Question about Whirlpool Washing Machines
Need central control unit for whirlpool WFW9050XW00
2 Suggested Answers
duby1990
  • 367 Answers
SOURCE: Need a part number
The part number is W10160252. You can order the part at sears.com . The price is 131.10
Posted on Nov 21, 2008
I have a Whirlpool washer WFW9050XW00 that stops during the wash cycle. The machine beeps and the wash light flashes 8 times pauses and flashes 1 more time. Thank you in advance
http://www.repairclinic.com/Shop-For-Parts/a11b5d875741/Model-WFW9050XW00-Whirlpool-Washing-Machine-Parts >Go to the website provided and you can check some troubleshooting options. If your issue isn't addressed there click on repair help or Live Chat Now for free assistance. The Google search showed this site and said live help is free. Hope this helps.
Jan 06, 2015 | Whirlpool Washing Machines
Water level switch and control WFW9050XW00 W10239066
Please check this link for tips to wire the water level controller, the pressure switch. click on :Pressure switch.
Jan 11, 2013 | Whirlpool WFW9050X Washer
Getingcodef71onwasherwasherwillnotstart
An F71 error indicates that the control panel (the buttons you press) is not communicating with the central control unit. Open the panel and check if there is continuity to the control panel wiring harness. Make sure that the wiring harness is fully connected to the user interface panel and the central control unit. Depending on if the drum rotates, you need to replace the user interface or the central control unit. (If the drum rotates, then it's probably the user interface. Otherwise it's the central control unit.)
Whirlpool has the parts diagram for the GHW9150P on their site in the Manuals and Literature section. The direct link to the parts list for the GHW9150PW0 is: https://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%208180440.pdf . For other models, enter the model number and click search on this page: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . This site has the parts for the GHW9150PW0: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136839&diagram_id=28192106 . If you have a different model, start here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ghw9150p .
I hope this helps.
Oct 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet getting error code F70 and F71. When hitting start button, getting a clicking sound and nothing is happening. Cannot open the washer door as it is locked with clothing inside it.
Hi jreib29,
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested.
Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
F71: USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
4. Replace Central Control Unit if drum is not moving.
Hope this helps.
Thank you for using FixYa.
Sep 17, 2011 | Whirlpool Kitchen Ranges
F70 error code?
Hi.
You find more in this article.
Regards.
Ginko
Aug 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code f70
F70 Error code means Central Control Unit Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
F71 error code meansUser Interface Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
In both the above situations the following things are required to be checked and replaced where required:
1. Continuity of the User Interface harness.
2. Wire harness connections to the User Interface and the Central Control Unit.
Oct 04, 2010 | Whirlpool Duet WFW9550 Washer
I HAVE A WHIRLPOOL DUET WASHER WITH A ERROR F 70
Hi
Thanks for using FixYa. Error F70 is Central Control unit Heartbeat failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface. To resolve this issue you’ll have to:
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washing Maching fault code F70
Hi
Thanks for using FixYa. Error F70 is a communication error between the Central control unit (CCU) and the user interface. To start with you’ll need to check continuity of the user interface and then check the wire harness connecting the user interface & central control unit. If the drum is not moving then central control unit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool aws 3551 fault FO7
Hi
Fault F07 is a Motor Control Unit Error. It means that the Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. To resolve this issue you need to:
  • Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
  • Check the Drive Motor
  • Check the Wire Harness
  • Please revert for further assistance.
    Thanks
    Rylee
    Jul 25, 2009 | Whirlpool Washing Machines
    Washing Machines Logo
    48 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
