Question about Pentax ME Super 35mm SLR Camera
Pentax A3000 frame advance jammed
My camera, a Pentax A3000 has a LED 1000 in the viewfinder . The battery check works and I have replaced the batteries.The problem is that the frame advance will not advance to the first frame.It stays on the S and will not advance. I've looked through the manual and can't find much on the subject.I have tried re-loading the film. Is the button sticking or is it the frame advance? Will this be an expensive fix or is it something small that I can fix?
    Scholar:
  • 58 Answers
There could be a number of causes.
First make sure that the replacement batteries are up to it. Ie one's marketed for camera use. Others often cannot supply the current required by the motors. (Electric motors require most current just as they start, and so it may not do anthyhing at all.) Then check the battery contacts are clean. Much the same reason applies, dirty contacts cam prevent the batteries from supplying enough current.
One more simple possibility is that it does not know the battery door is closed. This may be detected by a protrusion in the film door edge operating a contact in the loctaing groove, or contacts in the door latch. There may be more than one!
It is also possible that the camera is detecting an impossible film. DX coded film uses the contacts inside the film chamber to read the film speed from unpainted sections of the film cassette. It is just possible that a dirty contact or a scratch in the paint is telling the camera that the film is a speed it cannot handle, or is just confusing it with a nonesense code!
Outside these there are a number of possibilites which will require internal investigation. You can try these camera repair pages for tips on repairing your own camera.
Posted on Jan 23, 2009
Film was in camera, frame 18. Batteries had failed at frame 17, had to depress "B Lock" button" and set shutter to 60 to release shutter. Replaced batteries with fresh batteries, battery...
This camera is somewhere between fifteen and thirty years old. It is highly unlikely that spares would be available, and it would be extremely expensive to have it repaired in any case, most artificers familiar with the internal layout having probably retired years ago. Maybe the camera should be retired too ?
Apr 16, 2017 | Olympus OM-4TI 35mm SLR Camera
The mirror inside the camera has flipped up and wont stay down I can't see anything through the viewfinder
The ZX-50 does not have a mirror lock up feature so there are several possibilities for the problem. There could be residue on the foam padding where the mirror hits the inside of the camera frame causing it to stick. In this case the foam may need replacing and the inside frame cleaned. Checking with a camera dealer in your area will answer the question in more detail.
Oct 28, 2010 | Pentax ZX-50 35mm SLR Camera
Screen is black and film won't load
If it's a 35mm film camera and you see nothing through the viewfinder, then as long as the lens cap has been removed, your camera has a locked up mirror.
You don't give any clues which exact model you have, but if it's one of the later electronic autofocus models with automatic film advance then the additional detail that the film isn't loading confirms that your camera simply has no power. Replace the batteries and all should be well.
If your camera does not have automatic film advance then you still almost certainly have flat batteries and just need to learn how to correctly load and wind the film.
Feb 28, 2010 | Pentax Photography
The mirror on my pentax pz1 (film) camera is stuck
Mirror lockup often occurs if the batteries are flat.
Try new batteries first and if the problem remains please report back for further options.
Feb 13, 2010 | Pentax PZ-70 QD 35mm SLR Camera
No pic framing on LCD display - playback is OK
ON digital slr cameras there is no pic framing on the LCD display.
Apr 25, 2008 | Pentax K100D Digital Camera
PENTAX MEF SLR CAMERA,
I just bought some batteries for mine...you will get it in any photo or camera store
Dec 05, 2007 | Pentax ME Super 35mm SLR Camera
Pentax K100D DSLR
The interface IC ( between the main CPU and the CCD sensor ) seems faulty . Camera should go to the Pentax agents unfortunately.
Sep 02, 2007 | Pentax K100D Digital Camera
Black viewfinder
Slr mirror is stuck. remove the lens and try to slightly move the mirror up and down ( but not forcing it to move!)and pushing the shutter switch. Try also applying lighter fluid in the mechanism while operating or shooting, fluid will help loosen the stucked mechanism.
Aug 31, 2007 | Pentax ZX-7 35mm SLR Camera
Viewfinder
I don't know how to answer your question, since I haven't yet experienced that phenomenon. It sounds like it's just caused by the nature of the lenses used. Since you are new to the camera, I'll just warn you that it is not perfect in any way, but every function of it is very good, so the end result is amazing, and I might even say perfect. This is just the nature of the Pentax dSLR for now, and it seems that it's a Pentax thing in general. You'll find lots of dSLRs that can outperform the Pentax in one or two feature comparison tests, but if you lign up all the features of one camera and compare them with the Pentax you'll find the Pentax will beat any camera out there. It is just so well balanced, and each feature really is good enough, which adds up to a LOT. I'm sure somebody here will explain the problem you're having, and if you're like me you'll just make a few adjustments and be satisfied with the results. Post some shots too, that's an excellent way of getting feedback that will help you make the most of your Pentax. I wouldn't trade my Ds for any other camera out there even costing 10 times more.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Pentax ME Super 35mm SLR Camera Logo
660 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
