Question about Radio Communications
Ezonics bmh 10x headset
Want to pair this old bluetooth headset with an ipod 4th generation
SOURCE: CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Posted on Aug 26, 2008
  • 10 Answers
SOURCE: Wireless headset pairing
With the Samsung WEP210 this is a common problem (which is actually just a user error)
This is what you do:
1. Of coarse make sure the headset is charged
2. Make sure the bluetooth headset if OFF
3. PRESS and HOLD the top/middle (on/off) button until the light stays on (it will blink then should stay on continuously). That means it is now in pairing mode.
4. Tell you phone to search for bluetooth devices.
5. It should find the headset, and by default type "0000" to pair your new headset**
**You can use whatever pin code you like......but I would recommend the default which is four zeros.
Posted on Dec 10, 2008
SOURCE: how can i pair my samsung bluetooth headset to
turn off the head set then press and hold the on button until the blue light stays solid blue.
search for device on your new phone and add device code is 0000
Posted on Apr 12, 2009
SOURCE: My nokia E63 wont find bluetooth headset
I had a similar problem with my headset.. but found the solution.. I am using Jabra 2010.. ok.. so just switch "off" the headset...go to the pair menu on e63.. then switch on the headset.. and then look for new pair devices option.. voila it came up. hv been trying for almost 3 weeks before i got the sequence right.. somehow if u had switched the headset on beforehand.. it wouldnt recognise it only.. the solution is here at jabra website .. although.. they dont hv e63 listed .. but the same procedure for e71 worked fine for my handset..
Posted on Aug 05, 2009
SOURCE: I have a new droid by motorola and an old h500
You need to put your H500 into "pairing mode" by pressing the call button until the light turns steady blue, instead of blinking. Your droid will then see it when you are in the Bluetooth Settings screen under Networks & Wireless. I just did this myself last night and it worked fine. Be forewarned, however, that you cannot voice-dial with your bluetooth - only answer calls. There are several forums out there that are bashing Motorola & Google for not having this basic functionality.
Posted on Feb 17, 2010
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
Dec 05, 2016 | Radio Communications
How do I pair ipod with bluetooth headset
1. go into your settings on your ipod and click on the bluetooth section so that it is open.
2. on your HEADPHONES press whatever button to start syncing the bluetooth(it will most likely start flashing blue or w.e color)
3. go back to your ipod, the device will show up in the list of avaliable devices, press it, connect it, there you go!
Mar 28, 2014 | Apple iPod nano 7th Generation
Pairing ipod nano 7th generation with plantronics bluetooth headset
Please check the video link provided below for your reference. The device used there is a iphone but the instructions on how to connect a bluetooth headset are the same.
How do you pair the 903 headset with my ipod touch?
To pair the Plantronics BackBeat 903 with an iPod Touch:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the iPod Touch:
In Settings, choose General, Bluetooth, and turn Bluetooth on.
Choose the device on iPod Touch, then enter the PIN/Passkey 0000 (4 zeros).
After pairing the 903 and iPod Touch, the headset model may appear on the screen when you are viewing the audio or video playback controls. (You can "tap" to switch to a different audio output, such as the internal speaker)
Aug 17, 2011 | Plantronics BackBeat 903 Bluetooth Headset
How do I sync my h700 Bluetooth to my iPod touch
depending on the model of iPod touch, it might not have bluetooth.
If it does, turn the iPods bluetooth on and set the headset into pairing mode. when the headset appears in the list of available devices on the iPods screen, press it and enter the code necessary for pairing (usually 0000 but it varies by manufacture)
hopefully that helps good luck
Feb 23, 2011 | Apple iPhone Apps
How do i get it to connect to my ipod
ok, this is a bit complicated of a matter so ill make it as simple as possible. First of all, the first generation iPod Touches DO NOT have bluetooth capability, so if your ipod is a first generation you cant use bluetooth. Second, the iPod must be running on the latest firmware, which can be updated through iTunes. Third, iPod Touches CANNOT pair with bluetooth headsets (such as the ones you use with a cell phone the go over one ear) however they CAN be paired with bluetooth HEADPHONES (go over your entire head to cover both ears) now assuming you meet the above criteria, the option for bluetooth is in Settings>General>Bluetooth On. place the device in pairing mode and it should be discovered. if it is not, you are using an incompatible Bluetooth Device. Hope This Helped! Remember to Rate
Aug 25, 2010 | Motorola Mobility Bluetooth...
I am trying to pair a Discovery 925 to an ipod touch (2nd generation). It recognizes "9xxPlantronics Not Connected" I click on that bar (or line) and get the keyboard screen with the request to enter...
I might be wrong, but I think the iPod Touch, not being a phone, doesn't have either HSP (HeadSet Profile) or HFP (Hands Free Profile) bluetooth profiles, solely used for phone calls. Nevertheless, being an audio/video reproduction device, it must have A2DP (Advanced Audio Distribution Profile) and AVRCP (Audio/Video Remote Control Profile), from its 2nd-gen onwards. Your problem is that the Plantronics 925, being a monoaural bluetooth headset, bears HSP and HFP only. You were able to successfully pair it with your TP2 because it is a phone. You must purchase stereo bluetooth headsets, in order to pair them with your iPod Touch.
Just my 2 cents... Carlos
May 23, 2010 | Plantronics Discovery 925 Bluetooth...
How do I pair my s9 bluetooth headset with my
do you have the adapter that makes your ipod nano have bluetooth?
im guessing you do so
turn on the bluetooth adapter on the ipod
mod the power button on the motorolla s9 untill blue light is constantly on
from the ipod select the bluethooth options and select the headset
use the password 0000
Apr 29, 2010 | Motorola Mobility MOTOROKR S9 + Bluetooth...
IPod touch not pairing with HBM-210 headset
It will never work. The profile is not included in the software. It is an exclusive function for the iPhone.
Review "iPhone, iPad, iPod touch: Supported Bluetooth pro?les" at the Apple web site.
I suffered the same pain after buying them.
Jul 29, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Radio Communications Logo
49 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
