Question about Maytag MER5775Q Electric Kitchen Range
Nothing heats up on my maytag glasstop but the digital display
I can't cook on or in my maytag range but the digital display works, i can set the oven though it doesn't heat up. I made sure the lock is not on or delayed cook. i changed my fuses in the house just in case and still nothing
  • lauraluv67 Jan 25, 2009
    Thank you so much for your response. Yours is the first solution that makes sense for my situation!! I've scoured the net looking for a solution. No answers have applied. I'm waiting for my brother to come over with his volt meter, he's out of town for a few days. I'm a single mom, laid off work and need to see if we can fix this before I call a repair man. I will absolutely let you know how your solution works for me. Thank you, thank you, thank you.
    Laura
  • fritzy17 Feb 11, 2009
    I have the exact same problem..is there a breaker or fuse on the Maytag elec. ranges my model is CHE 9800bcbc. It all started when my oven element burnt out. I replaced the element as I have done on a previous occasion and when I reset the circuit breakers the stove lit up but none of the elements work? I will look at the wiring in the back of the stove before call a repair man.
    Sergeant:
  • 311 Answers
An electric range needs 220 volts for top burners and oven to work,if getting only 110 volt the display or clock will work.the most common problem i've found with your curcumstances is a burn't wire where the cord attaches to the range or if hard wired still the same place.pull out your range and inspect all wiring where range connects to house and where house connects to range.if ok take a volt meter and meaurse voltage there at cord area .if not 220 volt reading problem will be with the house.if yes 220 volts will need to trace out the range .then the problem at a place the cook top burners and the oven have in common,wire path wise.
Posted on Jan 22, 2009
Stove top works , oven does not
If the ignitor is not glowing to lite the oven then it needs to be replaced. Here is that part to order.
Whirlpool 74007498 Oven Ignitor AppliancePartsPros com
Mar 20, 2014 | Maytag MGR4452BDW / MGR4452BDQ /...
Cook top won't work and oven won't heat
check the plug it sounds like the plug is not secure only getting one leg of current push in firmly
Jul 29, 2012 | Maytag MER5775Q Electric Kitchen Range
The clock on the stove was flashing and now I can't get time set and the oven buttons don't work to put on broiler or oven. I don't know how this happened or how to correct it
hello,
You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thanks for using fixya
Aug 18, 2010 | Tappan TGF657 Gas Kitchen Range
The oven does not maintain the heat displayed. If I put cupcakes into the oven, or rolls, to bake at 350degrees, they are still not done after an hour and a half. The temperature displayed is what I have...
This sound like you have a faulty thermostat module. The digital temperature display is giving you a false reading. Your best bet is to purchse an in oven thermometer that will give you a more exact reading until the thermostat is replaced. Good luck and happy cooking.
Jul 21, 2010 | Maytag MER7662W Electric Range
Maytag Microwave apprears to work but does not cook
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101-==-
May 17, 2010 | Maytag MMV4205 Microwave Oven
Can I use cast iron on a glasstop electric range?
yes it is true, the heat transfer will be to great and will crack or explode the glass. definately not recommended.
Nov 08, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Stove control panel not working
You do not have a fuse or overload button on a Maytag cook-top. If you heard a pop, it was the touch pad on your control board blowing out.
Oct 22, 2009 | Kitchen Ranges
I broke the glasstop of my stove. Can I replace
http://www.partselect.com/Maytag-Stove-Parts.htm
just typ in your model number, and find the part you want on the diagram. you can purchase it through them, too.
Jul 31, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Gemini electric oven; glass top cracked
yes its not too difficult check your owners manuel as most ceramic cook tops are under extended warrenties from 5-10 years
Feb 11, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag range # MGR5775QDS
gas range, most common issue for extended cook time, long preheats, bad oven ignitor (it works but its slow to refire ) 75 dollar part servicer will get 175-265 depending wher you live
Oct 25, 2008 | Maytag Kitchen Ranges
Maytag MER5775Q Electric Kitchen Range Logo
296 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
