Question about Refrigerators
Hi. We cannot figure out how to take off the water, ice dispenser on outside front of refrigerator, Model # ED25DQXDW00.
    President:
  • Refrigerators Master
  • 2,651 Answers
Its a little tricjy nad requires a little patience and trust in modern day plastics!, if you look closely under the faceade of the dispensor assy, youl see 2 little notches cut into the plastic, youll need to place a small screwdriver into these notches ( one at a time will work) and twist it off, at the same time your doing this apply some pressurein a downward fashion to the top for the facade, the front will pop off with a little persuasion.. then lift off top clips, to reinstall , hang back unto the top clips and heres where the trust comes in while appling hte same down ward pressure , youll need to "hit" the bottom clips back on , . I use the heel of my hand and have yet to breakl one yet!
Posted on Jan 22, 2009
How to fix water leak on GE Profile Refrigerator
I would look at the dispenser door for the ice (ice chute) I have seen this door not completely close and cause leaking the you are describing. This door is has a black seal, use a flashlight, from the inside of the freezer door, look for light on the outside of the door. I think you leak is there and replace the solenoid for the door to fix this issue. Good Luck, if you want more help please input a model number. Thanks
Aug 17, 2014 | Refrigerators
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Water, ice and crushed ice dispenser doesn't work properly
you need to replace the board in the dispenser front housing on the front of the freezer door / larry
Mar 16, 2009 | Refrigerators
Ice and Water Dispenser not responding...
had the same problem, there was a component in the front user panel that was shot
Mar 29, 2008 | Kenmore 44103 Side by Side Refrigerator
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
Kenmore Side by Side Refrigerator Model #106.50544001
It's time to replace the dual water inlet valve (the part the water line connects to). A bit of sediment or other fine object can get in the seat or the material itself can deteriorate and allow a tiny amount of water to pass up to the icemaker.
Jan 04, 2008 | Whirlpool GR2SHWXPB 21.7 cu.ft. Top Mount...
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
