Question about Excalibur Micro Chopper Wireless Indoor Helicopter
My Excalibur Micro Chopper spins in circles!!! :(
Hi, I have a red Excalibur Micro Chopper that I have just recently taken apart and put back together. (I had to fix the on/off button.) It did not do this from the start, but when it is turned on and charged pretty well, (with new batteries in the remote control) it spins in circles and doesn't go up when I push the upward control lever. The side control lever works a little, but it is hard to tell with the spinning. The remote control works fine, and the helicopter is fairly new. (as in it has not been used too much) I am also not sure if it will go up or not, but if the spinning is fixed, I am sure it will go up as well. Please help!!!
3 Suggested Answers
  • 22 Answers
SOURCE: I have a micro flyers
i think the internal battery in the helicopter is dead because it hasn't been charged for a long time
Posted on Dec 14, 2010
SOURCE: Need a manual for Excalibur
Una foto o un video es de gran ayuda,Use un lenguaje sencillo, no jerga de la industria
Posted on Nov 10, 2011
Casdon washing machine red light flashing
Quite a simple fix!. The door sensor inside the housing has moved, so when the door closes the connector on the door isn't touching the micro-switch inside.
Remove the batteries first and then undo the screws on the back of the unit and pull it slowly apart. Do not remove the screw that is in the centre of the drum on the back. This doesn't need removing!
Once pulled apart undo the 4 screws that hold the drum housing in place. You will then see the micro-switch which will probably need adjusting up into its original position. Once back into position, I found using strong tape the best, test the door by closing it. If the sensor is in the correct position you will hear the micro-switch click on and off.
Put all the screws back, put the batteries back in and away you go! With the door closed the drum should start spinning around again when you hit the Wash buttons.
Feb 23, 2013 | Casdon Hotpoint Electronic Toy Washer
I have a bissell powerforce bagless turbo. The problem is the brush bar is not spinning. I have cleaned out all the debris on the brush itself, and taken it apart to make sure nothing is blocking the
Sorry to hear you're having difficulty with your vacuum. You may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your vacuum. Here's a quick link to locating a Service Center. http://www.bissell.com/service-centers/?cid=ccsocial
Dec 19, 2012 | Bissell Vacuums
Need a manual for Excalibur Electronics Micro Flyer Helicopter
Jan 16, 2011 | Excalibur Micro Chopper Wireless Indoor...
The copter won't lift off the ground. It is the Wasp Micro Chopper.
check for hairs or debri around rotor shaft weak batterie in charger
or failing Lipo battery
Dec 26, 2010 | Excalibur Micro Chopper Wireless Indoor...
Kitchen aid dishwasher not cleaning dishes well. especially the top rack. practically taken the whole thing apart can't find any clogs.
sounds like you have a broken chopper. have you checked the chopper how far have you taken it apart? if the unit is put back together point all wash arms in the same direction turn the dishwasher on after it has started washing give it about 2-3 minutes open the door and see what wash arm is not moveing. if the upper wash arm is not moveing you need to check the chopper.
Oct 18, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 | Dishwashers
Daewoo 750
if spin not worke there is 3 resone one spin motor out of order2. spin door not close well 3 capacitor is not good
Nov 19, 2007 | Daewoo DW500M Top Load Washer
Top rack arm doesn't spin.
matt, did you get down to the chopper screen? If that screen is clogged the flow to the upper arm will be restricted. Check out the pic, Catriver
Sep 29, 2007 | Kenmore 24 in. 17362 / 17364 / 17369...
Kenmore Ultra Wash Dishwasher
Cyber, did you get down to the chopper screen? If that is clogged with gunk it will restrict the flow and the top arm will not spin. Im going to try to attach a pic of the chopper assy and screen. Catriver..post back
Apr 02, 2007 | Kenmore 24 in. 16582 Built-in Dishwasher
Excalibur Micro Chopper Wireless Indoor Helicopter Logo
Top Excalibur Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Excalibur Toy Expert? Answer questions, earn points and help others
