Question about HP PSC 2175 All-In-One InkJet Printer
Clicking underneath the control panel board
Hi, I just got off with one of your support people trying to troubleshoot a problem. There is a clicking sound beneath the key board on the control panel. I need to remove the control panel cover to investigate.
  • hairrrazor Feb 06, 2009
    Knocking, repetitive noise under keyboard. ERROR message says "scanner failure, turn printer off and on again" Attempted turnoff and will not turn off with button. Pulled out power cord, waited 60 seconds, plugged into wall power outlet, knocking starts over again, stops noise in a minute or so, then copy/scan/photo card buttons blink off and on..... HELP!
  • Juanita Vega
    Juanita Vega May 11, 2010
    what type of printer are you working with?
  • 62 Answers
Scanner has a lock on it that sounds like it needs to be unlocked. See user manual for info on where scanner lock is if it has one.
Posted on Feb 12, 2009
Frigidiare lffh21f7hwa freezer When door is opened light will flash on and off you can hear a clicking sound, every so often it will have to be reset by unplugging
You are talking about the inside light right? The clicking is coming from the controls panel right? I think the problem is related to the control board itself because there is a relay that switches the light on when the door is opened part number=> 297366300 Frigidaire Freezer Main Control Board Otherwise if removing the bulb will stop the problem, please try that. Appliance 911 Sea Breeze
Dec 06, 2015 | Refrigerators
I dont know which sound drivers install in my computer
Hi, try looking in Control panel, system, hard ware, device manager and clicking the + sign on the audio, right click audio and update or discover which driver you have. Hope this helps.
Jul 02, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Fan not turning clicking in back
Hi. This will indicate that the Main circuit board(PCB), which is located in the back, middle or lower rear panel, has failed. This clicking noise is the result of a failed relay, on this particular board. The main board directs the necessary power to this fan circuit when commanded by the control sector. This type of circuit damage will cause all components within the unit to fail, thus, not allowing optimal performance. I would advise to replace this damaged board, asap. Once replaced, the unit will operate normally.
Dec 11, 2009 | GE Refrigerators
I have a GE profile side by side model PSS26SGRCSS. Lately the water and ice dispenser have worked only intermittently with a dimming of the lights. Tonight it stopped working and the temperature display...
Something has malfunctioned on *********** control board part number WR55X10942 This board controls most functions of the refrigerator. It would be simple to say change the board but this is the first time I have seen one affect so many different controls that I recommend that a service technician come out and make sure that something other that that board is not affecting the other controls on your refrigerator. Please let me know what the technician finds, Thanks, Sea Breeze
Sep 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge gss25ifrf ww side by side fridge clicking
Sounds like the main control board is bad . Pt # WR55X10656 . This board is located behind the 8 " X 10 " , panel just above the compressor compartment . The compressor relay , is what you hear clicking , cutting the compressor , on/off . Even the dispensor board , is operated by the main control board .
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The compressor is not running and there is a clicking noise coming from the circuit board panel on the back of the refridgerator
You have to replace the main control board . The clicking is the compressor board relay , which the only repair , is to replace the main board .
Sep 11, 2009 | GE Refrigerators
My fridge is making a clicking noise (like a car turn-signal) and the digital display in the fridge is out
The clicking is from the main control board relays clicking off and on . The part number you need is WR55X10656 . This board is located on the back , behind an 9X10 inch aluminum panel . It controls the digital display along with all other operational parts of the fridge .
Aug 21, 2009 | Refrigerators
GE Profile Refrigerator clicking
Sounds like the main control board is bad . Check your warranty to see if board could still be covered .
Aug 08, 2009 | Refrigerators
Clicking sound fridge freezer not running
Hi alexaz97,
First off the wire under the hinge is only for trouble shooting and should be fine. The control clicking on the other hand is usually a bad sign. The relays on the board should not click on and off, I have seen this about 10 times this month at my appliance store. The board will need to be replaced. If you would like I can send you a control board. I have pleanty in stock and ready to ship. The control is $124.99. Shipping is included. You can contact me here or at my appliance store.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Jul 31, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
HP PSC 2175 All-In-One InkJet Printer Logo
99 people viewed this question
Ben Johnson
