Question about Kenmore Elite 45986 Front Load Washer
What does the F11 error code on my Kenmore Elite He 3t mean?
I am in the middle of the Express Wash cylce and the washer has stopped, locked and is beeping F11
  • 5,911 Answers
"F11" is a serial communications error. The following link explains the possible causes and how to troubleshoot:
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
First, attempt to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). In many cases, this is all that is required in order to correct momentary glitches with the unit. If the error code reappears, follow the advice provided in the link. In the majority of the cases, I've experienced, it was the CCU that caused the problem.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Jan 22, 2009
Yupo, was getting F11, unplugged washer for 40 minutes, all ok now.....johngrunt1
Posted on Jan 24, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Cycle will not spin and drain properly near end of cycle. Keep getting F11 fail codes when I try resetting my kenmore elite HE 3t any suggestions?
    Hi Shaun, I just found (and watched!) a good youtube video which may help with your problem regarding the F11 code, link follows below.
    Trust this helps, best regards Alan
    Troubleshooting and Repairing the F11 Error Code in Whirlpool Duet Washer
    Feb 12, 2015 | Kenmore Washing Machines
    Kenmore elite washer he 3t error code f11
    You have a bad CCU. What is the model number?
    Nov 04, 2012 | Washing Machines
    Cylce stops after 1st drain before spin out
    I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
    Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
    On HE3T wash stops in middle of cylce and flashes F2
    "F02" is a Long Drain error. The following link explains:
    http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
    Most commonly, your drain pump has something clogged in it causing the drain flow to be obstructed. I would begin by checking the drain pump reservoir. I provided a follow-on link with the advice I gave you that explains how to do this. If you have any questions along the way, please let me know. I hope this helps you.
    May 02, 2009 | Kenmore Elite 45986 Front Load Washer
    Error codes f and h
    I have the HE 3t and an error code of f flashes at the 9 minute mark. Can any one help with this problem? When I contacted customer service that told me to unplug the machine and plug it back in. This did not solve the problem. Any suggestions?? Thanks, Paula
    Jan 17, 2009 | Kenmore Elite 45986 Front Load Washer
    F and then 06 error/ Kenmore elite HE 3T series 4
    well i found the answer on browsing through fixya. the following would assist you with the needy.Hoe it is helpful.Pay back with your comments if the problem is solved.
    http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
    Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite HE 3t - error code F dU and door is locked
    Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
    Jul 29, 2008 | Kenmore Elite 45986 Front Load Washer
    When washing, it stops and says F11. What does that mean?
    F-11=Serial Communication Error
    Communication between the Central Control Unit( CCU)and the MotorC ontroUl nit
    (MCU) cannot be sent correctly.
    PotentialCauses
    . CheckW ireH arnessc onnectiontso the MCU.t he motor,a ndC entraCl ontrol
    Unit (CCU)
    . Checkt he Drives ysteml or anyw orno r failedc omponents
    . ReplaceM CU
    . ReplaceC CU
    . Replace Motor
    . ReplaceW ireH arnes
    Apr 05, 2008 | Kenmore Elite 45986 Front Load Washer
    F 11 Error Code
    The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
    Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    1,129 people viewed this question
    Sal De
    fordexpert
    Robert Rankin
