Question about Broan-NuTone Allure III QS330SS Kitchen Hood
I can switch on lights and fan, but then they switch off
The lights and fan work initially, but after a short while everything shuts down.  A few minutes later, it works again.  Seems like a thermal problem.  What part should I replace most likely?  The control panel, or one of the transformers?
  • 38 Answers
It could be either. Usually i would say its the control board, but its very possible that its the transformer. I would start with that, the trans=25$ then control board = 110$
Its the small transformer (blue/yellow/black/white) wires coming out of it.
Posted on Feb 08, 2009
Have a 2004 dodge caravan battery went put in a new one interior lights came back on when turn the key to start the van it shuts off no lights no nothing and in a few minutes the lights come back on
Try this to reset the system
Insert the ignition key into the driver side door lock.
  • Turn the key counterclockwise to unlock the door.
  • Turn the key clockwise to initiate the alarm activation sequence.
  • Turn the key counterclockwise. The alarm will stop and reset itself.
  • Nov 17, 2016 | Dodge Cars & Trucks
    My light stays on when I close the door.
    If the light stayed on AND the tray kept spinning around, or a fan kept running, then I would say you have a bad door switch. But if everything else works like it is supposed to, then you probably have a relay on the main control board that is stuck closed (on) or you have a shorted triac on the main board. Since very few technicians troubleshoot down to the component level or repair boards, you are probably looking at a board replacement - a rather expensive proposition to fix a light that is stuck on.
    Jun 15, 2016 | Emerson MW8999RD 900 Watt Microwave Oven -...
    Heater fan runs for a few min then shuts down
    Check the afc Automatic fan control is shut off too soon .
    Apr 29, 2017 | Vulcan Heating & Cooling
    Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
    some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
    Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
    I turn car off and something keeps running sounds like /fan/electric motor drains my battery.
    When you switch off pull the fuses out one at a time to isolate the guilty circuit that is running on after shut down. There are are only a few circuits that are powered when the car is off (alarm, interior lights etc.) so you will need to check if there is short or switch malfunction that would allow the power drain.
    Feb 21, 2011 | Mercedes-Benz CL550 Cars & Trucks
    Fan blows, gas flows, ignitor lights, gas burns only for a few seconds then kicks off, repeats a few times then shuts down
    Check the circuit for the draft inducer fan motor. The centrifugal switch in the motor may be shutting down. This stops power to the gas valve.
    Nov 20, 2009 | Goodman Heating & Cooling
    Dell Inspiron 8100 Motherboard Problem?
    if the processor fan is off or removed processor heat and its work for 1 or 2 second thats why change the fan and then try again
    Oct 02, 2009 | Dell Computers & Internet
    The unit runs for a few minutes and completely shuts down
    Without the model or make sound like a bad thermostat..check amps the the compressor and voltage... if the compressor is locking up or the thermostat cutting voltage to it..
    Hope this helps
    Apr 05, 2008 | Refrigerators
    Whirlpool RM988PYVW microwave oven
    Wonder what that belt was? This model doesn't seem to use a blet of any kind. This may be a problem with the control panel assembly, which we repair nationwide for $39.95. Full information on our service is available at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Please feel free to follow up here or privately if you have other questions.
    Aug 12, 2007 | Whirlpool RMC275PD Microwave Oven
    Broan-NuTone Allure III QS330SS Kitchen Hood Logo
    333 people viewed this question
    Top Broan-NuTone Kitchen Ranges Experts
    Dan Phillips
    Level 1 Expert
    Phil Lovisek
    Phil Lovisek
    Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
