Question about Sharp SF 2020 Copier
SHARP COPIER I have a sharp copier i changed the toner and the roller and it still makes dark copies please help. model SF-2014
  • ptm5577 Jan 24, 2009
    Hi Wiz i replaced the drum roller only, and i will cleaned the optics.
    I will get back to you soon thanks ptm.
  • ptm5577 Jan 30, 2009
    Hi wiz this is ptm again. I cleaned the optics and it help a little, copys are liveable. Problem # 2 What would make the writing from the other side of the paper blead through, I try using heavy paper did not help. Thank you
  • Sharp Expert
  • 1,326 Answers
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Posted on Jan 23, 2009
Sharp SF-7370 copier, with a dark line going from top to bottom
check the drum cleaning blade maybe the blade is worn out
Jan 04, 2010 | Sharp Office Equipment & Supplies
Sharp SF 2014 copier power problem
Check the power cable for power. If there is power at the end of the cable but the machine does no switch on,the problem might be with the power supply. If there is a fuse which is user accessible, check that. Otherwise its a technician job.
Jun 04, 2009 | Sharp AL 1631 Copier
Sharp sf 2014 copier problem
clean the paper feed rollers with soap and water damp cloth take paper tray out use flashlight to locate rollers also clean registration roller under the drum check and see if u have any broken gear teeth on your fusing assemby also if after cleaning it works i recommend u replace feed rollers
Jun 04, 2009 | Sharp Office Equipment & Supplies
Sharp copier 2027 roller toner light on
Have you added toner resently? If so you will have to emptiy out the waste toner. The bottle is filled with toner and has set a flag in to a sensor.. I believe the waste toner bottle is in the front of the copier on the right side. It has been awhile scine I've worked on this model.... It may be behind a door on the right side of the copier toward the back of the copier... Be carefull when you empty out the bottle...... Use a plastic bag with No holes in it..... The toner will go every where if you are not carefull... Good Luck
Apr 18, 2009 | Sharp SF 2020 Copier
Melted exit rollers SF 2020 Sharp copier
Please.....do yourself a favor, and call a service tech.
Feb 27, 2009 | Sharp SF 2020 Copier
Sharp sf 2050 prints dark lines on page when beginning copies, lines dissapear after about 100 copies....is there some kind of heating element in these or something i am overlooking please let me know
replace the drum cleaning blade , clean the optices if this does not work replace the drum but this is a old copier not really worth much $50 mabye
percison roller phx az has parts
Feb 25, 2009 | Sharp Office Equipment & Supplies
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
SHARP SF2014
Try using heavier paper say 80gsm. Or adjust light exposure if possible.
Oct 29, 2008 | Sharp SF 2020 Copier
108 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
