Question about Epson Stylus NX130 All-in-One Printer
What's your problem?Attempting to connect to a different device from that specified in the driver. Check the driver settings and the device.
2 Suggested Answers
  • 4 Answers
SOURCE: Epson Stylus CX9400 driver settings
Not sure how you're removing the driver, but if you go to control panel device manager remove the printer totally as an option; reboot and then reload the printer. You also need to identify the remote printer in the print sequence or as your default printer in set-up (device manager). Hope this helps.
Posted on Jan 26, 2009
Scanning function is not working. Computer is connected - it prints to printer but when attempting to scan documents, message says operation is invalid - check computer connection.
It would be useful to know the device you are using. I will assume it is a common multifunction device.
Defragment your hard drive
uninstall your driver
reinstall your device driver from the supplier's web page
Oct 22, 2017 | PRINTER Office Equipment & Supplies
My printer is an MP620B (Canon PIXMA). On attempting to print, error code 6C10 is displayed. I've visually inspected the far right interior of the printhead area and see no jams or obstructions. ...
Check if the drivers for the printer are installed and working properly on the computer. All the devices which are connected to the computer require a set of drivers to be installed on the computer. If the appropriate drivers are not installed on the computer then the device will not work properly. To check if the drivers are installed and working on the computer, right click on My computer and select Device manager. Highlight the installed printer. If there are any caution signs then follow the troubleshooting procedure. If troubleshooting does not help then try and update the drivers for the printer and see if it works. quote.gif
Sep 23, 2011 | Canon PIXMA MP620 All-In-One InkJet...
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
I'm plugged in all the cable correctly (based on the manual) when i got to the 6th step when we have to make sure all the lights are flashing, the WAN lights is on but the light is in ORANGE color, i...
Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on.
Step 2 Disable any internet security software running on the computer. Software firewalls like Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, etc. might block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Note that in some cases just disabling the firewall/antivirus software may not help, you may need to uninstall and reinstall the software.
Step 3 Configure your internet settings. Go to Start > Settings > Control Panel. Double click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click to the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows.
Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.x range.
If you are attempting to configure a D-Link router, then make sure you take note of your computers Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1.
If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range.
To set your computer with static IP address:
Windows2000/XP: Control Panel > Network Connections > Local Area Connection > Properties > Internet protocol TCP/IP > Properties...
Windows95/98/ME: Control Panel > Network > TCP/IP protocol for your Network Adapter > Properties...
IP address: 192.168.0.2
Subnet mask: 255.255.255.0
Gateway: 192.168.0.1
DNS: 202.129.64.198 (or whichever your provider is using)
Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration. There are several more FAQs that cover the configuration of the different D-Link Gateways, Access Points and Print Servers.
I got this from their support page. Hope this works out for you :D
Jul 18, 2011 | D-Link Wireless N 150 Home Router 4Port...
CQ50-215NR wireless will connect to the router but no connection to internet using a DSL HTC modem. Two other computers (Laptop and desktop) can connect to the internet using the same wireless (router and...
First check the wireless card's driver ..download it from the support site and reinstall it ..just to be sure it is installed well ..After that take a look into teh router's security settings ..It may have the access restricted by MAC address ..and in this case only the mac addresses specified have access to the network ..Another thing can be the settings in the router ...be sure t does not have a limited number of connections ..to check that ..disconnect any other device and try just with this one ..and see if it connects ..
Also it may be added by mistake into exceptions on the router's firewall ..Check this too ..
To make any changes or checking you have to enter the router's settings by typing its IP address into a browser of the admin computer in the network .
If non of these are the cause..it my be a matter of frequency used..It may not be in the range of the laptops specs..or ..the laptop card may have a different band or so ..This can be adjusted also in the router's settings if it is capable ...
Jul 14, 2011 | Compaq Presario CQ50-215NR Notebook
My LG KE500 wont send photos to other mobiles - can you help
This depends on how you are attempting to send the files.
If you're using a bluetooth connection, be sure that both phones have a compatable bluetooth driver installed and turned on. Try pairing the phones first through the bluetooth menu on both phones, and secure the connection with a pin code.
If you're attempting to use MMS to send the pictures, be sure that both your phone AND the receiver's phone have a valid MMS package set up with their carrier. Check your MMS settings on your phone as well, making sure to set it up correctly (refer to your user manual or call your carrier to assist you)
If you're still having an issue, call your carrier, they will help
May 11, 2011 | LG Cell Phones
ON MY SLICK MP3 PLAYER ,WHEN PLUGGING IT INTO A DESKTOP , WHEN TRYING TO DELETE A CERTAIN FOLDER , A POP UP STATES .. ERROR DELETING FILE OR FOLDER , A BIG X THEN SAYS CANNOT DELETE FILE CANNOT READ FROM...
This sounds like you've got one of three things happening:
1 - Your USB cable is dying slowly. Over time connections become seperated within the cable. This causes data loss and all sorts of funny errors. Try a different cable and see if that helps.
2 - Your USB plug is malfunctioning or underpowered. If you are attempting to use a USB 2.0 device on a 1.1 connection, errors may prevent you from doing what you want to do. Try a different USB port, see if that helps.
3 - Your MP3 player has a setting somewhere locking files to the device itself. If windows tries to delete a locked file, you will receive an error. Browse through the manual of your device or the settings on the device itself and see if there's a lock or protection or USB mode somewhere.
Because you're getting the "cannot read from source or disk" error, I am strongly geared towards #1. Get yourself a new cable and see if that doesn't solve the problem.
May 04, 2011 | Audio Players & Recorders
Usb not working
Check to see if the USB device you are attempting to connect works in a different system (preferably one that has never seen that device before, perhaps check with a friend)
If it works without issue on the other machine then check the acer website for driver updates.
If it does not work, you either need to install drivers for that device or you have a defective device.
Mar 16, 2009 | Acer Computers & Internet
Jan 14, 2009 | Epson Stylus CX9400 Photo Printer
Imation atom usb driver vista
vista has this problem , see below webite
Error message when you try to install a new hardware device on a Windows Vista-based computer: "Windows encountered a problem installing the driver software for your device GET basis information
http://support.microsoft.com/kb/940199/en-us
Jun 06, 2008 | Electronics - Others
Epson Stylus NX130 All-in-One Printer Logo
162 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
