Question about Coby Televison & Video
How to get audio out from coby TFTV3225T? - Coby Televison & Video
How do you put a video on the Coby MP620 [4 GB] MP3 PLAYER
You can put a video on the device using "Coby Media Manager". To install it:
1. Plug your device into the computer
2. When the Autoplay menu appears, select "Open Folder to View". If no Autoplay menu appears, then look for the device in My Computer.
3. Launch the "coby-cometlite.exe" file and follow the setup instructions.
4. Now you should be able to use "Coby Media Manager" to automatically convert and transfer videos to the device,
Mar 05, 2011 | Coby MP620 MP3 Player
How do I add audiobooks from windows media player to coby 300. Coby manager says it on there but coby player tells me no files.
Most audio books are Protected WMA files which this unit does not accept, you would have to convert your audio books to MP3 format for them to play properly on your MP300. Honestly, this unit isnt good for audio books as audio books break up into chapters, this unit has no sort order so your chapters would be out of order.
May 15, 2010 | Coby MP300 MP3 Player
Can't get music on coby
Thats probably because your music is protected Windows Media Audio files, try to sync an Mp3 file, this unit only reads MP3 or unprotected Windows Media Audio files.
May 13, 2010 | Coby MP305 MP3 Player
I tryed to connect coby speaker (model number - csp42) up to my olevia 337-b11 tv and i can only hear sound through the bulit in speakers in the front of the tv and not out of the coby speaker! the coby...
Does your TV have an Audio out? This is the only way that you can get signal to feed to your coby speakers and make sure that your coby speakers has an amplifier.
Apr 03, 2010 | Olevia LT37HVS 37 in. LCD HDTV
What outlets do I hook up to on the reciever and the tv for it to play on regular tv stations
Cable Box optical Digital Audio to Coby Digital Audio In. (This brings TV-related multi-channel and normal audio into the Coby so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the Coby on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
Mar 01, 2010 | Coby DVD938 Theater System
Video OK but no audio when use SD card on photo frame COBY DP702
Audio is probably recorded with different codecs, one of which is unsupported by your frame.
Mar 23, 2017 | Coby DP-772 Digital Picture Frame
No audio
You will only get stereo sound from that TV matched with that Coby instead of full surround sound, without purchasing additional equipment.
That Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
The manual for the Coby mentions a "Digital Decoder Amplifier," which would work. You would connect a digital audio cable from the area marked "Coaxial" on the back of the Coby to a digital audio IN on the back of an external amplifier. You would connect the speakers to this amplifier, instead of directly to the back of the Coby. Then you would need a cable or satellite box with digital audio outs (fairly common nowadays) to another digital audio IN on the back of the amplifier. The cable or sat box you may have already, but you may need to purchase such a "Digital Decoder Amplifier" or other digital amplifier with appropriate speaker wires and 2 digital audio input slots (not to mention two digital audio cables). Fairly complex. Possibly expensive.
-Tha Mp3 Doctor
Feb 20, 2009 | RCA Audio Players & Recorders
Can't get surround sound for tv shows
The coby dvd 988 has 2 rca audio input jacks, you need to have these connected to your TV AUDIO OUT jacks, these are usually colored red and white like right and left stereo jacks, be sure to set up the TV for AUDIO output through these connections, some tv`s require that the internal built in speakers are cancelled and the audio output jacks are enabled. Set the coby input signal to receive the port you pluged the tv signal into.
Feb 06, 2009 | Coby DVD-988 Theater System
Question: how do you connect to a cable box?
-Tha Mp3 Doctor
Jan 31, 2009 | Coby DVD-937 5.1 Channel DVD...
Televison & Video Logo
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
