Question about Whirlpool LER5636P Electric Dryer
Dryer will not heat
Whirlpool electric dryer will not heat. breaker is not tripped on either leg. heating coil shows .009 resistance. what else control power to coil. i see abalist resister what should it measure.
  • 5,911 Answers
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Posted on Jan 22, 2009
Why wont dryer heat up after changing out coil ?
most dryers are 220. its possible your breaker is half tripped. try cycling the breaker.. you should get 220 across it while its running. (Be careful).
Sep 09, 2015 | Haier Dryers
LG electric dryer is not heating. Electric coils test for continuity. Any suggestions?
There are several things that can prevent a dryer from not heating. UNPLUG DRYER BEFORE TESTING ANYTHING.
1- power- Test the receptical to make sure you are getting 220 volts. To do this you need and voltage tester. Both legs should pull 110 and together 220. If one leg is not pulling any power than your breaker is half tripped. Reset breaker to cure your problem. If problem persist it is in the breaker or receptical.
2- cord- To test this unplug dryer. Take the panel covering the cord connections off. Remove cord entirely from dryer. Test each leg for continuity. If any are not showing cont than replace cord.
3- Themal fuse- To test this remove access back access panel on some front panel. By the blower housing there is a fuse white thin sliver or round fuse with 2 wires going to it. The one with 4 wires is your low limit cycling thermistat. The thermal fuse is near that. Disconnect the 2 wires and check fuse for continuity. If meter shows cont fuse it good. If not replace fuse.
4- Hi Limit Thermistat- test same way as thermal fuse. On the heating element housing at the bottom are 3 wires running to a fuse. Test the left and right. The bottom is attached to one of the sides.
5- Thermal Cutoff- Test same way as thermal fuse. This fuse is near the top of the heating elemnt above the Hi Limit. 2 wires with usually plastic covers on them.
6- Heating Element- Below high limit 2 wires. Test for continuity.
If all these fuses are good than you may need to call a technician. The motor may not be getting to the right rpm to activate the senfrigrial switch in the moter. Timer or control board may be out.
7- Motor- If
Jul 16, 2011 | LG DLE2514 Electric Dryer
Drum turns, air blows but element does not heat up. Circuit breaker panel shows one untripped double breaker for dryer. With dryer running can see 120v coming from control and passing thru sensors (1)...
The element will probably show near-zero resistance and be good. You need 220 volts from the breaker pair--check with an AC voltmeter--and at the two slanted blades in the power socket. If only one breaker in the pair is good, it can show your symptoms. Hope this helps!
Sep 25, 2010 | Whirlpool LER5636P Electric Dryer
Lightning strike power surge partially disabled dryer.(Whirlpool)
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Sep 29, 2009 | GE Profile Harmony DPGT750EC Electric...
No heat, 120 power to only one leg of heating element. The power was read on the side of the heating element that came from switches. I do not have a schematic, so it is hard to ttrouble shoot, not knowing...
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 31, 2009 | Dryers
Won't heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 20, 2009 | Whirlpool GEW9200L Electric Dryer
HAVE A 8 YEAR DRYER( Kitchen Aid)
I would be checking the service panel. I'm assuming the dryer has been working in that outlet. If the breaker is over 50 amps that is why it didn't trip. But the breaker may be bad itself. Make sure it is wired properly. Red wire should go on one side of the breaker and the black on the other. The white should go over to the neutral bar. Then make sure the outlet you plug into is wired the same way. (MAKE CERTAIN THAT BREAKER IS OFF) The top two prongs should have a red on one side and a black on the other, with the white at the bottom. If these are correctly wired, the problem is either in the breaker or inside the dryer. Depending upon the model you have, a 50 amp double breaker isn't prohibitively priced. If you buy the breaker, wire it the same, turn it on, plug in the dryer and it happens again, the dryer is at fault. Coils burn out inside them, lugs burn through, but I'd feel more comfortable at that point calling a service man, tell him what you've done with wiring, breaker, and outlets. It may be time for a new dryer.
Sirwriter
May 16, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will not heat but will run.
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 10, 2009 | Whirlpool LER5636P Electric Dryer
My whirlpool dryer has no heat. the drum turns.
Your issue is;
"my whirlpool dryer has no heat. the drum turns."
Based on the information provided above, I am unable to access my database to provide you with exacting information. A valid model number was not provided. However, I have provided some common solutions to help guide you in your search.
This information is for an electric, generic model dryer only!
My Solution is:
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
Temperature Switch; make sure a positive heat selection has been made, still no heat, then check these:
This link shows disassembly of a version 2 Whirlpool dryer:
http://www.repairclinic.com/0100_16.asp
Heating element
Thermal fuse
Wiring
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 23, 2008 | Whirlpool Dryers
Dryer problem
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Mar 11, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
