Question about Clover Corporation CDR-4070 Video Recorder
Trying to connect dvr to my laptop
I connected it to my laptop did config and admin password then it pops up a window cant find dvr
How do I down software to my I pad
Posted on Aug 31, 2011
  • Midnigh Aug 31, 2011
    Need software were can I find it
Did you enter proper ip or url in configuration . when cldvr v 101206 opens ther is config button u click that enter same ip adress of dvr. this dvr ip adress you will see in dvr system ip configuration. that ip you have to eneter in config button and than click connection button and eneter passowrd admin and there you go
Posted on May 17, 2009
  • Bill Collier Nov 07, 2010
    Were you connecting your Clover DVR directly to your laptop? If so, make sure you use a crossover cable not a straight through cable. If you want to connect directly (not through a hub), I was given the following instructions for Windows XP (which worked for me) from a technician at the company as follows:
    “... you will need to have a crossover network cable. You can purchase the cable from a computer store.
    Once you have the cable, connect the DVR to your computer then oo to "START" and select "Control Panel". A new window should open on your desktop.
    In the new window, select "Network and Internet Connection" (category view) then "Network Connection". Or if you have classic view, simply select "Network Connection"
    In the network connections window, you should have "Local Area Connection" icon. Right-click on the icon and select "Properties". Another window will pop up on your screen.
    Select "Internet Protocol (TCP/IP)", and then click on "Properties". A new window will pop up on your screen.
    Select "Use the following IP address", and put in the following information:
    IP address: 192.168.1.100
    Subnet mask: 255.255.255.0
    Default gateway: 192.168.1.1
    Once you're done, click "OK", close all other windows, and go to your DVR unit.
    On the DVR, press "SETUP" button to bring up the setup menu.
    Select "SYSTEM" and press "ENTER".
    Select "IP Configuration" and press "ENTER".
    Use the enter button and arrow keys to input the following information:
    IP MODE: STATIC IP
    ADDRESS: 192.168.001.150
    SUBNET: 255.255.255.000
    GATEWAY: 192.168.001.001
    PORT: 5700
    Once you're done, press "ESC/STOP" 3 times or until you're back to camera view. And go back to your computer.
    You must have the DVR software installed in your computer. Once done, open up the DVR software (CLDVR).
    Click on "CONFIG", a new window will pop up on your screen.
    Put the following numbers into IP/URL section:
    192.168.1.150
    Once done, click "OK", the config window will close.
    Click on "CONN"; input the password (default password is "admin"). You should now be connected to your DVR.
    In our software, you can turn on or off recording, search/playback saved videos, and change record settings.
    (Thanks to Jamie for the help!!!)
Sannce DVR-DH81NK1T i am lock out need code or password
Connect dvr to local network
boot up the dvr
connect to local network with a computer (eg Mac)
login into admin screen of your router to identify the assigned ip address of the router
start a terminal session
telnet to the ip address
default user name : root
default password : xc3511
mbaad@MBAADs-MacBook-Air:~$ telnet 192.168.0.3
Trying 192.168.0.3...
Connected to 192.168.0.3.
Escape character is '^]'.
YourCCTVDVR login: root
Password:
BusyBox v1.16.1 (2014-12-24 15:47:14 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
Welcome to Monitor Tech.
[root@YourCCTVDVR /]$ cd /
[root@YourCCTVDVR /]$ ls
bin etc linuxrc proc share usr
boot home mnt root slv var
dev lib opt sbin sys
[root@YourCCTVDVR /]$ cd mnt
[root@YourCCTVDVR /mnt]$ ls
custom dvs logo mtd usb web
[root@YourCCTVDVR /mnt]$ cd mtd
[root@YourCCTVDVR mtd]$ ls
Config Log
[root@YourCCTVDVR mtd]$ cd Config
[root@YourCCTVDVR Config]$ ls
Account1 StorageCfg network
HvrMode SysComs ppp
Json SysTime resolv.conf
RT2870STA.dat dhcp.cfg uboot_env_lang_video
There will be an Account## file for each account you have set up
Remove all of these files
[root@YourCCTVDVR Config]$ rm Account1
Reboot your dvr box and it is at the first setup screen
Here are the commands - note you can't send password as part of the telnet command
telnet 192.168.0.XX
root
xc3511
cd /mnt/mtd/Config
rm Account*
exit
CCTV Networking Technical Support
Apr 10, 2017 | Home Security
Zmoda "no root"
You will need to contact Zmodo. It is most likely a corrupt password. You maybe able to access your menu, but wont be able to do anything and will get the "no root" error message. They will verify you are the actual owner via either your registration or a number off your orig invoice, for security reasons. (You could be a crook trying to delete the evidence, its good they check) They will then give you a bypass admin code to put in, then direct you to change your password and you should be all set. I just got done doing this after waiting for an hr with their online LIVE chat, and finally just called and waited the 15 mins for someone to answer. Its a small shop, but, they were friendly, knowledgeable and most important, spoke REAL ENGLISH!! =]) I spoke with Tony and after I got it fixed, he gave me a case number which will allow me not to have to go through all the verification next time around if I give it to him.. so, find your invoice and place that case number on it for future reference and put it in a handy location you wont forget.
Hope this helps the 20 plus ppl I found also asking pretty much the same question. I looked all over the net and I am an IT Professional and I couldn't find an answer.. even on their website. I plan on adding the answer there too as well. Have a GREAT DAY! =])
Jan 08, 2013 | OEM Systems Zmodo Surveillance...
Bought a new q see qt 428 security camera system however cant access menus, the password window keeps popping up. This the first time I am using this system..
usually the user name and password in a user manual. Please check .
sometimes, default user name and password is the same: admin
Sep 13, 2012 | Digital Peripheral Solutions Q-see...
Userid and Password for DLINK DVR-628 Router
Select Admin and leave the password blank to enter the config settings
Jul 05, 2009 | D-Link DI-604 - 4-Port Broadband Router [...
Its not the bios password but the config/admin
follow the steps below:
1) just remove the jumper and fix it again.
or
1) remove the battery and fix it again.
Mar 13, 2009 | Dell Latitude 100L Notebook
I have an eyemax dvr .. i cant get to the admin password.. is there anyway to reset this?
In the C:\Windows and look for DVR2.ini file. Open the file and scroll to the "Users" section and look for admin and replace all of the information next to the "=" with:
61646D696E000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000FF130000FFFF00000000000000000000000000000000000019
This will replace the current password with a blank password.
Mar 09, 2009 | Home Security
DWA 552 and 2WIRE HP1000
you dont have router protected (is not yours anymore).to gain control again, you can rest config. but you need your router manual nerby, to help you config. a previous internet provider config. and so on. to reset router config, you press a reset button on the back, until the lights is off/red. then config the router on the router website( writen on botton with default user and passw.(user: admin passw: admin or password) the wan config, Wlan,...
(Use a wpa2/wep encrption level on Wlan config.)
Note: change all router passw every 30 days, or less if necessary.
Jul 24, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Admin password DVR-X4 IP
i lost the dvr password how to watch yastaday data
Mar 11, 2008 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Dell Wireless 2350 Router
I can definitely help you on this, however, this would require us follow a few troubleshooting steps which cannot be dictated here. So, I would request you to initiate a chat session with me from the fixya homepage and we would carry on from there. Cheers
May 15, 2007 | Dell Wireless 2350 Router
Clover Corporation CDR-4070 Video Recorder Logo
3,377 people viewed this question
Top Clover Corporation Televison & Video Experts
Are you a Clover Corporation Televison and Video Expert? Answer questions, earn points and help others
