Question about Broan-NuTone 1 Speed 70 CFM Exhaust Fan Motor and Fan Assembly
How to replace fan blade on nutone 696 exhaust
I cant get fan blade off motor assembly
  • 95 Answers
SOURCE: Replacement Motor for the NuTone LS80SE Ceiling Fan
https://www.centralvacuumstores.com/nutone/fan-motor-ls-series.php
Posted on Mar 02, 2009
Bat1956
  • 585 Answers
SOURCE: Bathroom exhaust fan 16 years old and noisy. How to fix?
One drop of 30 wt oil at each bearing will quiet the thing for a while, but you will eventually want to replace it. Also consider the whole fan is about the same cost as the motor, and easier to find.
Posted on May 16, 2009
digritz
  • 530 Answers
SOURCE: where can I get the motor unit to replace?
The motor is a common item to need replacement in bathroom vents. Replacements can be found just about anywhere that deals with electric motors. You might even be able to get a replacement where you originally purchased the unit. There are dozens of web sites that you can locate a replacement. http://www.electricmotorwarehouse.com is just one. Simply do a web search on replacement bathroom vent motors. Also if the are able to purchase items from wholesale vendors you can get one from Grainger's. It should cost around $20 to $25
Part # 62345-000 (replacement motor part #).
However there is an alternative to replacement. This depends entirely on how handy you are with these kinds of things and how bad off the motor is. If your not comfortable with repairing this kind of thing don't bother with the rest of this.
I hate to replace anything that may be repairable. Unfortunately my friends know this and recently one asked me to look at his NuTone bathroom vent motor before he replaced it.
For the cost in time of an hour I was able to refurbished it.
A good way to check if it's a candidate for repair is to check how much play is in between the shaft and bushings. If you can feel movement then it's best to go ahead and replace it. If the problem is that the shaft is tight and just hard to turn then it may just need some cleaning and fresh lubrication.
The steps are simple. Once you have the motor removed from the vent cage you will see a pair of nuts and bolts holding two brackets in place. These brackets(one on either side of the coil) are what hold the shaft centered and house the bushings. Remove the bolts and the brackets. Be careful not to lose any of the washers on the shaft. These are spacers and need to be replace the same way they went on if they come off. All you need to do is clean both ends of the shaft put a little oil on the shaft and in the bushing and put it back together. If the motor has a plug and not just bare wires for reconnecting to the power supply then it's safe to just plug it in to any outlet for testing after you remount it in the vent cage. You will know right away if you were successful.
Hope this helps.
Posted on Oct 16, 2009
hondo73162
  • 132 Answers
SOURCE: Fan does not work motor will buzz thats all. Nutone ultra quiet t
it may be that the bearings nead to be oiled, have you tried to spin it by pushing it with a pencil and see if it sticks or spins freely ?
Posted on Nov 07, 2009
rickzilla
  • 706 Answers
SOURCE: I installed a Nutone Bathroom Exaust fan/Light
Hello georod01,
Pretty simple problem and you have a few options.. first off.. If you take the fan/motor assembly out of the housing ( meaning : unplug the motor ... power off of course... and remove the sheetmetal screws that secure the mount that holds the fan/motor to the housing.....) You may have already done this... On some models, there is a set screw that secures the fan to the motor shaft.. you may be able to snug that up to stop the wobble... If the motor is OK and the fan is spinning but making contact with the housing.. It may not be centered in the housing so you may be able to better orient it..
If that fails to solve your problem, you can get a fan/motor assembly at home depot and either transfer it from the new bracket to the original ( if they are different).. or transfer just the fan blade onto the old motor... I think it costs about $8 - $12 for that and they are not usually easy to find but they do sell them...try the plumbing section...
As for suitability in an insulated area.. you should have no problems unless you put the wrong bulb size in the holder.. most of them have an over-temp cutoff sensor built in.. The fan motor is not much of a heat source... Hope that helps...
Posted on Jan 30, 2010
I would like to replace a Nutone 8663Rm series bath exhaust fan with a Broan 683L The 683L requires an opening of 8" X 8 1/4". Since access it is located in the attic, where it is unbearably...
You can buy a replacement motor assembly for that model.
http://vacuums-intercoms.centralvacuumstores.com/search?w=8663rmsa&af=type%3Aproduct&asug=&x=0&y=0
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=8663rmsa&Search.x=0&Search.y=0
Jun 16, 2011 | Broan-NuTone N-8663RMSA Combination Light...
Our exhaust fan is really noisy. Nutone QT 100N-B model. Where can we purchase a new one?
This model has been discontinued but replacement motor assemblies are available. There is no off the shelf model that will fit in the existing housing. If you do not want to replace the housing then the motor assembly is the way to go.
You ca purchase the replacement from either site below:
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0
Jun 07, 2011 | Broan-NuTone QT100L Fan
My model 8663RP "B"-Unit Combination
It sounds like the fan blade may be loose on the motor shaft. You can purchase a new motor for this fan online.
Look here: http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/S97017705-Motor-Assembly-.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=8663rp&Search.x=0&Search.y=0
May 02, 2011 | Broan-NuTone N-8663RP Combination Light...
My nutone qt-110n-b is louder than usual and I seem to have a loss of exhaust.
Sounds like you need motor replacement assemblies. take a look on amazon for it. Amazon com nutone qt 110n motor. Hope this was helpful. cheers
Mar 06, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
I purchased a reoplacemetn motor for my Nutone/Broan LS 100SE bath fan based on a reccommendation here. The new motor, part # 89169, came with five wires compared to the original motor's three. How do I...
The additional wires are for a starting capacitor, not included with the motor. The easiest way to hook-up is to order the Outlet Assembly p/n 88617000 (available at Coastal Tech Supply.) The assembly includes the capacitor, connector, and shroud; and will replace the existing outlet assembly in the housing. Minor electrical work is required to remove the old assembly and install the new one.
Mar 03, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
I have a Nu-tone 8663 RP Combo fan and light. The unit has been a great unit for a good number of years. The fan is shot. Motor bearings I think. How can I get a replacement fan assy. ?
I just ordered a replacement fan motor for this same exhaust fan. I got it from here, http://www.electricmotorwarehouse.com/aosmith/nutone/nutone1.htm
It's this one,
1.2 amps, 115 volts 60hz
1550 RPM; Shaft 1/4" x 1"
Rotation = CCW
3.3" Diameter Motor
2 Mounting Studs Opposite Shaft End
Motor Case Length 1 15/16"
2-Prong 115 Volt plug
For Model 8663RP, 8673RP
8664RP (86933-000)
86933000, JA2B104N, JA2B104
can substitute 99080517
Part # 86933
$43.95
It's on the first page, and the 8th motor on the page at the time of this post. Hope this helps!
Oct 20, 2010 | Broan-NuTone N-8663RP Combination Light...
My fan doesn't start right away when the switch is turned on. Then as it is starting up it squeaks and hesitates. Seems like a "gunked-up" problem but I can't remove the impeller blade assembly from the...
The fan blade can be removed from the shaft. You just need to pop the lock washer off and pry the fan blade. You most likely will not be able to remove the fan blade without damaging the blade. You can buy the replacement fan blades online. The part number is 5901A000. Here is a blog on the entire replacement motor assembly. http://nutoneproducts.typepad.com/nutone-products/2009/08/nutone-0695b000-replacement-bath-fan-motor-for-model-qt80.html
Oct 05, 2009 | Broan-NuTone QT80 Fan
May 16, 2009 | Broan-NuTone N-671R Exhaust Fan Exhaust...
Feb 28, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Noisy fan
We had our house built with the same Nutone fan/light units in all 4 bathrooms. Moved in in 2002. One of the units starting making a loud noise last month. I popped the plasic cover off the light, then carefully pulled out the bulb, then unscrewed the wingnut in the middle. That allowed removal of the light assembly. Then I had access to the blade and motor. I found a lot of dust had collected on the motor and blade. I blew most of it off with compressed air (like what you would use on a computer), then used an electronic cleaner on the motor, then wiped off the blade and motor with a clean cloth.
I then crossed my fingers and turned on the fan.... It worked! It was quiet again. I waited a week before posting this. The fan is used every day. It is still quiet today.
If it ever needs replacing, I saw that Nutone sells the motor alone for about $22, that's a lot better than replacing the whole unit for around $70.
Mr. J.
Nov 17, 2006 | Broan-NuTone N-769RF Combination Light Fan...
Dryers Logo
27 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
