Question about Logitech Radio Communications
Can not connect to iPad - Logitech Radio Communications
How to pair JBL with iPad
Open settings on iPad Bluetooth scan for devices make iPad discoverable press and hold power button on jbl untill red and blue light flash look on iPad see your jbl press and done give that a try or try reverting to instructions if you still can't connect with iPad troubleshoot by trying to connect to Android if it connects to Android then retry with iPad and messing with Bluetooth settings or iPad may need an update check in settings general
Jun 21, 2018 | JBL Audio Players & Recorders
How do I connect my onn wireless mouse with my iPad via Bluetooth?
Unlikely that you can, because an iPad doesn't have mouse drivers. Your finger is the mouse. My thoughts confirmed here by Apple, you can't :>)
Can you use this to connect a mouse to the ipad? - Business - Apple
https://www.apple.com/.../question/answers/ipad/...connect-a-mouse...the-ipad/QUPAT...Jan 18, 2017 - Can you use this to connect a mouse to the ipad? I would like to connect a mouse to my ipad and was wondering how I could go about doing so. Also, could I get a wireless mouse for the ipad? Asked by ... No, iOS does not support a mouse interface. Answered by Samuel O from Alton; Feb 5, 2017; Flag as ...
Apr 24, 2018 | VIA Computers & Internet
Slim folio will not be found with new Ipad 6th generation, we followed the instruction and nothing happens
You have missed a step. Read again carefully
Connect the Slim Folio keyboard case to iPad
Before you connect your iPad 5th Gen to the Slim Folio keyboard case, make sure it's inserted correctly into the case:
Place your iPad so the camera lines up with the camera lens cutout on the Slim Folio case.
Snap the corners of the iPad into the holder to secure it.
To connect for the first time
The Slim Folio case doesn't have an On/Off switch. To turn on your keyboard case, open it and rest the iPad on the strip directly above the keyboard. The status indicator on the top right of the keyboard will glow green.
On first connection, your keyboard enters Bluetooth discovery mode and the status indicator will blink blue rapidly.
Go to the Bluetooth settings on your iPad and select Slim Folio in the Devices list.
If your iPad requests a PIN, enter it using the keyboard (not on your iPad).
Once the connection is made, the status indicator will turn solid blue. Your keyboard is ready to use.
To connect to a different iPad
If you've already connected the Slim Folio case to an iPad and want to connect it to another one:
Rest the iPad on the strip directly above the keyboard. This activates the keyboard. You should see the status indicator glow green, and then blue.
Press the Bluetooth connection button on the right side of the keyboard to make your keyboard discoverable.
Close
Apr 17, 2018 | Tablets & eReaders
I can't connect to ITunes
connect the pad to your computer and open iTunes, turn off the ipad, then hold both the lock and the home button for 10 seconds, then release the lock button while continuing to hold the home button until iTunes recognizes the iPad.
iOS Device not recognized in iTunes for OS
Jun 18, 2014 | Apple iPad Tablets & eReaders
How do I connect my Ipad to my windows laptop?
Install a copy of ITunes from Apples store on the PC.
This will interface between the pc and the Ipad.
Apple iTunes Download iTunes Now
Jun 16, 2014 | Acer Computers & Internet
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
I’m happy to help further over the phone at https://www.6ya.com/expert/jason_60e0f57ba319f3f6
May 05, 2014 | Kensington Folio Case Stand for iPad,...
How do I connect to Internet on my Ipad?
Two possible options:
Use Wifi to connect the iPad to your home wifi. Read this: iOS Connecting to Wi Fi
IF your iPad it equipped with cellular option (3G ,4G depending on iPad generation) you can insert a sim card with a mobile data plan to connect to the internet. Here are several reads for several providers:
Verizon How to set up new Cellular Data account on iPad
Sprint How to set up new cellular data account on iPad
AT&T How to set up and manage cellular data account on your iPad
Learn about cellular data settings and usage on your iPhone and iPad...
Apr 26, 2014 | Apple Ipad I-pad
IPhone deletes my contact names when I sync it to computer! Leaves the numbers, delete only names.
If you've set up automatic syncing, iTunes syncs your device by default whenever you connect your iPod, iPhone, or iPad to your computer. If you don't want iTunes to sync your device without being prompted, you can change this setting.
You can prevent unprompted syncing for any specific iPod, iPhone, or iPad; or for all iPod, iPhone, or iPad devices you connect to your computer.
To prevent unprompted syncing for a specific iPod, iPhone, or iPad:
  1. Connect your iPod, iPhone, or iPad to your computer.
  2. In iTunes, select your device (below Devices).
  3. Click Summary, and then deselect "Open iTunes when this Device is connected."
To prevent unprompted syncing for all iPod, iPhone, and iPad devices:
  1. In iTunes, choose Edit > Preferences.
  2. Click Devices.
  3. Select "Prevent iPods, iPhones, and iPads from syncing automatically."
    If this checkbox is selected, any connected iPod, iPhone, or iPad won't sync without being prompted.
To sync your iPod, iPhone, or iPad when unprompted syncing is disabled, connect your iPod, iPhone, or iPad to your computer, and then choose File > Sync "Device Name" in iTunes, or click your device (below Devices) and then click Sync.
For more information, see the iPod, iPhone, or iPad User Guide or the Apple Support website.
Dec 18, 2012 | Cell Phones
Comcast ipad wifi problem
I'm sure you've done this but try turning off wifi on iPad and then turning back on. Does your wifi name show?
Jun 17, 2017 | Apple iPad 32 GB 3G Tablet PC
Radio Communications Logo
12 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
