Question about Rheem Water Heaters
Rheem 30 gal electric 66x 30d e.c.o. reset button not popped out
Reset button not popped out;can not reset.
  • 1250 Answers
SOURCE: cant get my 50 gal rheem electric water heater to
There is 2 ways to do this.
The first way is to turn off the power. Turn off the incoming water (cold) to the heater. Go to a faucet close to the location. Turn off the cold water supply under the sink. Open the hot water side of the faucet. Allow any water to drain from the faucet. Make sure that the water coming out is not under pressure. You should be able to tell by how it come out. Easy, or forceful. Now go to the heater and open the bottom drain valve. The reason it does not drain very easy is because you have a vacuum. Similar to having a soda bottle full of water and turning it upside down. It will drain but it will "Glug" and drain slow. Opening the hot side of the faucet relieves the vacuum and it should drain o.k. When you are done with your repair, leave the hot side of the faucet open and turn on the incoming water to the heater on. Let it fill till you get a steady stream of water from the faucet. This "Burbs" all air out and ensures the tank is full prior to turning on the power. When you get the steady stream, turn off the faucet and restore power. In some cases, the heater may sweat because you are heating very cold water. This is normal and will only happen this one time.
Now if you want to know the second way, let me know. I've done it dozens of times with plenty of success and minimal mess.
Good Luck
Posted on Mar 06, 2009
  • 35 Answers
SOURCE: pop off valve dripping Rheem 50 gal electric valve at bottom
If you are reffering to the drain valve at the bottom of the hot water tank. It may be leaking due to the O ring being cracked or worn out. You can either drain the tank and replace the valve or you can buy a hosebib brass cap and thread it on the existing valve. There is no cause for alarm when doing this as this valve is just to drain the tank when replacing your hot water heater
Posted on Feb 25, 2010
SOURCE: i have a rheem glas standard 30 gallon model #
Look on label on side of tank.
Wattage of tank will be element wattage. This is true if tank has one or two elements since both elements are never ON at same time.
Simply go to hardware store and buy 3500W element.
Take phone photo to store if needed for identification.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Wattage appears on end of each element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/images/Voltage-printed-on-element-.jpg
Posted on Apr 08, 2011
  • 961 Answers
SOURCE: need to up water temp
The two blue rectangular cover plates, held on by two scews, cand be removed by taking out screws. There might be a little piece of insulation present when you pull off the panel, pull that out. You will see a pointer that is shaped kind of like an egg, pointing at numbers which represent temp in degrees. Start with the lower dial, this is your thermostat, Raise temp setting by 10 deg. Hypothetically, depending on what your present setting is, try setting lower thermostat at 130 and upper at 120. Your lower thermostat should be higher than the upper because of heat rising, it is more effecient and both thermostats don't have to be at the same temp. This will save you money in the long run.
Posted on May 25, 2011
SOURCE: I have a Rheem Marathon 105 gal. electric hot
Check 240 circuit breaker.
Open top cover on water heater and push in ECO red reset button.
If reset button will not reset, then replace thermostat.
If reset is not tripped out, then either upper thermostat is bad, upper element is bad, or water heater might be getting 120V instead of 240V.
If you have some hot water, then best suspect is lower element.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 26, 2011
I have a rheem 40 gal electric water heater. The GFI on the tank keeps popping do you know what could be causing this
10-23-12
Your tank has a GFCI circuit breaker?
Maybe you mean ECO reset button located on upper thermostat?
If GFCI circuit breaker is tripping, turn power off, open covers inspect for burned parts, and test elements. Copy following link for troubleshoot walk-thru:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
If ECO reset button is tripping, then replace both thermostats, and test elements.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Oct 22, 2012 | Water Heaters
I have a Rheem model 71-308. It only has a lower access panel. How do I access the upper heating element?
If your heater only has one access panel, then it only has one element. These are mostly in the 30 gal. electric models.
Oct 30, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a Rheem Marathon 105 gal. electric hot water heater. No hot water ....
Upvote the help.
May 26, 2011 | Rheem MR105245 Marathon Electric Water...
I'M NOT GETTING HOT WATER THE SYSTEM HAS POWER IS THERE A RESET BUTTON OR OL SWITCH ON A RHEEM TALL ELEC UNIT
There is a reset button located behind the top cover plate on the side. Remove four screws to remove cover and carefully spread insulation apart to access element,thermostat, and reset button. It is a small round red button. If you push it in and it stays thens the element should come on. If it pops right back out then you need to look at changing the reset.Thank you.
Mar 29, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a rheem glas standard 30 gallon model # 81sv-30d water heater with upper and lower watages 3500. how do i know what size heating element i need?
Feb 12, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The Thermostat does not reset!!!
Hi jamaica,the reset pops on tank/water tempature. The unit is overheating or the reset/saftey has become defective.Recommend replace thermo.
Mar 31, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Pop off valve dripping Rheem 50 gal electric valve at bottom
Feb 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
59 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
