Question about HP Officejet 6310 All-In-One InkJet Printer
Printing invitations I am having trouble printing on a 5.5 X 8.5 invitation.
  • 2 more comments
  • Anonymous Jan 29, 2009
    I cant do it
  • LawMama Jan 30, 2009
    Have the same problem with HP2355 All-in-One. Mismatch paper error.
  • Anonymous Apr 18, 2009
    I am having the same problem My HP Office Jet 6310 doesn't recognize the 5 1/2" paper width...HELP!
  • Anonymous May 05, 2009
    Trying to print 5X8 notecards and can't figure out how to do it!
    New Friend:
If you are printing from word 2010 and have an HP printer;
-set up your document on your screen how you want it to look, go into your print preview section, your printer should be listed towards the top of your page and directly under it should be "printer properties" click here, select the features tab in the next window and change your paper size to the correct size for your document.
-you may also need to go into the page layout tab in the main screen, select the size button, click on "more paper sizes" at the bottom of the window, select the paper tab and change the size of your paper again to the size of your document
-lastly, while in the "paper" tab window select "print options" towards the bottom right corner, left side of new screen click on advanced, scroll down to print and make sure there is NOT a check in the box that says "scale content for A4 or 8.5 x 11" paper sizes
Posted on May 10, 2014
4 Suggested Answers
  • 10 Answers
SOURCE: print 5x7 invitations on my 950?
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
Posted on Oct 06, 2007
  • 6 Answers
SOURCE: Can't Print Invitations
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Posted on Jun 27, 2009
  • 1705 Answers
SOURCE: printing 5x7 card stock in HP 1510 injet all-in-one printer
You need to set up your printer preferences to accommodate the type and size of paper you wish to use, usually listed under printer/print or page set up.
Invariably, paper is loaded, butted to either left or right of the paper feed, but on the other side of the feed there should be a sliding stop which keeps your paper in place.
If feeding from the top feed, print side towards you, if printing from a tray at the bottom of the printer, print face down.
You can download a user manual from here once you've chosen your model printer:-
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=+HP+PSC+1510&submit.x=11&submit.y=7
Posted on Apr 22, 2010
What are the custom wedding invitations is it worth paying?
hi
Wedding cards are the most important thing to consider when planning for inviting the guest to wedding functions. It solely decides whether the guests attending the function or not. these designer wedding invitation cards show your gratitude for them and importance of their presence in the function. custom designed invitations also come with the special quotes printed on them they are more effective then a normal wedding invitation. Last month my uncle ordered Wedding Invitations Card by Lavender Paperie.
They are most beautiful ones i ever saw. the design is so clean and beautiful with special message make it more attractive. Wedding Invitations Custom Laser Cut and Lace Wedding Invitations
Oct 21, 2017 | The Office Equipment & Supplies
I want to print my writting on a invitation and i dont know how to do it?
if you want to write on your invitation then use any program to do it like photoshop or write on your invitation first and then scan and print it
Apr 21, 2013 | Brother Mfc-j270w All-in-one Inkjet...
Where is list of those I have invited to FB I want to review status of the invitations
Go to this link: http://www.facebook.com/invite_history.php
Long way around:
1. login to your account 2. click "account" in the top right corner 3. select "edit friends" 4. on the left side of the screen select "invite friends" 5. if you look on the right, you'll see a "View all Invites" button, click it and you'll get to the link above and be able to see all your invites and their statuses
Hope this helps!!
Feb 16, 2010 | Facebook Computers & Internet
Printer says to re-insert paper face down.
You must have the default printer settings changed to "double-sided" printingor "print on Both sides".
Check in your printer properties: 'Right click' the printer icon. Select "properties", "Printing preferences", "finishing", un-check "print on both sides" (these options vary slightly by printer model, so just check around on the different buttons).
That's my best guess. :)
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Print 5 x 7 invitations on 3100
You need to adjust the paper size in page setup of the program that you are using to create the invitation. What program are you using?
May 19, 2008 | Dell 3100cn Laser Printer
Paper mismatch
Hi kingwa55,
I have an hp photosmart c4480 and was having the same problem printing wedding invitations. Same size 5.5"x8.5'. Im not sure if this will work on your printer, but this is what I had to do.
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print, properties,features, click the drop down box under sizing options.
Click more and scroll to the bottom and it should be there.
If your options are different then mine, I'm sorry for wasting your time.
Apr 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Print Size
you have to choose the paper type in the printer driver option wheather envelope or A4 paper see the preview before printing
Mar 22, 2008 | HP Deskjet 3915 InkJet Printer
Print 5x7 invitations on my 950?
Oct 04, 2007 | HP PSC 950 All-In-One InkJet Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
166 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
