Question about Cortelco 8150 Trendline Corded Phone with Lighted Dial & Hearing Aid Compatible (8150COLORVOE21F)
Handset tab broken on AT&T CL84209. Where can I buy replacement?
AT&T CL84209 spontaneously displays "line in use" with no dial tone After a period of time everything returns to normal
This is a good argument for buying the cheap $$ extra warranty. If you didn't, try taking it back to seller to see if there's anything they will do for you.
Nov 03, 2017 | AT&T Lands Phones
How can i deregister a headset from my vtech phone model#ls6475-3. Also, is there a limited to how many headsets you can register to the base.
You can deregister all of the handsets and then register each one again for the LS6475-3. Make sure that all of the handsets are out of the base and all chargers and that the phone and all handsets are in standby. Then press and hold Find Handset on the base. When the In Use light begins to blink, release the Find Handset button. During the seven seconds that the In Use light is blinking, press and release the Find Handset button. Wait for the deregistration process to complete (about 10 seconds).
If the process fails, you may need to reset the base. You can do this by unplugging the AC power cord to the base or by picking up a registered handset and pressing Talk/Flash. Then you can try again. These directions are on page 5 (page 8 of the PDF) of the manual for the LS6405 handset. The direct link to this manual is https://cdn-media.vtechphones.com/media/p/document2/products/%7BD6DAD9B0-4C1A-4882-93D9-04124A59B629%7D/LS6405_CIB_V5_20160805.pdf . Then check that all of the handsets are in standby and not on any charger before attempting to deregister the handsets again.
You can register 12 handsets to the LS6475 base, according to page 31 of that manual for the main unit: https://cdn-media.vtechphones.com/media/p/document2/products/%7BA37C95FC-053D-4D34-B60A-EA5ED42B056C%7D/LS6475-3_UM_4_925.pdf . If you use the cordless headsets, you can register 10 handsets and 2 headsets.
These manuals can be found through the product page: https://www.vtechphones.com/pd/1603/LS6475-3-2-Handset-Answering-System-with-Cordless-Headset . The base manual is in the section under the Support & Manuals tab. The handset manual can be found from the Accessories tab. Then click on the Support & Manuals tab after clicking the link for the Handset.
I hope this helps.
May 21, 2017 | Vtech Lands Phones
The tab that holds hand set is broken. Where can I get this?
I would try a thrift store, you may find an intact unit.
Feb 06, 2016 | Cars & Trucks
Gas door won't close.
You go to a dealers parts dept & buy the
broken spring,if that is what your asking about
Nov 07, 2014 | 2004 Honda Civic
Can I buy a new basket
Fold a piece of cardboard into the slot on the shredder. I had to do this on an office shredder I owned for years.
IMPORTANT: ALWAYS REMEMBER TO REMOVE the piece of cardboard ANYTIME YOU HAVE TO CLEAR THE CUTTERS &&& ALWAYS UNPLUG IT!
Aug 04, 2014 | Fellowes PS60C-2 Shredder
Where to but a handset tab for cl84209
goto alibaba.com. join up and then puit u r question on that web-site. lol.
Jul 22, 2014 | AT&T CL84209 19 GHz Twin 1Line Corded...
Broken handset
The weakness with the handsets was that women using hand lotion or hair gel can get it on the front of the keypad. It then works it's way to the back side of the rubber keypad. The oil gets on the powder carbon on the keypad. The Carbon shorts the copper on the phone to activate the #1 or #2, etc. When the oil mixes with the carbon the key no longer works. I replaced many keypads until Sony Supplies ran out.... A cheap home fix would be to open the handset and clean the #1 key and the circuit board. You can try the keys but if they don't have any carbon on them you can buy liquid carbon at Electronic Stores OR just paper punch a circle of alumimum foil. Glue the foil on the key with thin glue. Works....
AL
Jan 03, 2008 | Sony SPP-A2780 Cordless Phone System
Cortelco 8150 Trendline Corded Phone with Lighted Dial & Hearing Aid Compatible (8150COLORVOE21F) Logo
35 people viewed this question
Top Cortelco Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Cortelco Lands Phone Expert? Answer questions, earn points and help others
