Question about Kenmore 43142 Front Load Washer
Kenmore front loader
Small screw (from a pocket!) now rolling around between the drum and the tub. Panel/hose have been removed. Can hear the screw but can't see it or reach it. Any suggestions? (Besides check the pockets next time!)
  • 5,911 Answers
There's no easy way of getting something out of between the tubs without removing the rubber door seal from the tub. It's a pain in the rear to get it to go back on too, because of the retaining spring that holds it in place. Are you sure the screw is between the tubs and not stuck behind one of the was tub fins? Most small items like screws will eventually find their way into the drain line and get caught in the drain pump strainer. Since you can't see the screw, it may actually be trapped behind one of the fins. One way of knowing is to roll the inner basket with one hand and listen. If you hear something rattling around it's somewhere in or on the inner tub. The outer tub (or shell) does not move. You can also look through the inner tub holes with a flashlight while turning it slowly to see if you can see anything between the wash tub and shell. Usually, water and gravity will force anything lying in the tub shell into the drain line. Let me know if this helps you.
Posted on Jul 07, 2007
SOURCE:
Kenmore HE2Plus washer. It sounds like a pin or other metal object may have fallen through the holes of the drum. You can hear it roll around when you spin the drum. Is there any way to remove it without...
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 18, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore elite HE3 elec dryer, model # 11082826101,has a loose piece in the dryer drum, how do I take the top off to fix it?
There are three screws that hold the top panel in place in the rear of the dryer. Remove these screws and the panel will slide back, then lift off. You should have access the outer perimeter of the drum, control board and control panel.
If you need to access the dryer bottom cabinet, remove the lower toe panel directly below the door. The panel comes off by removing the screws under the bottom front edge. With the screws removed, the panel will drop down and then come off.
NOTE: Propping the two front feet of the dryer up can offer better access to the toe panel screws ( a section of 2x4 works well for this).
There are some helpful exploded view diagrams you can use for reference at these following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Small items (like coins) can often get caught in the dryer drum baffles. They come off easily by removing the screws that hold them on place around the drum perimeter.
CAUTION: Make sure you UNPLUG the dryer before servicing anything inside the cabinet. Dangerous voltage is still present even with the dryer turned off.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Oct 14, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Roper washing machine the drum is loose and makes lots of noise
remove the drum unit and check out as follows: Remove top panel. Most of these have front controls, so the screws on the top back allow the whole top to come off easily, remove the screws and pull the cover forward. If the dryer is mounted on top of the washer, remove the dryer off first. Remove the 2 lower screws on the front panel, pull kick panel down and off. Turn off the hot and cold water taps and remove back panel.
2. Loosen two screws that hold weight on back half and slide out weight.
3. Remove drive belt. Cut wire tie, unplug motor and leave wiring in the bottom of the washer. Remove 4 screws/bolts that hold on motor and remove motor
4. On front right, loosen screw and remove rubber drain trap from tub. Squeeze large snap ring and remove water level sensor ( thing that looks like an old fuel filter ) from rubber drain also. Remove little hose from top of water level switch also. ( NOTE: You can also disconnect the level switch hose at the top of the washer. This will make it easier to re-connect, however you'll need to be careful that you do not damage the hose when you remove the tub assembly ).
5. At this point, you might want to remove the motor control board and pump motor assembly. Each is secured by 2 screws and are easily removed. This will prevent accidental damage and give you more room inside the washer to work with. There are 2 connectors on the control board and 1 on the pump motor � be sure to remove those first.
6. Shocks, push the lock tab to allow the pin  to be slid out of the tub and the shock will be free from the drum. ( picture help one and picture help two )Push pins through to the rear and remove. The baskets will now be hanging from the springs.
7. From top, twist out the tube from top of the outer tank. Place support under drum. I use 2 blocks of wood.
8. From front, carefully cut the glued spots where the door seal is glued to the front panel and remove the fill spout holder clip. The tools used is a piece of copper tubing flattened down. I use a wire tie to reinstall as the metal clip can be a pain to work with!
9. Drum should just be hanging from 2 large springs. Remove the clips/spring holders that go over the top of the springs so they can be lifted and removed from the washer. Start on either side, lift spring, move toward center and lower to disconnect drum from the frame. Completely remove spring. Repeat on the other side. Drum should now be sitting on the supports.
10. From above, lift drum and slide out the rear. Leaves you with an empty cabinet.
11. Lay drum on front face on a blanket or sheet and start to remove screws that hold halves together. Once all screws are out, the back half with pulley (top half if sitting on face) easily lifts up from the other half.
12. Remove and replace tub gasket seal. New seal will appear thicker than old one. The old seal can be picked out with a small flat screwdriver.
Assembly.
13.  Place supports in bottom of washer. Lift and slide drum back into place on top of supports.
14. I use a zip/wire tie to go around the water fill tube where the spring clip was and then cut the leftover tail off of the zip/wire tie. I remove the 2 screws holding the plastic hose in place to make installing the wire tie easier. Push the rubber boot over the plastic hose and use the wire tie to secure the boot to the plastic hose. Helps to install drum support springs (big ones on top) first.
15. Install safety clips back over springs. Glue the top hose back into place.
16. Front assembly reverse of disassembly.
17. Back and Motor assemble reverse of disassembly.
18. Finally, pull the boot over the front of washer. Don't do this until drum is in fully, or the boot might not end up on straight and might twist a bit. Small spots are re-glued again in place, super glue works well for this.. Spot glue at the 12 o'clock, 1, 2, 3, 4, 5, 6, 7, 8 and 9 o'clock positions around the opening.
19. Put on back and top.
20. Run load, check for leaks. Note: back panel is structural and should be on for a load to be run.
21. Should be done. Total time 3+ hours. I hope this helps anyone who has to get into the Frigidaire -Kenmore ( 417.###### ) front loader and replace the seal/tub bearing&shell or inner basket.
Bearing and Seal notes:
Tips for removal / replacement of inner tub....
1. After removing the back panel and drive belt, remove the pulley from the shaft. The bolt is removed easily, but we often have to gently pry around the base of the pulley to remove it (unless you have a puller). The pulley is very light and the metal is soft, so be very careful that you do not damage or bend it while prying.2. The inner tub will lift out once you have split the outer drum halves.
3. Remove the 3 tumbling fins from the old inner tub. The new tub will not include these, so you'll need to reinstall the old ones. They are held on by one or to screws each. *Careful* of the outside of the wash basket as it is VERY sharp!!
May 07, 2009 | Roper Washing Machines
Drum does not rotate once machine turned on
remove and check the drum gasket: Remove top panel. Most of these have front controls, so the screws on the top back allow the whole top to come off easily, remove the screws and pull the cover forward. If the dryer is mounted on top of the washer, remove the dryer off first. Remove the 2 lower screws on the front panel, pull kick panel down and off. Turn off the hot and cold water taps and remove back panel.
Assembly.
May 07, 2009 | Washing Machines
Having trouble dismantling the motor / gearbox from the tub base of a 7244E washing machine, to replace the drive coupling. I have the 3 mounting screws out but can't withdraw the motor/gearbox assembly...
Assembly.
May 07, 2009 | Whirlpool Washing Machines
WASHTUB PROBLEM
Assembly.
Change is moving around under the tub how do I get it out
1. Bring Band-Aids, Frigidaire seems to leave many sharp edges!! Remove top panel. Most of these have front controls, so the screws on the top back allow the whole top to come off easily, remove the screws and pull the cover forward. If the dryer is mounted on top of the washer, remove the dryer off first. Remove the 2 lower screws on the front panel, pull kick panel down and off. Turn off the hot and cold water taps and remove back panel.
Assembly.
May 06, 2009 | Frigidaire ATF6000ES Front Load Washer
A small screw fell through a hole in drum and is scrapping on the
the rear tub.
and tub assembly.
Apr 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer (He3t) front load
The bearing in the duet is attached to the outer rear tub of the washer. You have to remove the whole rear half of the outer tub. Take off the back and you will see all the screws around the tub where they attach together. you have to buy the whole rear half too. They wont let you replace just the bearings.
Nov 18, 2008 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE SMART WASH QUIET PAK 4 FRONT LOADER,
Now this is a drain issue from the pump, clean out or check drain hose position to make sure hose isnt in water. Front loader right? kick panel under door has two screws, 1/4 or Torx T20 will remove them. You will see a clean out screw handle that holds junk. Use a trash bag wrapped around the clean out to catch water and debris..
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 43142 Front Load Washer Logo
82 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
