Question about Whirlpool LSR9434PQ Top Load Washer
My roommate removed the water in hose and I need to find a manual to put it back together
My roommate removed the water in hose and pretty much took apart the entire back panel of the washer, I need help finding a do-it-yourself repair manual so that I can put it back together.
    Scholar:
  • 76 Answers
Starslight07 You can find the repair manual for your washer here: http://tinyurl.com/32d5lu Good luck. Gendos
Posted on Jul 07, 2007
Dyson wand, handle and hose are all unattached. How do I put them back together?
You can find a copy of the DC14 Manual here (
https://www.dyson.com/medialibrary/Files/Dyson/Support/downloads/US/Floorcare/manuals/dc14_opmanual_usa2007%20pdf.pdf ) Pages 4, 5, and 6 have plenty of schematics for putting the wand/handle assembly back together and getting everything to click. In a nutshell, the metal tube pretty much just slides back into the tube top, and then the slid-in tube clicks back into the top of the machine.
Good Luck!
Jul 12, 2014 | Dyson DC14 All floors Bagless Upright...
Took apart the washer and dryer and need to put it back together...i have everything except where the clear plastic hose goes
Kristen-follow the hoses-water comes into machine at the water supply valves-hot and cold which go into the tub-then there is a drain pump which is connected to the tub via a hose-the out put of the drain pump is connected to the drain through the back of the machine usually at the bottom and this goes into your houses' drain-follow the hoses and you shall reach laundry success-cheers Denny
Oct 25, 2013 | Frigidaire FEX831CS Top Load Stacked...
Im am not getting any heat either in manual or automatic. I took the hoses of the core and was able to blow air through (there was anti-freeze present). I ran the engine (hot) and no water came out...
i have a 1998 olds intrigue and had the same problem. In my case i had to pop on of the hoses off from the water put with the other hose still connected. I took a high presssure car wash sprayer on the rinse mode NO SOAP. Put the sprayer into the one hose about 1 min, then put that hose back on the water pump and did the same with the other heater hose. This completly solved my problem. You have prolly got a clog in ur heater core as I did. Just make sure no 1 sees u at the car wash doing this cuz it a major D.E.C no no, But sure to fix a clog a simple house hold garden hose will not work u need a high pressure water hose and a car wash is cheap and effective.
Jan 02, 2010 | 1998 Oldsmobile Intrigue
Bissell Pro Heat 7901 will spay through hose but not the floor and red flow indicator will not spin. So we took the housing off and after unclogging a hose running to the hearter, my husband unhooked the...
I borrowed my friends bissell to clean my carpet. It's the 7901. He brought it over and told me that it only sprayed out of the attachment hose. He said he couldn't figure out what was wrong. I'm no vacuum technician but, I am a mechnic. I decided to open her up and check it out. After about two hours it was back together and working. The reason I replied to your e-mail was because we have the same problem. I couldn't find an answer to this problem on this site so I will tell you what I found and hopefully it will help you. In removing the cover where the red heating light is, there is the heating unit for the water. In my case it is silver and it will get very hot so be careful. Notice that there is two water hoses connected to it. I removed this heater and found one of the connectors where the water hose goes was clogged. I took the back off the heater and used my air compressor to blow out the connector, and sure enough something flew out. Hope this helps. brian.small@bobstgroup.com
Sep 04, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
The water supply will not shut off
The air hose from the tub to the water level switch probably got pinched when you put the cabinet back on. Remove the console screws and raise the console. The plastic hose comes through the cabinet just below the timer. Reposition it and try again.
Aug 22, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does not fill with water
One simple thing to do is remove the hoses from the machine and remove the screens. Leave them off or clean them and put them back. The screens will probably be pretty clogged. Replace the hoses . Turn the water on check for leaks and retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2008 | Washing Machines
Same prob-GE front: drum rotated during wash, but did not drain.
Most of the time the hoses are attached with spring clamps. Just use a pliers to squeeze them together to allow you to remove them. Take off both hoses. Scoop out as much water as you can first. You may want to pull the machine forward about two feet and then tilt it back to the wall to prevent remaining water from spilling. Pump is only held down by two screws. Take them out and inspect the pump for obstructions and remove coins and other objects from the big hose.
You can do it.
Nov 16, 2008 | GE WSXH208A Front Load Washer
Whirlpool LSR9434PQ Top Load Washer Logo
117 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
