Question about Kenmore 63942 Dryer
Changing heating element on a frigidaire dyer
I cant seem to locate the heating element on my frigidaire dryer, please tell me where to find it, so it can be changed.
    Genius:
  • 2,920 Answers
The heating element is in the back of the dryer.there should be a cover you can remove so you can see it or you may have to take the top off the dryer to get to it. either way it is the back of the machine
Posted on Jan 22, 2009
    Novelist:
  • 101 Answers
If you dryer lint screen is located at the top of your dryer your heating element is going to located at the rear of your dryer. You will need to remove the back of the dryer to get to it. You will see a housing and the element is located in there. If you lint screen is located in the door when you open the door then your heating element is located in the front. This one is easier to get to. Simply remove the bottom panel under the door and you will see the heating element right at the front on the right hand side. Make sure you unplug the dryer before working on it. If you have any other questions feel free to ask and also please let me know if this was helpful for you. Good luck and glad to help.
Where are fuses located in Frigidaire front loading dryer?
No fuses. Probably Heating element or one of the thermal switches. Electric dryer I am assuming
May 24, 2015 | Frigidaire Dryers
A step by step video on who to find and change a heating element on a frigidaire crown dryer
Good morning friend, thank you for your post!
I see you are trying to change the heating element on your Frigidaire Crown dryer. I am unable to locate any video to assist in this replacement but I would advise that these intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
Jul 30, 2014 | Frigidaire Dryers
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Trying to replace heating element in my frigidaire dryer model# fde336res2. where is the darn element? thanx kevin
Hi awc9859...
Your heating element is behind the drum where it is attached and case of the dryer
I have also attached a link so you could view the part in its location...double click on the drawing and look for part 15.
Please take time to rate me thumbs up
http://www.partselect.com/PS418120-Frigidaire-131553900-Heating-Element-Assembly.htm?SourceCode=5&ModelNum=fde336
Sep 10, 2011 | Frigidaire Dryers
NEED TO INSTALL HEATING ELEMENT ON MODEL FEX83ICSO STACKABLE DYER
This is it, Good Luck Tim:
http://www.partselect.com/dryer+replace-heating-element+repair.htm
May 26, 2011 | Frigidaire Dryers
Frigidaire LC-240H-W*2 change heating from 240 to120
the heating element is always 120 volts.
the two lines from the breaker box to the dyer consist of two 110 volt lines which one runs the motor and one for the heating element
May 21, 2011 | Dryers
Kenmore electric dryer 90 series part# 3405768 kit # 27918 problems. The dyer heats up, the bulb at the door lights, but the dyer doesn't hum neither does it rotate to dry clothes! I'm unable to locate the...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 24, 2011 | Dryers
Model LEQ6000ES Affinity Frigidaire electric dyer purchased 5-29-06: tumbles but won't heat. Cleaned all air ducts and lint trap and still won't heat. Error codes not obvious. What else can we check?
you will need to check the main power and make sure there is 220 volts at the termianl block if that is goor then you will need to check the heating element an all thermal fuses.
remove the small panel in the back of the dryer so you can get the belt loose.
then remove the lid.Take out the four screws that hold the control panel in place.
then remove the screws that hold the front panel on and then remove the drum lift up on the back of the drum to get it loos e from the carrier bearing holder thenyou can get to the heating element and thermal fuse on the back wall of the dryer and the side wall of the heating element can.
Jan 08, 2011 | Frigidaire Electric Dryer
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Kenmore 63942 Dryer Logo
157 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
