Question about Casio FX-260 Calculator
X to the y button
I can't figure out how to use the x to the y button. How do you do it?
  • 432 Answers
Hope this helps http://www.dur.ac.uk/stat.web/functions.htm http://www.acenet.edu/AM/Template.cfm?Section=Home&Template=/CM/HTMLDisplay.cfm&ContentID=5497
Posted on Jul 06, 2007
Samsung AK59-00123A remote to a M261VP vizio tv
Hello
[1] Switch your television on
[2] Point the remote control towards the
television
[3] Press and hold the TV POWER button, and
then enter the two-figure code in the table
to the right that corresponds to the brand of
your television by pressing the appropriate
number buttons.
If your television is compatible with the remote
control, it will switch off.
The remote is now programmed to operate
the TV.
The code for Zenith TV is [TV POWER + 63]
Sep 20, 2011 | Zenith ZEN700 Remote Control
How do I set the time on a sports air warch
Q. How to set my watch A. The A and M button are located on the back of the watch LCD screen. When looking at the watch right side up the A button is the one on top and the M button is located below the A button.
1. Press A button twice, the month figure appears, press M to adjust the month.
2. Press A button once, the date figure appears, press M to adjust the date.
3. Press A button once, the hour figure appears, press M to adjust the hour.
4. Press A button once, the minute figure appears, press M to adjust the minutes.
5. Press A button twice to finalize the settings!
sports air watch
Dec 13, 2010 | Watches
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 | Watches
Unidentified button on dash of 2007 Ram 2500 Laramie
did you ever figure out what this button is? I've seen very few trucks with this button and has me curious.
May 23, 2010 | 2007 Dodge Ram 2500 Mega Cab Laramie
Tax button
under the GT button at the top, switch that button to the "Rate"..enter whatever % tax rate you want. Then move button back to off setting.
enter your number and hit the plus sign, then the tax+ button or the tax- button. it will automatically figure the tax for you. You may have to play with it a bit..I got the pdf version from the canon tech geeks, and the directions leave lots to be desired. Good Luck!
Oct 31, 2008 | Canon MP-25DV Calculator
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Help! Cannot remove old ink cartridge!
  1. Open the front cover and then open the top cover. (Figure 1)
    Figure 1: Open front and top cover
  2. Raise the lever on the top right side of the drum cartridge. (Figure 2)
    Figure 2: Raise drum cartridge lever
  3. Grasp the drum cartridge by the handle and lift up and out. (Figure 3)
    Figure 3: Remove drum cartridge
******Very Important***************
To reset the NVRAM, perform the following steps:
Press the Menu button.
Press the (down arrow) button on the printer until Configure appears, and then press the (right arrow) button on the printer or (Set) button.
Press on the printer until Maintenance appears, and then press on the printer or .
Press the until Init NVRAM appears, and then press or .
Press Initializing and Restart Printer will appear.
Power off the printer and power back on.
Oct 24, 2007 | Dell 3100cn Laser Printer
Diagonal lines on print
Follow these steps.
Print Quality Problems on 3010cn.
Reset the NVRAM On the 3010cn
  1. Press the Menu button.
  2. Press the down%20arrow%203100cn.jpg (down arrow) button on the printer until Configure appears, and then press the right%20arrow%203100cn.jpg (right arrow) button on the printer or return%20arrow%203100cn.jpg (Set) button.
  3. Press down%20arrow%203100cn.jpg on the printer until Maintenance appears, and then press right%20arrow%203100cn.jpg on the printer or return%20arrow%203100cn.jpg.
  4. Press the down%20arrow%203100cn.jpg until Init NVRAM appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
  5. Press return%20arrow%203100cn.jpgInitializing and Restart Printer will appear.
  6. Power off the printer and power back on.
To print the Gradation [ESS] test print, perform the following steps:
  1. Power off the printer.
  2. Hold down the up and down arrow buttons on the printer and power the printer on. This will bring up a Customer Mode menu.
  3. Press the down arrow button until Test Print appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow button until Gradation [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. On the LCD, Processing appears and the test page is printed.
To print all four 20% toner test prints, perform the following step:
  4. Press the down arrow until Cyan20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. The test print will print.
  6. Press the Cancel button.
  7. Press the down arrow until Magenta20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  8. Press the return%20arrow%203100cn.jpg button. The test print will print.
  9. Press the Cancel button.
  10. Press the down arrow until Yellow20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  11. Press the return%20arrow%203100cn.jpg button. The test print will print.
  12. Press the Cancel button.
  13. Press the down arrow until Black20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  14. Press the return%20arrow%203100cn.jpg button. The test print will print.
  15. Press the Cancel button.
  16. Power off the printer and power back on.
Reseat the drum cartridge, perform the following steps:
  2. Unplug the power cable.
  3. Pull to open the front cover and then lift to open the top cover. (Figure 1)
    Figure 1 - Open Front and Top Covers
  4. Raise the lever on the top right side of the drum cartridge. (Figure 2)
    Figure 2 - Raise Lever to Release Drum Cartridge
  5. Grasp the drum cartridge by the handle and lift up and out. (Figure 3)
    Figure 3 - Remove Drum Cartridge
  6. Insert the drum cartridge.
  7. Close the top and front covers.
  8. Plug in the power cable.
  9. Power on the printer.
Apr 11, 2007 | Dell 3100cn Laser Printer
Casio FX-260 Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
