Question about Refrigerators
The LCD on the Candy wine coller flashing and wrote "E2" when normally you see the temprature.
4 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: My Dome 40 bottle
Hi and welcome to FixYa, I am Kelly.
The defrost thermistor has failed. This E2 error code means that your appliance has experienced a defrost sensor fault. The bad thermistor will be near the top of the evaporator coils.
Thanks for choosing FixYa,
Kelly
Posted on Apr 25, 2011
Testimonial: "From one side of the world to the other;Thank you so much Your reply was spot on and greatly appreciated.Keep up the good work"
  • 5 Answers
SOURCE: My wine coller won't hold
If it IS a small compact refrigerator, used as a wine cooler, then it may be "iced up" and just need defrosting, if only part of the coil is iced, it is probably low on gas, or the "condenser" coil on the back (or under) the unit may be dirty, a fan not running, or just too close to a wall and not breathing). It is "doubtful that the thermostat is bad, but just setting it colder will tell, and the "setting" is usually marginal anyway.
If it's a larger unit with a fan or fans inside Like a walk-in cooler, then there are other possibilities
Posted on May 12, 2011
  • 884 Answers
SOURCE: bottles in candy wine cooler ccv 150bl are not cold enough even with thermostat is turned to cold is there any way to solve this
Check the condenser is clean, and the inside not iced up. Is there a fan inside? Check all is operating normally. When you say it is not cold enough, what temperature are you trying to reach? For keeping / storing wine, 8 to 10 c should be fine. For chilling before drinking, take the wine to a domestic fridge to get it to 4c
Posted on Apr 21, 2012
BWE40 wine cooler. Is it safe to leave it switched on when code e2 is showing? Does code e2 distinguish which of the two sensors need replacing? Thanks.
Hi All,
I had this error on my wine cooler. I checked the sensors and got a reading Kohm from both, however i still decided to replace the rear sensor - buried in the foam. It is located in the foam about 20cm from the LHS and 20cm from the bottom of the foam.
I got the sensors from here https://www.inter-spares.co.uk/?subcats=Y&status=A&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&search_performed=Y&q=49032008&dispatch=products.search
I left the front (internal sensor) and just swapped the two terminals in the 4 way plug. I used normal expanding foam to fill the areas where i had removed the foam looking for the sensor. All up and running now.
May 11, 2014 | Baumatic BWE40 Wine Cooler
Bottles in candy wine cooler ccv 150bl are not cold enough even with thermostat is turned to cold is there any way to solve this
Apr 21, 2012 | Candy Refrigerators
Avanti error code e2 wine chiller, what is the problem?
Display flashes Error message "E2" - Defrost sensor (Coil Sensor) failure.
Contact the Avanti Service Department - 1-800-220-5570
Hope helps.
Jun 03, 2011 | Avanti WC42 Wine Cooler
My Dome 40 bottle electric wine cooler keeps flashing E2. Does anybody know what is the problem?
Kelly
Apr 25, 2011 | Refrigerators
NEEDED: manual for BC 112G wine cooler
Hello Ahanaples,
I understand that you are trying to locate a user manual for you Haier BC112G wine coller. I have located the manual on Haier.com the following link will take you to the page then you just have to click on the model of the unit that you have the first one at the top of the page.
http://www.haieramerica.com/en/support/modelsearch
Thank you for choosing FixYa.com
Justin Burnett
Mar 28, 2011 | Haier BC112G Wine Cooler
WKE 3000 temperature panel has stopped working - unit still turns on and off properly.
IF YOUR UNIT IS A WKL IT SHOULD HAVE A SENTRI III CONTROLLER(BOARD) THAT HAS A LCD DISPLAY GREEN NUMBERS ON IT WITH BUTTONS(SET, WARMER, COLLER) IF SO THE ONLY OTION IS TO REPLACE THAT BOARD, A VERY SIMPLE PROCESS 10 TO 15 MINUTES MINIMU TOOLS, CONTACT BREEZAIRE AT 858-566-7473 THEY WILL SELL YOU A BOARD OR CONECT YOU WITH A DEALER TO BUY THE REPLACEMENT BOARD ARROUND $150 APROX
Nov 11, 2010 | Breezaire WKL 4000 Wine Cooler
Danby Wine cooler runs and runs
not hard to replace but you are correct if it is not cycling off at the temp you want it to then the temp control is the problem
Apr 12, 2008 | Danby DWC283BLS Wine Cooler
Leaking water from the back
make sure that the drain is connected properly at the back.
Make sure that the little drain pipe (usually clear hose) is sitting in the plastic shroud that sits on top of the compressor at the back of the fridge.
Apr 09, 2008 | Danby DWC310BL Wine Cooler
Refrigerators Logo
318 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
