Question about Tool Shop 6 Gallon Air Compressor
Tool shop air compressor valve leaking - Tool Shop 6 Gallon Air Compressor
I have a mastercraft compressor with LCD display its 11 gallon,it runs up to about 70 psi and will not go higher but keeps running, any ideas.
You either have an air leak somewhere or you have a damaged valve in the valve body. You can check for leaks using a spray bottle with a dishwashing detergent/water mix. Spray the mixture on connectors and look for bubbles. Don't forget to check the tubing coming from the compressor head and the regulator. If you find no leaks (you need to check carefully), you might need to remove the compressor head and check to see if the valves in the valve body are damaged. My Campbell-Hausfeld compressor did the same thing and I had to replace the valve body.
Mar 08, 2017 | Psi Air Tools & Compressors
My compressor is not buildngup air pessure
Most compressors that come into the shop are not reaching cut off pressure. Here are a few tips on determining the problem /s. Three problem areas. Leaks,valves/head gaskets or worn cylinder/rings. Leaks on small compressors are easy to find by spraying soapy water on all connections and drain valves. Also spray on head gaskets. Repair as needed. No joy? Continue with checking valves. Most small compressors have reeds for valves and fail quite easily. There should be good suction at intake opening. Run compressor till no more gain in pressure. With air filter removed and pump running feel for suction at intake. If you feel very little suction or air blowing out of intake , most likely bad reeds or gaskets. If you feel good suction however no gain in pressure then likely worn cylinder. Good luck with repair.
Feb 03, 2017 | Air Tools & Compressors
I have a a old Gibralco compressor when i cut it on it starts fine when it reaches desired pressure it stops and restarts until i kicks the breaker what can i try
i suspect that the start/run capacitor is faulty or the centrifugal switch in the back of the motor is faulty
have an accredited electrician check the motor , capacitor and the pressure control switch
the air leak at the head is a faulty non return valve in the compressor line to the tank
available at good tool shops for around $60.00
Sep 07, 2015 | Air Tools & Compressors
Why is my mid 70's 2cylinder Worthington shop air compressor ( for powering pneumatic tools) suddenly leaking the compressed air out of the tank, back up through the air filter ?
You will probably have reed valves inside the head. One may be bent or broken or you may have simply blow a head gasket which is easy to fix. just google reed valves in a air compressor and you will see the setup.
You will need to take the head off which will be 6 or 8 bolts and have a look.Not hard If it is a gasket it will only cost you $30 or $40 for a kit.
May 11, 2014 | Air Tools & Compressors
IR330E20 Air Compressor check valve leaks
The in tank check valve could be leaking since the pressure switch vents head pressure. If the check valve doesn't close, air will continue to vent from the pressure switch.
Feb 02, 2014 | Ingersoll Rand Air Tools & Compressors
Compressors kicks breaker at 60 psi.
This is usually caused by long extension cord, leaking check valve or weak capacitor. Most likely leaking check valve. Easy to check, run compressor for a couple of minutes and shut off. Listen for air leaking from pressure switch or at the intake filter. If leaking, let out air and remove check valve and look for debris stuck under the valve seat. To find the checkvalve, follow the air discharge tube from the head of the compressor to the tank. You should find a brass or chrome valve threaded into the tank. If check valve is not leaking, suspect weak capacitor or long cord (motor shop will test cap for free). Good luck
Apr 02, 2013 | Craftsman Air Tools & Compressors
Sears Craftsman 919.167312 Leaking Air
http://www.searspartsdirect.com/model-number/919167312/0247/0703000.html Model 919167312 CRAFTSMAN AIR COMPRESSOR Parts . It is part 24 or 24a. The female threaded fitting is part of tank. Take the drain valve to a machine shop and have them tell what is the size and tpi. Have the chase the tank female fitting. I f don't want to that once you diameter and tpi you can buy a tape and chase it yourself. Word of warning if you start the tap crooked you will cut new threads and the tank is worthless. I wouuld pay the machine shop and be satisfied.
May 28, 2017 | Air Tools & Compressors
Wanting to replace air compressor on 1999 durango.
Air compressors very seldom become defective. However, if you wish to tackle the job make sure the freon is removed from the unit by loosening the high pressure valve. I would suggest you take it to a shop and have it repaired. Purchase what ever you need from the internet. Purchased all the parts to redo my 1966 mercury from Ebay, saved $400 hired expert to do the job for $200. Tools for replacing are expensive you would come out better by having it done. May be a small problem, such as the dryer, or low freon, or a leak Most shops will diagnosis the problem for free or a small charge. Or you could check the unit by adding a leak detector using the low side of the air condition unit. The low side is the lareer of th two lines in the unit.
Jun 08, 2009 | 1999 Dodge Durango
Oil on sprark plugs
  1. Disconnect the negative battery terminal.
  2. Remove the valve cover, using the proper procedures.
  3. Remove the camshaft, shims and rockers, if equipped, using the proper procedures.
  4. Remove the spark plugs.
  5. Rotate the engine to Top Dead Center (TDC) for each cylinder's seals that are being replaced; e.g., if replacing the No. 2 cylinder valve seals, have the No. 2 cylinder at TDC. Use a coat hanger put down into the cylinder to determine when it is at TDC.
  6. Attach a fixture at the flywheel or the front of the engine to prevent the engine from rotating. Make sure the fixture damages no components.
  7. Thread an adapter into the spark plug holes that can be hooked up to a shop compressor air hose.
  8. Apply 90 psi of shop compressor air to the adapter hose. This is done to keep the valves from dropping down into the cylinder when the valve springs are removed.
CAUTIONTo avoid personal injury, wear eye and ear protection. Keep hands and clothing away from engine parts that rotate, in case the engine does rotate from the cylinder air pressure.
  1. With the cylinder under pressure, remove the valve spring retainer and the spring, using a spring compressor tool. Hitting the spring retainer with a soft hammer may help loosen the valve keepers, if the keeper will not move downward when trying to compress the spring.
  2. With the valve spring removed, remove the oil seal.
To Install:
  1. Install a new seal, using Toyota Special Service Tool (SST) 09201-41020, or equivalent.
  2. Reinstall the valve springs (See Valves).
  3. Release the air pressure and reverse the removal procedures to complete installation.
  4. Connect the negative battery terminal, start the engine and check for leaks.
0900c15280046373.jpgFig. 1 Removing the valve sealsCelica 0900c15280046378.jpgFig. 2 Intake and exhaust valve sealsCelica 0900c15280046379.jpgFig. 3 Installing the valve sealsCelicaWith Cylinder Head Off Engine
  2. Remove the cylinder head, using the proper procedures.
  3. Remove the valve and spring (See Valves).
  4. Remove the oil seal.
To Install:
  2. Reinstall the removed components to complete installation.
  3. Connect the negative battery terminal, start the engine and check for leaks.
Aug 25, 2008 | 1990 Toyota Celica
Tool Shop 6 Gallon Air Compressor Logo
Top Tool Shop Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Tool Shop Air Tool and Compressor Expert? Answer questions, earn points and help others
