Question about Whirlpool Home
Jets wont come on my Swirl-way tub - Whirlpool Home
5 Suggested Answers
SOURCE: I have a Mansfield, Swirl-way tub. Jets won't come
on mine water got behind the soft touch controll and corroded the connection see if there is green gunck on the phone like plug
Posted on Mar 12, 2010
uspartscente
  • 717 Answers
SOURCE: purchased new home with a
is there an air button on the top of the tub? if so that is what you would turn the pump on/off with. give it a push and see. if you do have a button to push like that then make sure the air tubing is hooked up to the bottom of the air button and the other end is hooked to the air switch in the back of the motor.
if there is NO air button to push and just the logo on the top of the tub then you will need to fill the tub with water, get into the tub and then touch the logo. that would turn an older Swirlway tub on/off.
Posted on Feb 08, 2011
  • 16 Answers
SOURCE: Just bought a home with a swirl - away tub need to
Check with your local plumbing supply shop, there are special self cleaning chemicals to run thru the system, also can be purchased on line.
Posted on May 19, 2011
uspartscente
  • 717 Answers
SOURCE: need to find out why
see if the jet faces turn at all. Sometimes the jets are adjustable to allow more pressure from some jets.
turn the face of the jet and see what happens.
Posted on Aug 18, 2011
My hot tub has an issue. Only half the display is working, there's no heat and the jets wont turn on. If I trip the curcit, I can get the hot tub jets for 10-30 seconds and that's it. HELp
Almost all hot tubs use 230 volt AC power which comes from the power company in two power wires plus one common common wire. You get common 115 volts between a common and either other wire. "Half way" working could well be an attempt to run on only one of the wires. There is also likely to be a ground fault circuit breaker in the wiring which makes sure current going out to the tub is all returned via the wires and not through someone's legs to ground. If you're comfortable with an AC voltmeter check some voltages but understand that 230 volts is way into the killing range. Two people present and well insulated probes are important.
Apr 15, 2016 | Pool & Spa
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Need to find out why 2 of the 6 jets on my acer swirl bath tub don't push water out like the other 4, and where can I find replacement jets. We bought the home recently and it was built in 2000. so...
Aug 16, 2011 | Home
Just bought a home with a swirl - away tub need to clean out and I am not sure how to remove the jets from the inside of the tub. I need to clean them..
May 19, 2011 | Whirlpool Home
Purchased new home with a swirl-way avalon jetted tub dont know how to start it please help
Feb 06, 2011 | Home
I discovered tiny ball bearings in my hot tub. Where could they come from? The hot tub is working fine.
The ball bearings from your spa are from a roto head jet. Typically they are from one of the larger sized jets and they make the swivel action in the roto swirl jets function smoothly. You can determine which jet is coming apart by the loose function of the center nozzle. The jet can be removed and replaced to solve this problem. Most jets screw out but when they have deteriorated a lot, you may need plyers to take the jet out in pieces.
Jan 03, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
I have a Mansfield, Swirl-way tub. Jets won't come on. Lights are working, but no action from the jets.
Oct 04, 2009 | Whirlpool Home
Jet tub just wont start
well i''m a plumber and it wouldn't be one of our problems. most likely, the electrishians didn't hook power up to it, or they did it wrong and burn't it out.
Sep 19, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Home Logo
51 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
