Question about Garden
Garden pump , automatic pressure control unit appears to be defective
Been using this garden pump for 3 years.brand is icon 1000w model ic10001jfe. the pump should switch off when you release the trigger on the end of the garden hose. was working ok yesterday but today she's a kaput.tested the wireing,its ok up to the pressure control unit,beyond that nix. anyone got any clues?
  • 883 Answers
SOURCE: Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Posted on Jun 10, 2007
  • 22 Answers
SOURCE: pulsing and lost pressure
depending on amount of use i have found failures of the piston spring and retainer which are located inside main housing of pump,these cause pulsing and no pressure,you need to remove pump head and face plate to get to them,hope this is of help
Posted on Mar 30, 2009
  • 15 Answers
SOURCE: builds up to much pressure in hose and stalls engine
Sounds like the unloader is not working. try replacing it and see if that helps.
Posted on Apr 23, 2009
SOURCE: Pressure Washer Pump and Engine Stops Suddenly
The pump might be binding against the motor, causing the pump to overheat and temporarilly "seize up" and shut the engine off.
After cooling down for a brief period (5~10 mins) the engine can usually be re-started, but the overheating problem will keep coming back.
This happens when the pump either wasn't seated against the engine properly during it's initial instalation, or the pump housing wasn't machined properly and the PTO shaft is trying to drive the pump at a slight angle = excessive friction = overheating.
Try this:
1) Loosen the bolts that mount the pump to the engine just enough so that the pump can be wiggled slightly.
2) With the engine power switch in the "OFF" position, slowly pull the recoil starter rope so that the engine / pump completes about two revolutions. This helps to align the pump surface with the engine.
3) Lightly snug the pump mounting bolts in a criss-cross pattern, then slowly pull the recoil starter rope again to ensure that the pump isn't binding.
4) Finish tightening the pump mounting bolts in the criss-cross pattern (approx. 21 foot pounds torque).
The entire process should take you roughly about 10 mins from start to finish.
If this doesn't remedy your problem, then try running the engine for 20 mins with the pump COMPLETELY removed so as to isolate the components.
Posted on Sep 01, 2009
SOURCE: I have a brand new Lincoln pro mig 140. Took it
I'm having a problem with the wire feed on my Lincoln Pro Mig 140. The wire feed speed is not consistant. It seems to be slipping even though the tension is tight. Any solutions?
Posted on Jan 24, 2010
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
I need a fuse panal diagram for the 2013 VW Jetta, my 12 volt power ports are not functioning
Here you go. Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Data bus on board diagnostic interface
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Dual tone horn relay
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Radio/navigation display unit control module
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Jul 20, 2014 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
Fuse for the alarm system
Here is the full list of fuses for you! and for the car.
catalytic converter
valve,
change-over valve,
solenoid valve 1,
Fuel metering valve
solenoid valve 1
Fuel pump relay
Brake light switch
wipe relay (AW1)
Fuse 1 - Not used
Fuse 4 - Not used
Fuse 5 - Not used
Tail lights
Fuse 11 - Not used
Fuse 12 - Not used
Air quality sensor,
28-pin connector
ABS control module,
Light switch,
Fuse 17 - Not used
Tiptronic switch,
Fuse 21 - Not used
Converter box,
Alarm horn,
Alarm horn relay,
Light switch,
Fuse 27 - Not used
12 V socket,
12 V socket 2,
Blocking diode
A/C control module,
Fuel pump relay,
Fuel primer relay
A/C control module
Fuse 56 - Not used
Hope this helps
--N
May 31, 2014 | 2010 Volkswagen Jetta
Portercable Pressure Washer Model PCH2401
when the trigger for the wand is not pulled , there is a pressure relief valve that bypasses the water in the pump and so there is no pressure until the trigger is pulled again.
with the pump getting hot and not being able to pull the motor to restart, it indicates that that pressure relief valve has jammed ( faulty ) and the pump is running at full pressure all the time
That will heat the pump and stop the engine from restarting
That valve is where I would start looking for a problem
Apr 25, 2017 | Porter Cable Garden
Error 03 is displayed
Error 3 means that the unit cannot power on and control the air pump -the unit itself is faulty. The screen is totally blank that means that the control processor in the main unit had malfunctioned.
You cannot fix the defective unit. Time to replace a new unit.
Jul 26, 2011 | Lumiscope 1092 Wrist Blood Pressure...
I have a relativey new battery. Using the charger cable that plugs into the side port, not the docking port, the battery does not appear to be charging. If I take a picture the low battery icon comes up...
Hello, Well it sure sounds like you have a defective battery.I have several DX6490 cameras and have bought brand new batteries that were defective right out of the package !!!! MADE IN CHINA, need I say more ? Quality control is not one of their finer points,Try another battery from a different supplier there are many on E-Bay. This will probably solve your troubles.
Best Regards, Russell
Aug 16, 2010 | Kodak EasyShare DX6490 Digital Camera
High pressure issue
THERE SHOULD BE A PRESSURE REGULATOR ON THE PUMP YOU CAN ADJUST FOR MORE PRESSURE THIS COULD BE THE PROBLEM. ONCE YOU PRIME THE UNIT THE REGULATOR SETS ITSELF AND WHEN YOU PULL THE TRIGGER AGAIN THE SEAT AND SPRING MAY BE STAYING OPEN AND NOT LETTING THE UNIT BUILD PRESSURE
Aug 19, 2009 | Karcher 2500 PSI Pressure Washer
Pump spinning but not getting up to speed then shuts off
You have a pressurized system using a pressure tank.This is a case of an air logged pressure tank. Meaning there is more air than water in the pressure tank. The pressure tank must hold 2/3 water and 1/3 air of its total volume. Installed at the tank is the air volume control to take care of this proportion. Should the air volume control malfunction or becomes defective, the air-water ratio is affected. And then,
the pressure tank becomes either air logged or water
logged.
SOLUTION:
1. Shut the power off, and open the discharge line
gate valve to flush the water in the pipe lines.
2. Open the drain plug of the pressure tank to empty
all the water at the pressure tank.
3. Close the drain plug, and put the power on.
4. Start the pump, and set the flow control valve 1/4
open.
5. The pump will normally run.
Send your e-mail for us to know the results, and for
further assistance.
Jul 04, 2009 | Plumbing
How do I replace soap dispenser pump mechanism?
Our brand new Avalon model had this problem. It sure appears to be a design defect or defective part. After contacting customer support, they sent a replacement pump (the internal part, not the whole unit).
After removing the unit from your sink, holding the top pull firmly with constant pressure on the pump assembly. It will pop off, but you have to pull pretty hard.
I suggest running water through the top of your unit before putting the new pump assembly on it. Ours had black 'junk' inside even though it was brand new. The new unit just slides on in the reverse process of removing the old one.
Oct 30, 2008 | Price Pfister Marielle Kitchen Faucet with...
Saving money
you can use Solar Pumps: Solar-powered pumps perform well in climates with a great deal of sunshine and save money by not requiring an outdoor electrical outlet. Solar pumps also work well if your fountain is located a distance from the power supply. However, flow rate is minimal compared to typical voltage
Aug 27, 2008 | Little Giant APCP-1700 Swimming Pool Cover...
Garden Logo
189 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
