Question about Qmadix iharmonix Q-i-sound Stereo Bluetooth Speakers White
Won't connect to computer bluetooth - Qmadix iharmonix Q-i-sound Stereo Bluetooth Speakers White
I have a uniden wireless mouse and it won't
here ur pc is recognizing ur external hardware that is mouse but cursor is not moving this indicates that bluetooth connection is good and problem comes with the mouse. i advise to meet a good technician and there is nothing to do with it further.
Jun 28, 2013 | Computers & Internet
My bluetooth is paired to my Pantech P6020 but it won't automatically connect.
Unfortunately there are different versions of bluetooth. Pending on the age of the handset.
You could try a bluetooth adaptor
Dec 28, 2017 | Cell Phones
Ms9535 won't connect to macbook pro
Apple don't allow anything to link to Macbook's via bluetooth. I can't even connect my iPhone 4 to my Macbook Pro unless I connect it with a USB cable.
Nov 11, 2012 | Metrologic MS9535 Voyager BT Accessories...
Mki9200 won't list itunes
If you don't find a solution good luck with custemer service
May 26, 2012 | Parrot Mki9200 Advanced Color Display...
Bluetooth won't connect
I'm going to assume..you've got an iPhone.. Simply because apple seems to have a "list" of approved blue-tooth items.
Unless your "JailBroken" (google only, please do not ask), if the said bluetooth device will not connect, consider updating your iOS to 5.1.1. or 6.0, or simply deal witht thefact..it won't work... Older deviices (3gs and prior) don't support things like A2DP (blue-tooth bi-direction communication, like a head-set)... and unless (jailbroken..see above about google). will simply not work.
If your NOT talking about an iPhone..you've got me.
Apr 08, 2012 | iPhone Apps
My bluetooth won't connect
you should make sure you are hooked up to a phone or computer and it will work much better. and if that doesn't work make sure the person your talking to has phone service. and if all else fails go to good old texting.
Mar 19, 2012 | Coby Kyros Android Tablet
Bluetooth won't find devices
Hi! actually there are two type of bluetooth one is for software and the other one is for hardware. meaning if you do have a bluetooth built in bluetooth within your computer desktop or laptop you should have to install the driver in order to initiate and execute the bluetooth services, like data transferring.
kindly check you computer device manager
Good luck and God bless....
Feb 02, 2012 | HP Computers & Internet
I cant connect my i phone 4 to my laptop what can i do !
Unless you're trying to tether your phone to your computer or create a personal hotspot, it won't pair with your computer by bluetooth. File transfer by bluetooth is not supported. So, you can quit trying unless you're trying to tether.
Dec 09, 2011 | Apple iPhone 4 Black Smartphone
Bluetooth won't work and even won't turn on with win7
- Download the 'Windows Mobile Device Center which you can download it from
this works for both Vista and Windows 7. I've tried it on both.
Install the downloaded software but it may not look like it worked on Windows 7 PCs. Vista automatically configures the settings on the bluetooth devices but for those who have Windows 7, here are the things you should do:
- Go to 'Device Manager' from 'Control Panel' -Or- just right-click on Computer Icon and choose 'Properties' and then click on 'Device Manager'.
- You'll see an 'Unknown Device' named 'Bluetooth Peripheral Device'
- Right-Click it and click on "Update Driver Software" -Or- anyway you find it easy to bring up the Update driver window.
- Click "Browse My Computer for Driver Software" button.
- Click "Let Me Pick from a List of Device Drivers on my computer".
- Select 'Bluetooth Radio' from the list if it asked you to select and then in the next window, it will show a list of drivers with Company Names in one list and Drivers in another. In the Company List choose 'Microsoft Corporation', not only Microsoft.
- From the drivers list there may be one or more drivers with the name "Windows Mobile-Based Device Support" with different driver versions. Select one or the latest.
- Ignore any warnings and keep pressing next and then Finish at last. If all goes well, the last screen will show the message that device driver is successfully installed.
Now, after manually updating the driver for your bluetooth device, in 'Device Manager' when you click on 'Bluetooth Radios', it should display one more item which will say 'Windows Mobile-based device support'.
There are few more things that you want to pay attention to. If you have already added the device in your 'bluetooth device list' that didn't work, then remove the device and add it again. After you add it, you might need to restart the computer if it gave you a connection problem error message.
I hope this will help you guys fix your bluetooth problem with Windows 7.Rate me if the message was helpfull.
Thanks
May 20, 2011 | Computers & Internet
How to activate Dell vostro bluetooth
1) Install the bluetooth driver provided for your system. It will ask you to activate bluetooth by pressing fn+f2 key (this won’t work).
2) You manually have to install the software for the driver.
Note: some of you may have already installed the drivers but just cannot start the connection. So there is a problem in the software and not the driver.
For installation of the software follow these steps.
3) Go to your driver installation directory (ex. C:\dell\drivers) then you find which driver you installed for your bluetooth.
4) Then you find your system you are running (a 32 bit or a 64 bit) it will written as win32 or win64.
5) Then you find the installation file. Then install the application and it will be all ready once again.
P.s. don’t forget to turn your Bluetooth adapter on after you install the software.
May 20, 2010 | Dell Vostro 1510 Laptop
Qmadix iharmonix Q-i-sound Stereo Bluetooth Speakers White Logo
20 people viewed this question
Top Qmadix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Qmadix Audio Player and Recorder Expert? Answer questions, earn points and help others
