Timer light flashing.
hold menu button for 8 sec and then unplug for 1 minute. then when you plug it back in it will work after 1 minute
Posted on Jan 24, 2009
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Posted on Jul 01, 2009
Toshiba dramatic theater projector tv is dead, no screen, no sound with flashing red and green standby light pls help
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts//
Mar 04, 2018 | Toshiba Televison & Video
My toshiba tv 60 inch shows a blank screen.when I start it toshiba sign shows then blank screen why and how to solve
if the power button flashes in a pattern note down that pattern and repost the query with that included...presumable the power button light does not go out.
Jul 26, 2015 | Toshiba Televison & Video
My tv toshiba 43n9uxa has a red shadow to images and seems tilted on the edges with blue hue
Ur tv convergence are dead.Must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair world.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost $300-350 for parts and labors.
Apr 26, 2010 | Toshiba 42H81 42" Rear Projection...
Not powering up
Do you hear clicking inside the TV when you switch on?
Does the red power or green timer light flash on and off?
May 28, 2009 | Toshiba 42H81 42" Rear Projection...
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Green screen crash
i have a projection tv. It is a a Samsung HDTV 55" widescreen. There is a green curvey lines at top of screen. Can you help?
Jan 20, 2008 | Televison & Video
Design Problem of TP55H60
call tech ..suggest soldering h-drive.
Jul 26, 2007 | Toshiba TP55H60 55" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
