Question about Water Heaters
Flashing red light on vokera mynute 24m
Boiler wont start and has flashing red light
3 Suggested Answers
  • 234 Answers
SOURCE: vokera mynute 14se lockout reset button on
Has the boiler cool down? Try turn the power off for a few minutes and see if that will work.
Posted on Mar 15, 2009
SOURCE: hi got vokera 14-48 se mynute boiler piolt light
Vokera minute problem,
Replace the venturi at flue outlet
Posted on Jan 21, 2011
Alpha boiler cb24
Google Alpha boiler you should be able to down load a online manual with a ff chart in it . which should have codes in there for flashing lights .
Jul 29, 2017 | Water Heaters
Thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but then...
Check the pressure reading, should be about 1 bar when system is cold. Various models in the range of 24cdi. If you do not have a manual, go to,
http://www.centralheating.co.uk/Boiler-Manuals/worcester-bosch-boiler-manuals/worcester-bosch-discontinued-boiler-manuals.
Get the manual for your unit, to wards the end of install manual it has a fault finder, Also has a basic 1 in the user manual. Number of flashes how fast the light flashes which one flashing can all mean different, So get the manual and check, Some parts are easy to fix, as long as you do not touch the gas side the rest is plumbing. Come back if needed.
Mar 05, 2013 | Water Heaters
Boiler
Call in a plumber. Mine did the same, new valve was needed, Possibly Diaphram needs replacing.. Consider how old is Boiler, and does it need replacing anne melhuish
Jan 25, 2012 | Water Heaters
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Nov 08, 2009 | Water Heaters
Combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Jan 22, 2009 | Whirlpool Aquatic Millennium VII -...
Boiler light wont ignite
more likely the thermal coupling is u/s get new one fitted
Dec 02, 2008 | Water Heaters
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
Water Heaters Logo
97 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
