Question about Rival 38601 Smart Pot 6-Quart
Burns contents overheats
Every tjme i used it burned its contents
  • 1 more comment
  • hisam67 Jan 23, 2009
    Taking it back and exchange it for another one won't work since we received it as a gift.What now?????
    Perhaps a customer service # would help.....I understand others who tried got the run around....
    The 800# you sent did the trick.Rival Consumer Services are replacing the defective unit at no cost...Thank You
  • 8,197 Answers
Turn down the temp or cut the cook time some.
Posted on Jan 23, 2009
  • Jyackle5
    Jyackle5 Jan 23, 2009
    Here is the 800 # for rival
    1-800-557-4825.
    Good Luck
  • Jyackle5
    Sorry gave the wrong # here is the right one
    PO BOX 3900
    Peoria, IL 61614
    Telephone: 1-800-323-9519
    Brigadier General:
  • 5,158 Answers
What are you cooking... just offhand less heat as it appears to conduct heat extremely well and use a bit more water..... just sounds like cooking with those requires more attention...
Robert
    President:
  • 2,559 Answers
You should take back to the place of purchase and have them exchange it for another one.
Please rate this solution.
Thanks
  • Randy Hough
    Randy Hough Jan 23, 2009
    PO BOX 3900
    Peoria, IL 61614
Can a pressure cooker's 'ceramic insert' be frozen / thawed?
Why not use a freezer bag for the spare food to store it in. Probably won't do any harm if thawed thoroughly before re cooking but I wouldn't do it.
Dec 05, 2017 | Crock Pots & Slow Cookers
How do I open the stuck lid on my Power Pressure Cooker?
The cooling food has caused a vacuum making it worse. If you heat the food very gently as not to burn the contents, the lid should open once it is hot. Release any pressure and try and open it again.
Jan 01, 2016 | Crock Pots & Slow Cookers
Vacum Cleaner has burning smell.
Have you checked the belt...if u dont have the instructions to locate the belt see the manufacturer's website.
Sep 05, 2012 | Crock Pots & Slow Cookers
On the dial there is off, low, high and auto. What does the auto do? If I select auto is there a timer on it that shuts the pot down after a time? Is fo what is the time.
There is no timer -- with the dial set to auto, a thermostat opens and closes turning the heating element(s) on and off to keep the pot at a fairly constant temperature. The high setting can continually boil the contents, and can burn the food if not stirred. The low setting is for keeping contents warm.
I'd use "auto", if the pot is not going to be monitored.
Charlie
Mar 27, 2011 | West Bend Crock Pots & Slow Cookers
HOW TO USE AUTO SETTING
It looks rather like my slow cooker which has a 3 position switch with LOW, HIGH and AUTO.
AUTO uses a thermostat control to prevent the contents from boiling. Useful if being left unwatched. HIGH setting can cause burning if contents not stirred, and LOW setting is only of use to keep things warm. Hope that helped.
Oct 05, 2010 | West Bend 84384 Slow Cooker
How can I remove burn stains from Corning Ware? It is on a teapot that burned dry.
Can you let me know if you found a solution? I was warming tea and forgot. Thanks. joe.packer@att.net
Aug 16, 2010 | CorningWare SC60 Slow Cooker
Food burned on pan
oven cleaner (one that can be used on cold ovens!(read the can)
Dec 08, 2008 | CorningWare Crock Pots & Slow Cookers
Burned pot
yes
a ceramic or clay pot is the only solution.steel is hopeless for casseroles
same as frying eggs in a steel frypan without the teflon coating
only true stainless steel is advisable
May 15, 2008 | Rival 38501 Smart Pot 5-Quart
Stop working, burned fuse
although unfamilliar with your particular induction cooktop.If you have a fuse thats gone bad, adn you replace adnthat fuse goes bad upon powering up, it sure sound s as if you have a dead short somewhere under there triggering it to blow. no wires touching any metal (fallen off terminals perhaps??))if not id start diconnecting power line leading to individual switches, perhaps a short within the switch if shorting out unit.
Apr 02, 2008 | Crock Pots & Slow Cookers
Rival 38601 Smart Pot 6-Quart Logo
20 people viewed this question
Top Rival Crock Pots & Slow Cookers Experts
Jerry Greenberg
Jerry Greenberg
tsalagi152
charles
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
