Question about Samsung DualView TL220 Digital Camera
Samsung TL205 no enciende - Samsung DualView TL220 Digital Camera
Samsung TL205 Camera turns on but the screen never shows any sign of light. Screen is not able to display anything. Can this model be reset?
Many times you can turn the screen off in the menu up settings. Some cameras have a physical button on the camera to do so. Look your camera over carefully, and read the menu settings in your manual. If you don't have that, scroll through all your settings and see if you've turned off the LCD.
Oct 13, 2014 | Samsung DualView TL205 Digital Camera
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
My TL205 screen gets completely dark when i want to take pictures but i can see other things on it. I need help !
Reset camera Settings by the below procedure.
-Press the MENU button
-Use the left or right arrow keys to select the Settings menu (its icon looks like a wrench and hammer)
-Use the up or down arrow keys to scroll to the choice that says "Reset ALL..."
-Press the "Func./Set" button to confirm your choice.
Oct 19, 2013 | Samsung DualView TL205 Digital Camera
Can I get a print-out manual for the Samsung TL205/PL100 Digital Camera
You may download the manual here. You can print it out yourself, or most office-supply stores can print and bind it for you.
Jan 24, 2012 | Samsung Cameras
My Samsung TL205 digital camera will not turn on. The lens is out but when I press the power button, the green on button will light up then the camera will make one beep sound as the green light turns off....
I just fixed my camera. I pushed the lens inside completely. took the battery out and put it back in. turned it on and off a couple of times and ready to go!! good luck!
Feb 17, 2011 | Samsung DualView TL205 Digital Camera
When ever I try to turn on my Samsung Dual View TL205 the green light just goes on then turns off. I've tried recharging already do you anything that I can do to fix this problem?
Try switching on by holding the button for about 1 minute .WITHOUT ANY BATTERIES IN CAMERA. Then replace batteries and switch on normally. (this should have done a camera "reset").
Worked for me on my camera!
Jul 16, 2010 | Samsung DualView TL205 Digital Camera
Samsung DualView TL220 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
