Question about Microsoft Xbox 360 Console
Network Issues - XBox 360
I have two desktop computers, both running vista, and an xbox 360. I have a wireless g router and the computers are setup on the network. I have both computers connected to the internet, however, I am unsuccessful with sharing files and music between the two computers. In the network map, I can see my 2nd computer but I cannot click on it. It appears transparent.
Also, My XBox 360 is connected wirelessly to XBox Live, but I am unable to connect my xbox 360 to my PC's that are on the internet. I dnt know what is wrong. I can connect to the internet, but I cant connect to my PC. What do you think the problem could be with Vista?
  • Anonymous Jan 22, 2009
    It now displays as Network Error:
    It tells me to check the spelling of the name (Network Name). Otherwise, there might be a problem with your network.
Make sure you having network sharing enabled on your computers
Posted on Jan 22, 2009
Am trying to get xbobx live for my nephews birthday, hes got the xbox 360 ellite, but its not the shinny latest model do i need a wireless adapter as well as the router that came with my broadband, but we...
If you do not have a router that you can plug directly into the back of the Xbox 360 then yes you will need to purchase a wireless router to sync up with your wireless router that you already have downstairs. You didn't specify if your broadband router had wireless capabilities? Does it? If not then you will need to buy a wireless router to be able to hook up your Xbox 360.
Microsoft has their own personal wireless router that fits on the back of the Xbox 360 nicely. I would recommend you purchase it due to ease of installation and compatability.
Here is a link to an example of what it looks like: http://www.gamestop.com/xbox-360/accessories/xbox-360-wireless-n-networking-adapter/76045?ref=recpdp&cross=802124
And a cheaper older model: http://www.gamestop.com/xbox-360/accessories/xbox-360-wireless-network-adapter/40678
And here is a link to Xbox step by step wirless hookup: http://support.xbox.com/en-us/pages/xbox-live/get-started/connecting/wireless.aspx
If you are having specific issues then ask away and I can see what I can do to help you out. Try to be specific on what your current setup is and what problems you are having. thanks.
Jul 16, 2011 | Microsoft Video Game Consoles & Games
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
Tip
How to set up WiFi on XBOX
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
on Feb 07, 2010 | Video Game Consoles & Games
Having trouble connecting Xbox live. Have wireless router and wireless Xbox 360 adapter. Figured out where adapter goes. Now I'm stuck.
Is the router already setup and working? Do you have anything else that successfully connects to it "wirelessly", like a laptop or desktop or smartphone? If the answer is yes, here's how to setup the 360 to connect to your router:
1. Turn on the console and navigate to the wireless settings screen. On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
2. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
3. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
4. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead.
5. Save your settings and verify the network is functional. On the Xbox 360, use the "Test Xbox Live Connection" option.
What You Need: Active Xbox Live subscription (to access services)
edited from here: http://compnetworking.about.com/od/wifihomenetworking/ht/xbox2wifirouter.htm
Mar 05, 2011 | D-Link DI-624 Air Plus XtremeG Wireless...
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
Tip
Configure XBOX with Media Center
Windows Media Center setup on your Xbox 360 Begin by connecting your Xbox 360 to your home network. The Introduction to Home Networking guide on the Xbox website will provide information if you're setting up a network for the first time or if you need some guidance for adding the Xbox 360 to your existing home network.
Once your Xbox 360 is connected to your network, begin the Windows Media Center setup process by pressing the green button on your remote control (if you have one), or use your game controller to select the Media Center option from the Media tab in the Xbox 360 on-screen menu.
You are asked if you want to connect your Xbox 360 to a PC running Windows Media Center in Windows Vista. Select the Media Center option to continue.
Once your Windows Vista-based PC has been detected, your Xbox 360 will display an eight-digit code. Write down this code on a piece of paper, and then go to your Windows Vista-based PC.
Note: When connecting to a Windows Vista-based PC, you do not need to select Continue or download additional software.
Add your Xbox 360 as an Extender to your Windows Vista-based PC Important: During the setup process, the Windows Firewall is automatically configured to enable your Windows Media Center Extender to connect to your Windows Vista-based PC. If you're using extra security software that includes a non-Microsoft firewall, you may need to manually configure your firewall to ensure a successful setup and connection.
With your eight-digit code in hand, begin by selecting Windows Media Center from the Start menu in Windows Vista. From the Windows Media Center menu, select Tasks, and then select Add Extender. This will begin a simple, step-by-step path that will add your Xbox 360 to your Windows Vista-based PC. During this setup process, you will be asked to provide the eight-digit setup key you received from your Xbox 360.
Click through this preview of the setup to familiarize yourself with the process.
The Extender Setup screen provides an introduction of the steps you'll go through to add an Extender to your Windows Vista-based PC. Click Next to start the process.
Enter the eight-digit setup key you received from your Xbox 360 (the one that you wrote down on your piece of paper, right?), and then click Next.
The setup process will need to make changes to your Windows Vista-based PC settings to establish the connection to the Xbox 360. Click Next to continue.
Review the information provided about Away Mode. Make your selection, and then click Next.
The setup process will ask if you would like to share media with the Extender. Select Yes (recommended) to share media folders, and then click Next. If you are using User Account Control, you'll see a User Account Control dialog box that will seek your permission to run the Windows Media Center Extender Configuration. Select Continue to grant permission.
Your PC will now go through the remaining steps to configure itself and establish the connection to your Xbox 360.
That's it! You're done! When you're finished with the PC setup, go back to your Xbox 360, and start enjoying access to all of the digital entertainment stored on your Windows Vista–based PC through your Xbox 360.
Optimize your home network The quality of your entertainment experience, especially video playback, is dependent on having a reliable and high-performance home network. To help ensure the best performance, we recommend that you run the Windows Media Center Extender Network Performance Tuner during the setup process on your PC. The Network Tuner provides very specific feedback on your network, as well as tips to solve any potential problems.
You can click through the preview of the Network Performance Tuner to familiarize yourself with the process.
The Network Performance Tuner runs diagnostics on your home network and provides feedback on potential issues that would make your Windows Media Center experience less than optimal.
When analyzing the network, the Network Tuner provides specific feedback based on all of the components connected to your network.
The Network Tuner provides feedback on the types of media that your network may have trouble handling effectively and suggests corrective actions than can help to solve the problem
The Network Tuner also looks for performance issues related to how your network is set up. In this case, the fact that the Windows Vista-based PC and the Xbox 360 are both connected wirelessly to the router may cause performance issues. You'll only see these warnings screens when the Network Tuner has detected a problem.
Real-time feedback is offered through the Network Tuner, so you can see if the adjustments you make to your network improve the performance.
Regards,
Shrey
on Dec 17, 2009 | Computers & Internet
How to hookup wireless internet
I am trying to set up xbox live for my son but when i try to go live on the xbox dashboard it says that wireless network not connected but i have a wireless network running in my house and need to know how...
Tips:
What You Need:
  • Active Xbox Live subscription (to access services)
Source: About.com
Sep 29, 2008 | Computers & Internet
Xbox 360 wireless adapter not connecting 2 pc
u need a wireless router linsky is about the best out there
Sep 20, 2008 | Microsoft Wireless Network Adapter Xbox...
Microsoft Xbox 360 Console Logo
98 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
