Question about Home Security
WPC818RX Doorman Plug in Chime
TRying to reset code on the above
2 Suggested Answers
SOURCE: 'Doorman' chimes keep chiming, without bell being pushed
I had the same problem - turned out to be a cordless phone nearby. If you have one, try moving the bell away from the phone or vice-versa. Another possibility is a neighbour with the same code. There are some jumpers you can move around to change this.
Posted on Apr 22, 2010
Changed chime and now button does not work. Maybe I missed a step in changing the chime on the plug in chime? JETech battery button and plug in chjime
The battery-powered button is an RF transmitter. When the plug-in chime is replaced, jumpers may have to be changed to match the code in the button.
Feb 10, 2017 | The Home Security
Reset alarm stopwatch start pc396 pressing hourly chime
with the alarm time showing - press the split reset button if the hourly chime is on you will see a row of dots above it. Press the mode button to get the dots to disappear and turn off the chime.
Jul 16, 2013 | Fossil Watch Style # FS4387
Will my wireless bell push work with another manufacturers door chimes?
Doubtful they are compatible. If they are set by dip switches and you set them the same bot doesn't work-not compatible.
Jul 17, 2012 | Home Security
How to turn off beepiing and alarm on sportline 240
To set/Disable Hourly Chime/Alarm
Step#1.Press "Mode" (center button) until you are at "Time Display" (the home screen)
Step#2. Hold "Split/Reset" Button it will show the alarm time
Step#3. Keep holding Split/reset button and press the "Mode" (center button) "Hourly Chime Is On" when dashes appear above display (in alarm mode) "Hourly Chime is Off" When no dashes appear!!!!!!!!!!
Jan 24, 2010 | Sportline Stopwatch
Trying to reset the code for my DESA wireless doorbell but the only combination that works is 5,6 & 7. Need another code because neighbor has that code.
It would appear that there are pins in both the ringer and door button and you have to change them so they match. To remove the door button, slide the case straight up slightly (maybe 1/8 inch). Pry the top of the case away from its base and slide down to remove the entire button assembly. The pins are inside, next to the battery. 5/6/7 seems to be the default, so any other combination of three pins should solve your neighborhood conflict. (Don't use pin 8. That one changes the ring from a two-tone chime to a 16-note sequence.)
Jan 16, 2010 | Desa International White Wireless Plug In...
I have a byron SX85R plug in wireless door bell, i need to change the frequency/ or code, keep false alarming, cant find the instructions , also with the alarm, is a batterie alarm no. SX81R, which came...
From User Guide: Interference from a similar unit operating nearby: a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
Oct 10, 2009 | Bell Cocoon Child Carrier
SL-6195-RX seems three houses have the same
Open up both the button and the main unit and switch the codes with the pins. It done on a row of pin sets - Default is usually connectors on 5-6-7 (8 is on the main bell unit and causes the ding-**** to change to a Westminster chime).
With a pair of needle nose pliers pull the connector and set them on different numbers. You must do this on both pieces, When you have a unique code its no longer an issue with the neighbors.
Aug 02, 2009 | Desa International White Wireless Plug In...
Jan 19, 2009 | Desa International White Wireless Plug In...
Home Security Logo
103 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
