Question about Xerox Phaser 8500/DN Printer
Phaser 8500 what does error code 07,010,43;44116 mean?
  • fred116 Jan 23, 2009
    Need more instructions on how to fix this
    President:
  • 2,072 Answers
That is a print head movement fault.
There are 2 things that normally cause that. One is the print head pivot block becomes contaminated with ink, the other is the wiper blade tacks to the print head.
If you want instructions let me know.
Posted on Jan 23, 2009
  • Rick Kasper Jan 23, 2009
    What happens is if the printer is not sitting level, both front to back and side to side, ink will seep down the print head and get into the print head pivot block. If you remove the covers that block is a 1 inch by 1 inch stainless steel block. located on the left side of the machine, ( looking from the front). It is located about 2/3rd of the way back on the lower part of the frame. Take a look at it, you will probably see yellow ink contamination in the block. You may have to use a pair of chennel lock pliers to remove it, but once removed you need to soak it in warm water to easily clean it. clean the block, the shaft that runs through it and remove the excess ink spilled into the machine. Honestly the easiest way to do that is to remove the print head. If you need to go that far let me know if you want to remove it and I will send directions.
    Secondly the print head wiper blade could be tacked to the print head. That will happen if you shut the machine doen improperly, or if there is a power failure or the machine is being unplugged instead of shut down. That would require the removal of the ink loader, ( where you add the ink sticks) to access the print head / drum area. You can then gently detack the blade from the print head. Then run the cleaning cycle.
  • Rick Kasper Jan 27, 2009
    Did you resolve the problem? Or do you need more details.
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 error 09.005.40:64314
Best way to do that is take a screw. I use a drywall screw, and twist them into the blocks and slide them back and out. Remove all of them, see if there is just one stuck or not compltely advanced in the loader. Then replace them all . That should clear the code.
Feb 03, 2010 | Xerox Phaser 8500/DN Printer
Phaser 8860 error code 08,030.46;21225
The Media Path Motor Stalled
Solutions ranked by relevance:
Make Sure There is no Paper Trapped in the Paper Path
Power the Printer OFF, Wait 30 Seconds and Then Power ON
Oct 01, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Xero phaser 8500 red light on can not print
Is there an error message or error code appearing?
Mar 19, 2009 | Xerox Phaser 8500/DN Printer
Error code regarding ink sticks on Phaser 8500
the .46 means the problem is with the black ink stick. What you can try is this. In the bottom of the ink loader, there is a small pressure switch, There is one in each color slot. Take a pencil, use the eraser side to slide all the way to the bottom of where you load the black sticks. Move the earser end around there to see if the that actuator is just stuck. Normally you just have a piece of an ink stick stuck blocking that sensor.
It is possible the ink loader will need to be replaced, but I honestly have never seen one fail.
Jan 20, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8500 error 19.003.48
That is a print head calabration error.
Most likely the print head has failed.
Those also are extremely expensive parts you put into it.
Oct 21, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500N Printer Error
That is a yellow ink stick fault.
One is most likely stuck. cracked or otherwise not advance to the front of the ink loader. Check the sticks
May 27, 2008 | Xerox Phaser 8500/DN Printer
Error code 09,038,46:21303
When you service a Phaser 8500 or 8550 printer for:
· a persistent Ink Out message
· 9,035.43 Cyan Ink Stick Count Fault
· 9,036.44 Magenta Ink Stick Count Fault
· 9,037.45 Yellow Ink Stick Count Fault
· 9,038.46 Black Ink Stick Count Fault
Test the Ink Out Sensors for proper operation.
Inspect the Ink Sticks.
Apr 09, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
167 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
