Question about Garmin nuvi 260W GPS Receiver
The end of my 12 volt power supply cord was lost.
I lost the screw on tip or end cap and the fuse contained with in the 12 volt power supply cord. Is it possible to purchase these parts, with out replacing the power supply cord?
  • Garmin Expert
  • 343 Answers
You might be able to use the parts from an old cell phone adaptor. Have you tried that?
If not don't mess with any off brand adaptor. Get another one from Garmin at their website Garmin .com
Posted on Jan 17, 2010
Does my Casio g-200 keyboard have a fuse ? If so what type and where is it ?
I'd go exchange the power supply for the correct one (check the voltage, polarity and mA rating that's marked next to the power input). It may be too late, though.
There will be a fuse on the internal power input board, as well as one in the power supply, but if the instrument is turning on and lighting up, it's not a blown fuse.
Jun 29, 2016 | Casio Wk-200 Wk200 76-key Digital Personal...
My TV is dead. What boards should i replace?
have you checked the DC side of TV LOOK FOR ANY CAPACITORS with holes blown in them and are a of a burnt appearance , and also look for any breaks in circuit board also look for holes in circuit solder . I know this might sound silly have you checked the fuse in the MAINS PLUG ....
Dec 28, 2015 | Televison & Video
My whistler quit working. How do I fix it?
What Quit? Does it not power up? If so, have you checked the fuse that is in the plug end of the power cord? The tip unscrews to reveal a 2 amp glass fuse. Does the lighter socket power other 12 volt devices? If not, check the vehicle's fuse box. Did you press or turn the power switch? (sorry had to ask)
Mar 15, 2011 | Whistler Vehicle Parts & Accessories
The power electric was run over by mower -unit has no electical power
You could bring it to a repair shop where they will probably install a new power cord. The now-shortened power cord can be fitted with a new plug, and used as before instead - for a fraction of the cost.
From what I can tell, the pressure washer is a 120 volt type. Purchase a replacement plug - called a "cord cap". The most common configuration is pictured below:
A 15 amp / 125 volt male cord cap made by Leviton.
Your's is likely rated at 125V/ 15A (like the one above). This means there's 2 parallel blades and a ground pin - like most grounded plugs in your home. If unsure, bring the cut off section of the power cord to a hardware store to select an identical cord cap. You'll want to purchase the type of cord cap that has terminal screws - not the type without screws. The packaging of the cord cap will indicate how much of the cord jacket and individual wire insulation to remove. A little more or less won't make it impossible to do - but don't deviate too much from these dimensions for the best results. Once the cord has been stripped correctly - Disassemble the cord cap body from the outer shell by removing the screws on the front. Loosen or remove the 2 screws at the cord grip end and slip the shell over the end of the power cord.
Bring the cord cap body to the cord. The body will have 3 screws. One each silver (or light colored), bronze (or dark colored) and green. Loosen all the screws - do not completely remove them. Twist all the strands of each wire so that they are bundled together and there are no stray wires sticking out. Do this for each white, black and green wires. The black wire will connect to the bronze colored screw, the white wire to the silver screw and the green to the green colored screw. You can either insert the stripped wires into the small holes at the back of the terminal screws, or wrap them around the screw terminals themselves. The best way is to wire from the back - but if you choose to wrap around the screws, be sure all the small wires are under the screw head. Tighten the screws and tug the wires one at a time to make sure they are held firmly in place.
Once satisfied that the wires are connected correctly and tight - slide the outer shell towards the cord cap body. Align the screws with the holes in the outer shell. The parts will only fit together one way - so don't try to force it together. Tighten the screws in the front and then install / tighten the screws at the cord end to grip the cord. This clamp should be firm - but not to the point of crushing the cord. Test in a ground fault protected outlet and you're done!
I hope this helps.. please rate this reply - thanks!
Dec 21, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Hello I have a problem with my detector and that is, that the device just went off completely and won't turn on now?
Did you check the fuse that is in the end of the power cord? Does your lighter socket power other 12 volt devices? If the fuse in the power cord is bad, replace it with a new 2 amp fuse. If your lighter socket doesn't power orther 12 volt devices then check the vehicle's fuse panel.
Dec 07, 2010 | DE-1730 Radar Detector
When I plug the radar in the green dot turns on for a second then turns off, nothings on afterwards... I used a new wire and fuse and nothing....what could be wrong?
Does the unit work in another vehicle? If not, first thing to check is the fuse in the power cord. The adapter (part that plugs into the lighter socket) has a replaceable 2 amp 3 AG fuse inside it. The end of the adapter, which has the silver tip, unscrews to gain access to the fuse. CAREFUL: Unscrew slowly! The tip contains a spring which may fly out when disassembling. With use, screw cap on plug may loosen. Retighten occasionally.
Jun 23, 2009 | Car Audio & Video
Missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Apr 05, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
No power for Sony ICFCD855V Dream Machine.
Power supply seems to be 12 volts. I have ICFCD855V's and the power cords on both broke just past the strain relief on the power supply. That shorted the supply and blew the fuse (1.6 amp). I soldered in a new fuse and the supply (with no load) puts out 12VDC. Since it happened to 2 in my house I can't believe Sony doesn't have a recall on these things
May 10, 2008 | Toshiba Sony ICFCD855V Clock Radio
Garmin nuvi 260W GPS Receiver Logo
121 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
