Question about Dryers
Laqe7011kw0 WHAT IS THE CAPACITY OF THE FRIDIGARE AFFINITY DRYER LAQE7011KWO
How do I unlock it?
Try unplugging, then plug back in.
Jul 31, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Super...
How do you open the Frigidaire affinity dryer bc i think the belt is broken
If the belt is broken dryer will not tumble, you can turn drum and should be resistance to turn, if turns easy then belt is broken. This is a difficult repair. If you can't see how to open dryer you won't be able to replace belt.
Aug 30, 2014 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
My frigidair affinity dryer wont start it just beeps
Good Afternoon Friend,
I understand that your Frigidaire Affinity dryer, model# FASE7073NW, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
Jun 01, 2014 | Frigidaire Affinity FASE7073NW 27"...
Empty the dryer does not squeak but add clothes to it starts up, Frigidaire LEQ6000ES2
Hello David Strobel - Do you notice the black substance after you take the clothing out of the washer or is it after it has been in the dryer?
Dec 09, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Super...
When you push the start button the dryer buzzes and never clicks over to start.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Super...
My dryer is making a humming sound when you try to start it,all lights will come on but it will not start, i did a test on it and its showing error code e68, how do i fix this
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Feb 11, 2011 | Electrolux Frigidaire Affinity 5.8 cu. ft....
How to remove board
to gain access to the control board you will need to unplug the dryer move it out so you can get behind the dryer, remove the six bolts and the panel will come off. Also, there should be a booklet/wiring diagram in the left corner(back-view). I am assuming that you had a E68, hope this helps Tim
Oct 28, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Super...
I have anffinity AE06700FSO. It heats but doesn't turn. I read there are fuses. If so, where?
heatman101
Oct 23, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Super...
Fridigare dryer model# FDG336RES2 not heating
If yours is a gas dryer the spark ignitor needs to be replaced
Mar 17, 2010 | Dryers
Dryers Logo
48 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
