Toshiba COPIERS - e-Studio 205 Copier
Problem for Toshiba COPIERS - e-Studio 205 Copier
Misfed document error on screen
By sharonabusta on Jan 22, 2009
there's no paper or anything anywhere inside... i followed all directions several times and it used to work after i go thru the whole process... but now, it juz keeps on blinkin red light... so frustrated... cant work well without copier... cant afford getting service.. help?
Solution #1
posted on Feb 20, 2009
Not Rated)
cgoodall
Rank: Master
Rating: 80%, 5 votes
i've seen this one a lot when i worked as a repair man for toshiba, unfortunatley even the smallest piece of paper or a clump of dust in front of a sensor will cause a "missfeed error", if you havent already; try removing some of the basic parts on the inside and spray everything with a compressed air can like you'd use to clean the key boards, then reset the copier and hopefully that will take care of you're problem.
Was this helpful?
Yes
No
Solution #2
posted on Feb 13, 2009
Not Rated)
didi2005
Rank: Guru  Toshiba Expert
Rating: 86%, 121 votes
Sometimes small piece of paper, tissue and etc also can triggered the sensors...
Skill needed to open up everything in order to inspect.
Did u manage to get error code?
Was this helpful?
Yes
No
Solution #3
posted on Jan 23, 2009
Not Rated)
checkitright
Rank: Wiz
Rating: 82%, 1031 votes
there may be a piece of paper or a sensor is stuck,
1st remove trays and open all doors
2nd locate each sensor and see if it stuck or has something blocking it
The part that is up is the flag for the sensor , it tells the machine if there is a paper there, if it is late getting there, etc...
3 rd start with the trays, next to the wheels there should be two, one to tell it if the tray is full of paper and one to tell it it is coming out, you should be able to pull lightly on it and it should snap back into place (there is a spring inside that puts it back in place after the paper has passed)
4th look on the side where the paper should be going up
5th if you have a duplexer (2 sided option) look in there
ALL GREEN HANDLES ARE FOR USERS TO MOVE TO LOCATE PAPERS IN COPIERS
6th look in the exit where the paper comes out
some copiers ( possibly this one) you may have to physiccally remove it to see. ( wait until it cools off)
Good luck
Was this helpful?
Yes
No
Popular Solutions for Toshiba COPIERS - e-Studio 205
Questions and Unsolved Problems for Toshiba COPIERS - e-Studio 205
Do you recommend Toshiba COPIERS - e-Studio 205 Copier?
Answer
Answer
H2 eror problem haw can I solv the eror cod h2
Answer
brother copier/fax has several ghost rings after the phone has finished ringing
Answer
The scanner don't work in my toshiba e-studio 20 also copy (order) from PC program don't work please... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copiers Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
