Question about LG 42PG20 42 in. Plasma HDTV
My lg 40pg20 won't turn on
When i press the power button it blinks blue then turns red meaning it has just turned off, but now when I press the power button it turns on then off and stays at blue and it turns off and on by itself repeatedly
dave1645
  • 834 Answers
SOURCE: lg 26lg30 light blinks red blue wont turn on.
you have a bad cap in the power supply
these are can shaped device thet if bad will vent anf put up on the top the valoue is wrtten on the side trplace them and you should be good to go
Posted on Nov 06, 2009
freelance-au
  • 131 Answers
SOURCE: 61" plasam TV will not turn on
This is one of two problems, Bad capacitors in the power supply or your Y Sustain board has failed, I would go for the first, take the back off your tv and look for swollen or domed shaped capacitors on the power supply, They may also leak a brown liquid like substance.
Replace all that you can see and this should cure the fault.
Posted on Mar 05, 2010
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Posted on Mar 21, 2010
  • 2318 Answers
SOURCE: My LG Plasma 42PC3D turns on and off repeatedly. I
Your plasma TV has a power supply 6709900019A. These power supplies failed due to defective capacitors. See the picture below and check the capacitors mark with the red lines. There are 10 capacitors that should be replaced even if they do not show signs of bulging/swelling on top.
The value of the capacitors is 3300uF/10V but you can use 25 volts as long as they fit in the space provided by design.
Posted on Sep 24, 2010
eagle338
  • 4889 Answers
SOURCE: lg model 42pm4m plasma monitor won't turn on, red
Does the tv make a clicking noise like its trying to turn on before the tv goes into standby and the LED starts flashing? I suspect this is due to a shorted component, most likely to be in the 5V(switching) line and just want to be a bit certain before we start testing the power supply.
Posted on Jul 31, 2011
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Microphone PG58 won't turn on, it has a blinking red light when I push the power button
Your circuit board could be bad, but i would pull out the circuit board and spray contact cleaner onto the button, let it dry a few minutes and connect the battery and press that button quiet a few times and see if that fixes the problem.
Dec 06, 2012 | Shure PG58 Professional Microphone
My computer won't turn on
when it is blinking red it means its in sleep mode. at that time the fan is turned off by your computer to save power. Press the power button oce again and u should have it up and running.
Aug 15, 2012 | HP Computers & Internet
My 42' hisense tv turns on then blinks. blue then
Take it to a servicer with proof of purchase or back to the store. You will get it repaired for free or get a new TV.
Apr 19, 2012 | Televison & Video
When i turn on my LG 32lg30 on, the power indicator light flashes red 4-5 times, then the monitor turns on to a steady dark blue color. I tried to press buttons on the remote but there is no display.
Now there is a challange.
My LG has not shown this behaviour yet. Do you still have the DVD disk that came with the TV.
If you do you will get your answer there I presume.
Make sure that you are using the correct input.
kollagunn
Feb 21, 2012 | LG 32LG30 32 in. LCD HDTV
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
My subwoofer and wireless speakers won't sync lhb975 blinks blue then turns red
http://www.avsforum.com/t/1386546/lg-lhb975-wireless-speaker-sync-repair Te solution is here
Jul 18, 2011 | LG LHB975 Theater System
LG 42PG20 42 in. Plasma HDTV Logo
Computer Repairing
Computer Repairing
