Question about Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier
Dirt in the water tank.
I have the vicks vaporizer and i am want to find out y there is always dirt in the tank when i go to fill it???
  • 334 Answers
Its from the dust in the air.
It collects on the wet surface inside the humidifier and drains down.
A better air filter on your AC system would help reduce that, what type of filter are you currently using?
Posted on Jan 22, 2009
Where can i get a new water tank cap for vicks model V745A?
This is a POSSIBLE answer: I found the manual at the Vicks site, read through it, but it did not mention replacement parts at all. However, at the very end of the manual was this paragraph, which might serve as a way for you to get what you need. Quoting the manual:
If you have any questions or comments, call the Kaz Consumer Service Department at 1-800-VAPOR-1-2 or, e-mail consumerservice@kaz.com or, write to Kaz, Consumer Service
Department, P.O. Box 544, Hudson, NY 12534, explaining just how the product is operating. Specify model number. Our Consumer Service Representative will advise you how to correct the problem yourself, or will ask you to return the product for repair or replacement.
Aug 02, 2014 | Vicks Warm Mist V745A 1 Gallon Humidifier
Hi have a vicks warm steam vaporizer model v188. works great, just wanting to clean it. Can't find my manual anywhere.
The easiest ans simplest way to clean it, is too mix a 50/50 solution of White Vinegar & Bottled Distilled Water (enough to fill the tank) and fill the the tank with the solution. Allow it to set for 30 minutes, then turn the unit ON. Allow it to run, until the tank is half empty. Pour out the remaining solution and fill with the Bottled Distilled Water Turn the unit ON and run until the tank is almost empty. Following these instruction will remove all the lime and calcium build up in the unit.
Tip: Using bottled Distilled Water rather than Tap Water, will totally eliminate calcium and lime buildup.
I hope this helped you and thanks for choosing FixYa.
Aug 13, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I HAVE A vICKS VAPORSIOR AND HAVENT USED IT VERY OFTER THERES no STEAM COMMING OUT EVER I USE COLD WATER DON'T FILL ABOVE THE FILL LINE I ALSO CLEANED IT REALLY GOOD WITH CLOROX. aNY SUGGESTIONS???
The unit may simply has a calcium scale build up and it's blocking the water passage. To clean it, empty in water remaining in the tank. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water and fill the tank. Allow it to soak for at least one hour, then turn the unit ON. Place you hand in front of the misting nozzle to see if it's working. If you don't feel any mist, turn the unit OFF and allow it sit over night. If you do feel mist, allow it to run until the tank is 3/4's empty Turn the unit OFF, pour out the remaining solution and refill with Bottled Distilled Water. Run the humidifier until it's empty. This will flush the system entirely. In the future, I would recommend you use Bottled Distilled Water, instead of Tap Water. If you do, you won't have to descale the unit any more.
Hope this helped you, please let me know. Thanks.
May 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Do you fill with cold or hot water for vicks warm steam humidifier
im pretty sure you fill it with cold water...at least thats the direstions for when you use the vicks medicine you can add in...works great by the way
Feb 28, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I need to know how to use the warm steam vaporizer i lost the instruccions..
you add vicks petroleum paste/jelly at the top where the air vent is. Add 1-2 tablespoons of salt with tap water in the tank, plug in the unit and warm steam will produce.
Feb 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vaporizer That Works?
Have you tried adding salt to the water in the vaporizer? Sometimes the water needs to minerals for the humidifier to work...I add sea salt to mine every time I fill it.
Oct 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Aug 03, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier Logo
799 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
