Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Walbro wt hose routing on poulan saw
2 outlets on side of carb : how do you route the hoses from the primer to the carb?
  • 12 Answers
Carb has 2 nipples. top nipple gets line with filter on it from tank, bottom nipple receives line from bulb other side of bulb returns to tank
Posted on Mar 15, 2009
  • 42 Answers
The line that is on the front side of the carb goes to the tank. the line that is on the rear side of the carb goes to the primer bulb. let me know if this helps. thanks.
My Poulan 2025 Chainsaw fuel hoses have broke down and fell apart. I have new fuel line but do not know the hose routing. All I found in the tank was pieces of hose and the filter. Only one hole coming out...
Check out epartsreplacement.com and there is a video on there you can watch that talks about fuel line replacement. It is a very helpful video Tom. Good luck
Aug 07, 2011 | Poulan Pro Chain Saw 46cc 20"
WHAT IS THE FUEL LINE ROUTING FOR A POULAN 2375LE. IS THERE A ROUTING CHART?
The fuel line from the tank with the filter on the end, goes to the main fuel inlet on the carb, the conection nearest to the alloy pump cover held with a single screw, the other conection on the carb goes to the shorter of the two conections on the back of the primer ( the suction side ), the shorter of the two conections on the back of the primer ( the pressure side ) has a hose back to the tank, just remember the primer pulls fuel from the carb, into the primer, and then back to tank.
May 16, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
Apr 17, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Primer bulb-carb routing
It should be like this.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 10, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need to replace fuel lines. routing of lines on Poulan chainsaw Model #2025 with 16" bar
A Poulan 2025 IPL follows:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://www.ordertree.com/modelinfo/PWE/2025-Gas-Saw/75.2025-Gas-Saw.1.59.1.html
Small hose (filter on bottom) long enough to reach all corners inside tank, to lower carburetor connection. Please leave the 2 carburetor connections long enough to reverse until the saw is running.
Upper carburetor connection, small hose to suction side of primer.
Pressure side of primer (large hose) to middle of tank. nothing on bottom, length not critical.
The IPL is deceptive it appears the filtered hose connects to the primer; it does not.
Typical fuel system link and a couple of suggestions here:
Lou
Mar 16, 2010 | Poulan Garden
Fuel line routing
A typical fuel system and a couple of suggestions follow:
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
If not your saw, yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I am reasonably sure the upper most carburetor connection (it bleeds any air in the carburetor, air rises) goes to the primer. Leave the hoses long enough to swap them and try it. They can be shortened once you verify the correct routing. Good Luck. HTH
Lou
Feb 24, 2010 | Poulan Pro Chain Saw 46cc 20"
I wish someone out there could draw me a diagram of how the gas line are supposed to be routed on poulan pro 210 chainsaw
You can find a typical fuel system and a couple of suggestions here:
An IPL for a Poulan PP210 can be found here:
http://www.ordertree.com/modelinfo/PWE/PP210-Gas-Saw/75.PP210-Gas-Saw.1.59.1.html
The small hose goes between the filter and carburetor and from the IPL the carburetor and primer.
The large hose between the primer and fuel tank (return).
Hose can be purchased at any chainsaw outlet, Inquire about how much hose they recommend. I have not found a good hose stretcher and I have been looking. Good luck with your project.
Lou
Jan 29, 2010 | Poulan Garden
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
How do I replace the primer bulb on a Homelite Ranger chain saw?
Most of them snap in, meaning there are two small blades that are cast into the plastic for the primer bulb housing. These tabs fit into a recess and lock when pushed in from the outside. You will need the entire replacement as you cannot just replace the bulb like is possible on a Zama or Walbro carb. Whatever you do, make sure you mark the routing of the hoses. Its always fun to get them hoses mixed up and then wonder how theyre supposed to route...
Aug 30, 2009 | Homelite Garden
Poulan 2150 fuel line routing wt324 carb
the large hose from the tank goes to the suction side of the primer bulb. The large line from the out put side of the bulb goes to the bottom inlet of the carb.
the small line goes from the top outlet tube on the carb back into the tank near the primer bulb.
Mar 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
1,614 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Dwain Pippen
Roland W VanLue
Roland W VanLue
Are you a Poulan Garden Expert? Answer questions, earn points and help others
