Question about Symbol Hotshot LS2106 Handheld
The scanners won't scan information after being programmed
The scanners are being programmed using the program sheets from the manuel. They are 'beeping' as they are being programmed. When I go to scan a barcode, no information is being entered into the field by the scanner. I have switched out scanners and cables, and the same problem reoccurs. I've checked the ports and all are enabled. What else sould i check?
  • Anonymous Mar 25, 2014
    My scanner beeps but won;t read barcodes. I put a new battery in the scanner, charged it overnight but to no avail.
I would scan default barcode again. If you are using PS2 connectors. Scan barcode for PS2 keyboard. And USB for USB connectors. Most likely it is not seeing the device. Or treating as a keyboard as it should.
Posted on Jul 06, 2007
SOURCE:
I DON'T HAVE manuel or codes, could you tell me how to program this bc60xlt-1 uniden hand held scanner
Detailed programming instructions are in the factory manual that you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Dec 10, 2010 | Uniden BC60XLT Handheld Scanner
Lost owners manuel. need code install instructions. and also how to clear off all old codes
There is no general reset function that will clear all of the frequencies (they're not codes) from your scanner, but there are two ways to clear individual frequencies:
1. Programming "0.0" (zero point zero) into a channel will remove the programmed frequency.
2. Programming a new frequency into any channel will remove/override the previously programmed frequency.
You can download and print the manual for your scanner, at no cost, here:
http://www.uniden.com/pdf/BC248CLTom.pdf
Bill B.
Nov 16, 2010 | Uniden BC248CLT Base Scanner
My boyfriend bought me the pro2054 scanner from radio shack and I lost the manuel to program it and I need help. THANK YOU
You can download and print your manual here:
http://www.monitoringtimes.com/html/Radio%20Shack%20Pro-2054.pdf
Bill B
Aug 04, 2010 | Radio Shack Pro-2054 Base Scanner
How do i turn off auto enter on my symbol ls3603mx scanner?
from manufacturers site take scan code sheet, you will just find there programming scan codes, one for start programming, another to terminate auto entry and third to terminate programming. that is correct procedure if scannig is automatically set in scanner, if scanning is in your database on other hand, you need to re-write that bit which insert your code to database/spreedsheet automatically and change it to manual, as i do not know which of these method you use, i cannot be more specific.
try scanner first! usually scanner is programmed on automatic.
Jul 20, 2010 | Symbol LS3603MX
How do I get my scanner to go to the next line/box when using Excel?
In your programming manual there is a barcode scan that needs to be scanned in that adds the carriage return function. To do this you will first need to scan the barcode to put the unit into program mode, then scan the carriage return barcode, then scan the end programming code. Now when you scan a barcode the scanner will add the return to the sequence it sends to the computer. If you can't find your programming book you can download the sheets from the Symbol web site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 14, 2010 | Symbol LS2208 Handheld
Epsom stylus DX74000
hi ..i have just used nine to scan ...i am no expert....but i went to the start button (bottom left on screen )....then all programs.....which brought up the epson scan icon then i just left clicked on that and the item was saved to my pictures folder
hope this helps
Terry
Oct 25, 2008 | Epson Stylus Multifunction Inkjet Printer/...
How to scan from dell926 printer
Hi here is the user guide for your printer
Download it here
http://support.dell.com/support/edocs/systems/prn926/en/ug_en.zip
How to Scan
Scanning Single-page Documents or Photos
  1. Turn on your computer and printer, and make sure they are connected.
  2. Load your original document or photo.
  3. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 926.
  4. Select Dell All-In-One Center.
    The Dell All-In-One Center opens.
  5. From the Send scanned image to: drop-down menu, select the program you want to use.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add the program to the list.
  6. Click See More Scan Settings to customize your scan.
  7. When you finish customizing your settings, click Scan Now.
Scanning Multiple Photos or Multiple-Page Documents note-dell.gif NOTE: Some programs do not support multiple-page scanning.
  2. Load your original document. For more information, see Loading Original Documents on the Scanner Glass.
    note-dell.gif NOTE: You can also open the Dell All-In-One Center from the operator panel on your printer. For more information, see Using the Dell All-In-One Center.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add your program to the list.
  7. Click the Advanced button.
    The Advanced Scan Settings dialog box opens.
  8. On the Scan tab, select the Scan multiple items before output check box.
  9. Click OK.
  10. When you finish customizing your settings, click Scan Now.
    After you scan the first page, a prompt appears requesting the next page.
  11. Place the next sheet on the scanner glass, and click Yes. Repeat until you finish scanning all pages.
  12. Click No when asked for another page.
    The program opens with the multiple pages scanned.
Oct 06, 2008 | Dell Photo 964 All-In-One InkJet Printer
Scanner & Printer All-in-one
PLEASE READ **CAREFULLY
Do you want to scan in a document or a picture?
If it is a picture, go to your photo program. Under FILE choose IMPORT then SCAN or TWAIN or your actual scanner (if it shows there.) Have your photo in the scanner ready to go and click on the above. This will scan the picture into your program and you can do any adjustments or cropping needed and "save as" where you want in your files.
A document can be a little more tricky because sometimes your existing document program( Word or whatever doesnt match the document format. However, on many scanners you can choose which program you want to open the document. If your document program will not open it, you can choose" word pad" and once it is there you can save it as an rft document then try opening again in your document proggy. There are many workarounds here to convert documents that didn't come from your program, but with a little patience it can be accomplished.
**Now that I have given you this information, I'll ask you. Do you have the scanner driver installed on your PC? If you do not you won;t be abl;e to scan anything onto your PC, however, you can go to the manufacturers site, click on support or downloads and download the correct driver for your scanner and operating system to your desktop. Be sure to turn off all running programs while you download and install. Once it is on your desktop it will be an exe file. Just click on it to install. Your scanner will then work with your PC and you can scan whatever you want using your programs to do it-picture or document. Good Luck to You.
Aug 10, 2008 | Office Equipment & Supplies
Want to program symbols p470 scanner to work with my existing program
I have a small inventory company. We do inventory in corner stores such as 7-11s. I decided that we would like to try scanning products. At present we use calculators. I have a program that my son-in-law made me. We use it in windows 2000. The company we work for really likes the way our program prints out there information, so I would like to program the scanner to print out information the same as our program. Do you think this is possible?
My son-in -law doesn't like me enough to help me out. I can't pay him like the government does for his job.
I know how to program applications for Symbol Scanners but... in your message above..
this is what you wanted??
Can you post a screenshot of the PRINTOUT you wanted?
Jul 09, 2008 | Computers & Internet
Symbol Hotshot LS2106 Handheld Logo
871 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
