Question about Lexmark X5070 ALL-IN-ONE InkJet Printer
Change cartridges lexmark 4432-001 - Lexmark X5070 ALL-IN-ONE InkJet Printer
I dont know how to change the ink cartridge on my lexmark?
For more detailed instructions on how to change/replace the ink cartridges in your Lexmark printer, please refer to the Lexmark X5650 User's Guide. Turn to page 111 - Maintaining Print Cartridges.
I hope this information has been helpful.
Nov 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
I changed the toner on my Lexmark E250dn and now it has the "!" light on all the time and won't print. It's a new cartridge what is going on?
"!" means error.
Try removing cartridge and installing it again and might be one of the cartridge missing.
Try operating manual. Might helps, there are lots of reason for the error
ftp://ftp.lexmark.com/depot/LXK/E250_Depot_Repair_rev092606.pdf
Suspected
Follow the link on dispute about wrong cartridge due "Toner cartridge region mismatch"
http://www.techsupportforum.com/hardware-support/printer-support/379157-lexmark-e250dn-amp-quot-toner-cartridge-region-mismatch-amp-quot.html
Hope this helps
May 21, 2010 | Lexmark E250dn Laser Printer
Lexmark x85 multifunctional, not recognize cartidrige color
The cartridges are only installed through the printer itself and there is no installation of cartridges through the Lexmark software. You should ensure the Lexmark X85 has the cartridges installed in stand-alone mode. To do so, please follow the steps given below:
1. Push the "Menu" button 10 times, until "Maintenance" appears.
2. Then hit "Select" and "Change Cartridges" should appear.
3. Hit "Select" again. It will prompt you to open the lid and change the cartridges. Please do so.
4. When the lid is closed, the display will ask you if new or old cartridges were installed. If new, it may ask you to align the cartridges and you should do this too.
If it is not noticing a change, remove and reinsert the cartridges about 3 times in a row to re-establish pin connections. If this still presents you with a "Change Cartridge" or "Low Ink Level" message or something similar, try a different cartridge.
Oct 17, 2009 | Lexmark X85 All-In-One InkJet Printer
Change Cartridge Invalid Cartridge
First, Lexmark does not now or ever support the use of a third party cartridge or a refilled cartridge ink cartridge even if it is a Lexmark cartridge. Lexmark considers this to product tampering.
That said, please get a new Lexmark cartridge that is designed for your model of printer and see if it works. If you still get the failure, use a lint free slightly dampend cloth to wipe the contacts where the new cartridge goes. If that does not work, call Lexmark Technical support and see if there is still any warranty left on the printer.
Worst comes to worst, you can just replace the printer given the cost of ink jet printers nowadays.
Don
May 29, 2009 | Lexmark T612 4069 Printer
Lexmark Cartridge Error
Are you using a Lexmark factory new cartridge? If not then please try a Lexmark factory new cartridge.
Lexmark does not support the use of third party cartridges or refilled cartridges. Lexmark considers this to be product tampering and will void the printer's warranty if damage occurs because of the OEM cartridge.
Please don't shoot the messenger for giving you bad news. It is the truth!
Don
Apr 14, 2009 | Lexmark X4650 InkJet Printer
Lexmark x5490 Right /left cartridge incorrect
If you brought new cartridges and printer detecting it empty ,then you get it
replaced as the Lexmark cartridges comes with a 6 months warranty ..
Good luck....
Feb 13, 2009 | Lexmark X4530 InkJet Printer
Changing the ink cartridge.
I am going to assume that it is a X83.
Here is the link to the user manual. A detailed explanation with pictures starts on page 17...
http://www.lexmark.com/publications/pdfs/x83/engui.pdf
Jan 21, 2009 | Lexmark X6170 All-In-One InkJet Printer
Cartridge error on printer lexmark x3650
If cartridges are not original or are refilled, use new original cartridges.
If the cartridges are new and original, try cleaning the metal sensor inside the cartridge carriage.
If still no luck , contact Lexmark using the number listed on the owner manual.
Contact Lexmark -- Lexmark United States
Contact Lexmark -- Lexmark UK
Customer Support - Lexmark
Jan 02, 2009 | Lexmark X3650 Printer
Lexmark says inncorrect cartridge
chage both the cartridges as u have changed 1 also change another as its not getting detected.
Dec 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5070 ALL-IN-ONE InkJet Printer Logo
69 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
