Question about Computer, Chip, Cruise Control for Daewoo Leganza
No power to the coil on my daewoo
Timing belt is not broken. car was running good turn it off and it want start, no fire to spark plugs. just but a new coil pack on before this happen. took the coil pack back and had it replace with no success.
    New Friend:
  • 60 Answers
Are you getting fire from the Coil if so check the, Plug wires, Plugs, Make sure your coil is powering up/getting power trace it from there!
Posted on Jan 22, 2013
2001 dodge stratus will the coil pack spark if the vavles are bent
if your valves are bent ,then i take it your timing belt has snapped .which means your camshaft can not turn ., so you can not get a spark at the plugs.if it was the old distributor you would have been able to check the coil with a spark plug tester the trouble is with a coil pack it is controlled by both sensors and your ECU but due to the camshaft not turning so your camshaft position sensor can not tell the ECU to fire the coil pack.
Mar 25, 2015 | 2001 Dodge Stratus
Daewoo tacuma Just changed my spark plugs and HT leads now enging runs rough and stalls on idle
CHECK YOU FIRING ORDER, YOU MIXED THE IGNITION WIRES, IF IT IS A 4 CYL, FIRST CYLINDER #1 IS NEAR THE BELTS, CHECK COIL WIRES FOR NUMBERS, OR DISTRIBUTOR CAP FOR CYLINDER NUMBER OR COIL PACK FOR CYL #, AND FOLLOW THE WIRES TO THE SPARK PLUGS. MAKE SURE THEY ARE RIGHT, NEXT TIME DO ONE PLUG AND ONE WIRE AT THE TIME.
May 22, 2014 | Cars & Trucks
1993 Nissan 300zx: Number 4 cylinder doesnt fire.
Please read about misfire diagnosis and repair here.
Oct 01, 2012 | 1993 Nissan 300ZX
I've 1995 eagle talon esi non turbo 2.0 dohe I was driveing it and it stooped running it will turn over but won't start what can Ido
check the timming belt. it sounds like you have broken the timming belt remove the belt cover and make sure that the camshafts are turning when you are cranking the engine, if the belt has broken you will most likly have to remove the cylinder head and replace all the valves, when this engine brakes the timming belt the valves will hit the top of the pistons and bend the valves...good luck
Dec 30, 2011 | 1995 Eagle Talon
No spark & it isnt the coil pack
if the engine turns over but wont fire when you turn the key it is possible that the timing belt has broken. when that happens it will turn and turn but never start.
Mar 20, 2011 | 1996 Dodge Grand Caravan
My husband did a tune up on my car yesterday and now it wont start it will turn over like it wants to start but it wont he said that its miss firing we have bought 3 new coil packs and still will not start...
If your car is miss firing and your husband changed the coil packs,the wires leading from coil packs to sparkplugs must have got crossed.This will change car timing which will result in the car miss firing.He needs to go over wiring and correct problem for car to run right.You can go online to autozone.com and type in Info about car to get the correct wiring layout.Your problem isnt the new plugs n wires.Its the wiring layout.
Feb 09, 2011 | Pontiac Grand Am Cars & Trucks
Car will not start.Engine turns over but spark plugs willnot fire
I would say replace ignition coil, that might me the problem, otherwise it can be the ecu, which might have some electrical problems not allowing the car to stay running. Good luck.
Dec 29, 2009 | 1997 Eagle Vision
I have a 91 cutlass supreme that will turn over but it will not fire...where should i start looking??? different ppl tell me diff things i keep hearing coilpacks,ignition, and some modular thing!! plzz...
Are you getting any fire to the plugs? It could be the coil, ignition module, or even a broken or slipped timing belt. How many miles does the car have? Have you had starting problems in the past, or did it just stop working suddenly?
Dec 13, 2009 | 1991 Oldsmobile Cutlass Supreme
Computer, Chip, Cruise Control for Daewoo Leganza Logo
87 people viewed this question
Top Daewoo Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Daewoo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
