Question about Philips SA5125/37 MP3 Player
Can not get my player to charge.
I hook up my player to the computer , how ever when i try to charge it nothing , its always back to where it was . when i unhook it , and i do leave it on long enough.
  • 11,896 Answers
Either your not using the usb+ (this means there's extra power in usb) or your battery is dead or short in player.
Posted on Jan 23, 2009
    President:
  • 2,976 Answers
Make sure your computer is turned on the whole time it is charging. OR If you have atelephone charger with the same type plug, it will work. A blutooth charger will do the job but it will take forever.
Buy a usb to mains adaptor works for me 5 pounds amazon . co
Posted on Jan 22, 2009
This van has the anti-theift component.....we go to town to the store lock it, go shopping we we re-enter the van it wont start a mechanic said it was the main computer gone bad what do you say?
i say the antitheft system probably was triggered when that happens it either wont let the vehicle start at all or it"ll start bt only run for 2 seconds try putting the key in and turning it to on and leaving it for ten to fifteen min if that dont work try reseting the computer by leaving the key in the ignition in the on position and first unhooking the neg battery cable then the pos cable then hold down breaks or horn to drain remaining charge all vehicles store even after battery is unhooked and leaving it for 15 to 20 min then take the key out and hook the battery back up and try an start it
Mar 19, 2013 | 1998 Dodge Caravan
Is there a computer rest button on a 2011 dodge avenger
no but if you leave the key on and unhook the battery then hold down either the horn or breaks to get the remaining charge all cars store even after the battery is unhooked to drain away when either the break lights stop lighting up or the horn stops blowing leave it unhooked with the key on for ten to fifteen min then take the key out and hook the battery back up that should reset it
Mar 19, 2013 | 2011 Dodge Avenger Express
The VEC0108BD has charged overnight, however, the recharge light still comes on when it is hooked to the car battery. Am I suppose to leave it attached to the battery?
If the battery is charged, you should unhook the charger. If you leave the charger hooked up to long it could possibly ruin your battery. If it is not charged you can leave it hooked up.
Jan 19, 2011 | Black & Decker Electrical Supplies
Sansa MP3 player not working
you should try to reset it...take the sansa mp3 player and take the 4 screws out of the back and then remove the metal casing...then take the battery out....leave the battery out and press the power button....after you do that put the case back on and plug it into your computer if that dont work i would take the back off and then the face plate off and clean all the internal compnets....soon i will have a video showing how to do that on youtube....check frequently... www.youtube.com/stonedfly2 i will have it up this weekend
Feb 25, 2009 | SanDisk Sansa e260 MP3 Player
MP3 Player no power
get a pin and press the little reset button in the back
May 10, 2008 | Coby MP-C7085 MP3 Player
Ipod new classic wont charge
It should still be under warranty. Take it back to apple and let them replace it for you.
Jan 22, 2008 | Apple iPod classic MP3 Player
Wont turn on...
Try resetting the MP3 Player. Turn it on, connect to your computer, press and hold the play button for 10 seconds and disconnect from your computer. wait 5 seconds and connect back to your computer. When charging always leave the MP3 player in the on position.
Dec 31, 2007 | Audiophase MDP-1 Personal MiniDisc Player
It won't turn on
Don't flip the switch to on. Just leave it in the down position and hold the middle button and it will turn on.
Nov 20, 2007 | GPX MW3837 MP3 Player
Nothing from amp
The RCA "plugs" should be in an OUTPUT of the radio (sometimes they are INPUTS, like for an MP3 player..). Go to Sears or somewhere similar and buy an inexpensive Multimeter. Set it to DC volts and place the black lead on the GND termunal of the amp. With the red lead on the BAT terminal you should read roughly 12 volts always. With the car running and radio on, place the red on the REM terminal and again you should see 12 volts. If not it's the wiring. If the voltage is 12 on both then the amp is likely damaged.
Sep 01, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Mp3 Player Won't Charge
wiggle your usb cord - I had to wiggle mine a bit where it plugs into the usb port in the computer before it was recognized and listed as a device in 'my computer'. only then did it actually start charging; if your computer is not recognizing it is plugged in, it may not charge.. when i finally figured this out, the actual charging of my 4 gig audiophase mps only took 10 minutes- previously i was trying to charge it for hours without any luck.
Aug 31, 2007 | Audio Players & Recorders
Philips SA5125/37 MP3 Player Logo
29 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
